Boost user productivity and enhance performance with fast A3 printing and copying. Save time and make office tasks more efficient with scan-to-email, digital sending and optional faxing, and a choice of paper-handling and finishing options.
Simplify everyday office tasks and save valuable time
Work efficiently and simplify office tasks with an intuitive touch-screen control panel, and fast print and copy speeds of up to 40 ppm/up to 50 ppm. Send and receive faxes easily and save time with scan-to-email and digital sending. -
Increase user productivity and improve performance
Boost productivity and improve performance with a range of features which include paper handling and professional finishing options, and advanced solutions like document capture, job accounting and authentication. -
Count on these HP LaserJet MFPs to deliver a consistently reliable experience
Count on these MFPs to deliver industry-leading HP LaserJet reliability. Achieve consistent results with Original HP supplies. HP Web Jetadmin enables proactive fleet management and HP Jetdirect networking assures easy sharing in large workgroups.
- HP LaserJet M9040 MFP - multifunction printer - B/W
- Multifunction printer
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 300000 impressions
- Max Copying Speed
- Up to 40 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 40 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Scanning
- 600 dpi
- Original Size
- A3/Ledger (297 x 432 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm) (max)
- Media Type
- Transparencies, plain paper, cards, labels, bond paper
- Standard Media Capacity
- 3100 sheets
- Max Media Capacity
- 3100 sheets
- Output Trays Capacity
- 3000 sheets
- Stacker
- Optional
- Stapler
- Optional
- Automatic Duplexing
- Yes (copying)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN
- Power
- (50/60Hz)
- Microsoft Certification
- Certified for Windows Vista
- Laser - monochrome
- Interface
- Standard Memory
- 384 MB 384 MB
- Max Supported Memory
- 512 MB 512 MB
- Hard Disk Drive
- 80 GB
Copying
- Max Copying Speed
- Up to 40 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
Printing
- Up to 40 ppm
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3, PDF 1.3
- Image Enhancement Technology
- HP FastRes 1200
- First Print Out Time B/W
- 9.5 sec
Scanning
- Optical Resolution
- 600 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 30-bit
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 100 sheets
- Max Media Size
- A3/Ledger
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 227 g/m²
- Supported Media Type
- 3100 sheets
- 3100 sheets
- 3000 sheets
- 2 x input tray - 500 sheets - A3/Ledger (297 x 432 mm) , Input tray - 2000 sheets - A3/Ledger (297 x 432 mm) , Bypass tray - 100 sheets - 312 x 470 mm , ADF - 100 sheets - A3/Ledger (297 x 432 mm)
- Speed Details
- Printing: up to 40 ppm - B/W , Copying: up to 40 ppm - B/W
Finishing Equipment
- Stacker
- Optional
- Stapler
- Optional
- 1 x USB 2.0 , 1 x Gigabit LAN
- Operating System Support
- MS Windows 2000, Linux, IBM OS/2, Apple Mac OS X 10.3, Apple Mac OS X 10.2.8, Apple MacOS X 10.4 or later, MS Windows Vista, MS Windows XP Home Edition, MS Windows XP Professional
- Software Included
- Drivers & Utilities
- Voltage Required
- (50/60Hz)
- 1092 Watt
- Power Consumption Standby
- 345 Watt
- Power Consumption Sleep
- 255 Watt
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- Shipping Weight
- 181.4 kg
- 15 °C
- 32.5 °C
