Finish key tasks faster with a printer that starts right away and helps conserve energy. It produces more high-quality pages and multi-level device security helps protect from threats.
Accelerate your work and use less energy
Don't wait for documents and print your first page from energy-efficient sleep mode. This printer assures low energy use thanks to its great design and toner technology. Speed through jobs on a variety of media. Print two-sided documents without sacrificing performance slowdowns for duplexing. M506dnm printer also can be fitted in tight places and delivers quiet operation.
Perfect fleet security and management
Embedded features detect security threats and heal your printer, protecting it from boot up to shutdown. Protect sensitive data stored on the printer and in transit, using embedded security features. Centralize control of your print environment with HP Web Jetadmin and help build business efficiency.
More pages, performance, and protection
Help ensure the HP quality with anti-fraud and cartridge authentication technology.
Stay connected with secure mobile printing possibilities
Enable wireless direct printing from mobile devices without accessing the network. Easily access, print, and share resources with Ethernet.
Don't wait for documents and print your first page from energy-efficient sleep mode. This printer assures low energy use thanks to its great design and toner technology. Speed through jobs on a variety of media. Print two-sided documents without sacrificing performance slowdowns for duplexing. M506dnm printer also can be fitted in tight places and delivers quiet operation. -
Embedded features detect security threats and heal your printer, protecting it from boot up to shutdown. Protect sensitive data stored on the printer and in transit, using embedded security features. Centralize control of your print environment with HP Web Jetadmin and help build business efficiency. -
Help ensure the HP quality with anti-fraud and cartridge authentication technology. -
- HP LaserJet Managed M506dnm - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 11.8 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 43 ppm - B/W - A4 (210 x 297 mm) , Up to 34 ipm - B/W duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Image Enhancement Technology
- HP ProRes 1200 / HP FastRes 1200
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB 2.0 host
- AirPrint Enabled
- Processor
- 1.2 GHz
- RAM Installed (Max)
- 512 MB (1.5 GB)
- Language Simulation
- PCL 5, PostScript 3, PCL 6, PDF 1.7
- Media Type
- Envelopes, transparencies, labels, plain paper, bond paper, recycled paper, card stock, punched paper, preprinted paper
- Total Media Capacity
- 650 sheets
- Media Handling
- 100-sheet multipurpose tray, 550-sheet input tray
- Monthly Duty Cycle (max)
- 300000 pages
- Recommended Monthly Volume
- 2000 - 15000 pages
- Networking
- Print server
- Printer Features
- Hardware integration pocket, Instant-on Technology
- Power
- AC 230V
- System Requirements
- UNIX, Linux, Android, Microsoft Windows Vista (32/64 bits), Ubuntu 10.04, Microsoft Windows 7 (32/64 bits), Apple iOS, Ubuntu 11.10, Ubuntu 12.04, Windows 8 (32/64 bits), Apple MacOS X 10.8, Red Hat Fedora 17, Ubuntu 12.10, Windows 8.1 (32/64 bits), Apple MacOS X 10.9, Red Hat Fedora 18, Linux Mint 13, Ubuntu 13.04, Ubuntu 13.10, Ubuntu 14.04, Red Hat Fedora 19, Linux Mint 14, Linux Mint 15, Apple MacOS X 10.10, Windows 10 (32/64 bits), Red Hat Fedora 20, Linux Mint 16, Linux Mint 17, BOSS GNU/Linux 3.0, BOSS GNU/Linux 5.0, Ubuntu 14.10, Debian Linux 6.0.x, Debian Linux 7.x, SUSE Linux 12.2, SUSE Linux 12.3, SUSE Linux 13.1
- 1-year warranty
- 41.8 cm x 37.6 cm x 29.8 cm
- Printer Type
- Workgroup printer - laser - monochrome
- Localisation
Printer
- Print Speed
- Built-in Devices
- Status LCD, numeric key pad
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 8.5 sec
- Fonts Included
- 105 x TrueType , 92 x PostScript 3
- Printer Features
- Media Handling
- Processor
- 1.2 GHz
RAM
- 512 MB / 1.5 GB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 76 x 127 mm
- Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
- Media Weight
- 60 g/m² - 199 g/m²
- 650 sheets
- Media Feeders
- 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 199 g/m² , 1 x automatic - 550 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m²
- Max Media Capacity
- 2300 sheets
- Output Trays Capacity
- 250 sheets
Duty Cycle
- 300000 pages
- Networking
- Print server
- Network Controller Name
- HP Jetdirect
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, NDPS, NDS, HTTPS, TFTP, SLP
- Kerberos, SSL, NDS Authentication over IP, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP
- Connections
- 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B
- Consumables Included
- 1 x toner cartridge (black) - up to 6000 pages
- Security lock slot (cable lock sold separately), auto on/off
- EMC, CECP, IPv6 Ready, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN 55024:2010, EN 55022:2010 Class A, CISPR 22:2008
- Power Device
- Power supply - internal
- Voltage Required
- AC 230V
- Frequency Required
- 50 Hz
- 742 Watt
- Power Consumption Stand by
- 13.72 Watt
- Power Consumption Sleep
- 2.51 Watt
- Software Included
- HP Web JetAdmin, HP Software Update, HP SureSupply
- OS Required
- System Requirements Details
- Windows Vista/7/8/10 - HD 200 MB , Linux - HD 200 MB , MacOS X 10.7/10.8/10.9/10.10 - HD 1 GB
Environmental Standards
- Blue Angel
- ENERGY STAR
- Limited warranty - parts and labour - 1 year - on-site
- 15 °C
- 32.5 °C
- 30 - 70%
- Sound Emission (Operating)
- 54 dBA
- 41.8 cm
- 37.6 cm
- 29.8 cm
- 11.8 kg
- Width (Shipping)
- 49.7 cm
- Depth (Shipping)
- 39.8 cm
- Height (Shipping)
- 46.6 cm
- Weight (Shipping)
- 14.6 kg
