HP LaserJet M527CM
HP LaserJet M527CM
Quicklinx: CP0MWS00 Mfr#: F2A80A#B19
£1,371.47 ex VAT
£1,645.76 inc VAT
Finish tasks faster with an MFP that starts right away and helps conserve energy. Multi-level device security helps protect from threats.
Accelerate your work and use less energy
Don’t wait for documents. Print your first page in as few as 8.7 seconds from energy-efficient sleep mode and 5.7 seconds from ready.
Print two-sided documents without sacrificing performance slowdowns for duplexing and let high-volume jobs handle themselves with a 2,300-sheet maximum input capacity.
Scan two-sided documents in a single pass with super-fast scan speeds. HP EveryPage allows employees to scan without worry, detect potential errors or missed pages on the spot and save time with the advanced workflow features with the Flow MFP M527c.
This MFP leads its class in low energy use – thanks to its innovative design and toner technology.
Unparalleled fleet security and management
Embedded features detect security threats and heal your MFP, protecting it from boot up to shutdown.
Protect sensitive data stored on the MFP and in transit, using embedded and optional security features.
Protect sensitive business data with embedded and optional HP JetAdvantage Security Solutions.
Centralise control of your printing environment with HP Web Jetadmin6 – and help build business efficiency.
More. Pages, Performance, and Protection.
Produce sharp text, bold blacks, and crisp graphics with precision black toner.
Get more. Original HP Toner with JetIntelligence delivers more pages per cartridge than predecessors.
Help ensure the Original HP quality you paid for with anti-fraud and cartridge authentication technology.
Print right away with a preinstalled toner cartridge. Replace it with an optional high-yield cartridge.
Stay connected with secure mobile printing options
Use optional, 128-bit encrypted wireless direct printing from mobile devices – no network needed.
Add the option to print with a touch of your NFC-enabled mobile device to this printer – no network needed.
Easily access, print, and share resources with Ethernet and optional wireless networking.
  • Accelerate your work and use less energy
    Don't wait for documents. Print your first page from energy-efficient sleep mode. Print two sides as quickly as one and scan both sides of the page at once. This MFP uses exceptionally low amounts of energy thanks to its advanced design and toner technology. In addition this MFP fits in tight places to boost performance in any workspace.
  • Perfect security and management
    Embedded features detect security threats and heal your MFP, protecting it from boot up to shutdown. Centralize control of your printing environment with HP Web Jetadmin and help build business efficiency.
  • More pages, performance, and protection
    Help ensure the quality you paid for with anti-fraud and cartridge authentication technology.
HP LaserJet Managed Flow MFP M527cm - multifunction printer - B/W
Multifunction printer
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
150000 pages
Recommended Monthly Volume
2000 - 15000 pages
Max Copying Speed
Up to 43 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 43 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Scanning
600 dpi
Display
8"
Original Size
76 x 127 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
100 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, recycled paper, heavy-weight paper, card stock, extra heavy-weight paper, light-weight paper, punched paper, preprinted paper
Standard Media Capacity
650 sheets
Max Media Capacity
2300 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
250 sheets
Stapler
Included
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB 2.0 host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, Hardware Integration Pocket, Hard Disk Drive Encryption, save to network folder, Foreign Interface Harness (FIH), HP EveryPage, HP High-Performance Secure Hard Disk, pull-out keyboard, automatic cutter, scan to SharePoint, scan to OCR, security lock slot
AC 230 V (50Hz)
48.2 cm x 49.6 cm x 49.7 cm
22.1 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
1-year warranty
Fax Type
Plain paper
Printing Technology
Laser - monochrome
150000 pages
2000 - 15000 pages
Display Diagonal Size
8"
Display Features
Touch screen, pivoting
AirPrint Enabled
Standard Memory
1.75 GB
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Up to 43 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
9999
Automatic Duplexing
Copying Features
ID Card Copy
Printing
Max Printing Speed
Up to 43 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF 1.7, PCL
Automatic Duplexing
First Print Out Time B/W
8.7 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
600 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Document & Media Handling
Min Original Size
76 x 127 mm
Max Original Size
Original Type
Sheets
100 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 216 x 297 mm, JIS B5 (182 x 257 mm), 76 x 127 mm, JIS B6 (128 x 182 mm), 102 x 148 mm, RA4 (215 x 305 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
650 sheets
Max Media Capacity
2300 sheets
100 sheets
250 sheets
ADF - 100 sheets size: 100 x 152 mm - Legal (216 x 356 mm) weight: 45 g/m² - 199 g/m² , Input tray - 100 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 199 g/m² , Input tray - 550 sheets size: 102 x 148 mm - 216 x 297 mm weight: 60 g/m² - 120 g/m² , Output tray - 250 sheets
Speed Details
Scanning: up to 45 ppm - B/W , Scanning: up to 45 ppm - colour , Printing: up to 38 ppm (A4) - B/W , Printing: up to 34 ipm (A4) - B/W duplex , Copying: up to 43 ppm (A4) - B/W
Finishing Equipment
Stapler
Included
2 x USB 2.0 host (internal) - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x modem - RJ-11
Security Protocols & Features
Kerberos, SSL, NDS Authentication over IP, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP, WPA2-Enterprise
Operating System Support
UNIX, Linux, Novell NetWare 6.5, Ubuntu Linux 10.04, Ubuntu Linux 11.10, Ubuntu Linux 12.04, Apple Mac OS X 10.8, Novell Open Enterprise Server, Fedora 17, Fedora 18, Ubuntu Linux 12.10, Apple Mac OS X 10.9, Fedora 19, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Ubuntu Linux 13.04, Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Ubuntu Linux 13.10, Linux Mint 13 - 17, Windows 10 (32/64-bits), SuSe Linux 12.2, SuSe Linux 12.3, SuSe Linux 13.1, Boss 3.0, Boss 5.0, Ubuntu Linux 14.10, Debian Linux 7.x, Fedora 20, Ubuntu Linux 14.04, Debian Linux 6.0.x
Software Included
Drivers & Utilities, HP Web Jetadmin, HP Update, HP Device Experience (DXP), HP Send Fax, HP Web Services Assist
AC 230 V (50Hz)
671 Watt
Power Consumption Standby
27.8 Watt
Power Consumption Sleep
3.2 Watt
Phone cable
Consumables Included
1 x Cartridge (black) - up to 9000 pages - HP 87A
CISPR 22 Class A, EMC, FIPS 140-2, IPv6 Ready, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN 55024:2010, EN 55022:2010 Class A, CISPR 22:2008
Security Slot Type
Kensington security slot
ENERGY STAR Certified
Blue Angel Compliant
Limited warranty - 1 year - on-site - response time: next business day
48.2 cm
49.6 cm
49.7 cm
22.1 kg
Shipping Width
73.4 cm
Shipping Depth
59.2 cm
Shipping Height
61.3 cm
Shipping Weight
27.52 kg
Sound Emission
54 dBA (operating)
15 °C
32.5 °C
30 - 70%
Functionality: Copier
Functionality: Fax
Functionality: Printer
Functionality: Scanner
Max Paper Size: A4 (210 x 297 mm)
Brand: HP
Price Range Ex VAT: 1000 - 1500
