Fulfill workteam A3 printing and copying needs and provide send-to-e-mail from your MFP plus optional fax functionality, with a powerful tool that is affordable and easy to use and makes processes simple and efficient.
This MFP is extremely easy to use, install, manage and maintain with a new, intuitive control panel
Extremely simple to use, manage and maintain, this MFP's new, intuitive user interface is easy to navigate. It comes with an internal hard drive, in-built networking for reliable sharing, and original HP printing supplies that minimise interruptions. -
Enhance workteam performance with the A3 multifunction capabilities of this robust, affordable MFP
Easily add A3 multifunction capabilities to your office without stretching your budget. Accomplish more with A3 printing and copying at speeds of up to 35 ppm, optional fax and embedded send-to-e-mail functionality directly from your MFP. -
Experience familiar HP LaserJet reliability and quality for results you can always depend on
Get results you can count on with HP LaserJet quality and reliability. Create professional documents with flexible paper input. Enjoy worry-free operation with a 400 MHz processor capable of handling complex print jobs, and expandable memory.
- HP LaserJet M5035x MFP - multifunction printer - B/W
- Multifunction printer
- Copier Type
- Digital
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 200000 impressions
- Max Copying Speed
- Up to 35 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 35 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 300 x 300 dpi, 200 x 200 dpi
- Scanning
- 600 x 600 dpi
- Original Size
- 76 x 127 mm (min) - A3/Ledger (297 x 432 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 312 x 470 mm (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, recycled paper
- Standard Media Capacity
- 1100 sheets
- Max Media Capacity
- 2100 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 250 sheets
- Automatic Duplexing
- Yes (copying)
- Connection Availability
- Interface
- USB 2.0, LAN
- Power
- AC 110/230 V (50/60Hz)
- 74.3 cm x 74.3 cm x 99.7 cm
- 93 kg
- Microsoft Certification
- Works with Windows Vista
- Environmental Standards
- ENERGY STAR Qualified
- Copier Type
- Digital
- Fax Type
- Plain paper
- Laser - monochrome
- Interface
- USB 2.0, LAN
- Standard Memory
- 256 MB 256 MB
- Max Supported Memory
- 512 MB 512 MB
- Hard Disk Drive
- 40 GB
Copying
- Max Copying Speed
- Up to 35 ppm
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 1000
Printing
- Up to 35 ppm
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3, PDF 1.4
- Image Enhancement Technology
- HP FastRes 1200, HP ProRes 1200
- First Print Out Time B/W
- 10 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Interpolated Resolution
- 1200 dpi
- Grayscale Depth
- 8-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Fax Printing Resolution
- 300 x 300 dpi
- PC Faxing
Fax Machine Features
- Speed Dialing
- 100 station(s)
- Broadcast Transmission
- 100 stations
- Fax forwarding, automatic redialing
Document & Media Handling
- Min Original Size
- 76 x 127 mm
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Max Media Size
- A3
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 105 g/m²
- Supported Media Type
- 1100 sheets
- 2100 sheets
- 100 sheets
- 250 sheets
- Bypass tray - 100 sheets size: 76 x 127 mm - 312 x 470 mm weight: 60 g/m² - 120 g/m² , Input tray - 250 sheets size: 148 x 210 mm - 297 x 364 mm weight: 60 g/m² - 120 g/m² , Input tray - 250 sheets size: 148 x 210 mm - A3/Ledger (297 x 432 mm) weight: 60 g/m² - 120 g/m² , Input tray - 500 sheets size: 148 x 210 mm - A3/Ledger (297 x 432 mm) weight: 60 g/m² - 120 g/m² , ADF - 50 sheets size: 138 x 210 mm - A3/Ledger (297 x 432 mm) weight: 60 g/m² - 105 g/m² , Output tray - 250 sheets size: 76 x 127 mm - 312 x 470 mm weight: 60 g/m² - 120 g/m²
- Speed Details
- Printing: up to 35 ppm - B/W , Copying: up to 35 ppm - B/W
- 1 x USB 2.0 , 1 x LAN
- Network Protocols
- IPX/SPX, AppleTalk, DLC/LLC
- Operating System Support
- MS Windows XP, MS Windows 2000, MS Windows Server 2003, Apple MacOS X 10.2 or later, MS Windows XP Professional x64 Edition, Apple Mac OS X 10.3.9, Apple MacOS X 10.4 or later
- Software Included
- Drivers & Utilities
- Voltage Required
- 1265 Watt
- Power Consumption Standby
- 24 Watt
- Power Consumption Sleep
- 0.1 Watt
- Consumables Included
- 1 x toner cartridge (black) - up to 15000 pages
- Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
- FCC Class B certified, cUL, EN 61000-3-2, ICES-003, NOM, EN 61000-3-3, EN55024, EN55022 Class A, CISPR 22, FCC Part 68, FCC CFR47 Part 15, UL 60950-1, CSA C22.2 No. 60950-1-03
- ENERGY STAR Certified
- 74.3 cm
- 74.3 cm
- 99.7 cm
- 93 kg
- Shipping Width
- 141.8 cm
- Shipping Depth
- 90 cm
- Shipping Height
- 0.1 cm
- Shipping Weight
- 100 kg
- 15 °C
- 35 °C
- 20 - 80%
