HP LaserJet Enterprise M681f Colour Laser 27ppm Multifunction Printer
FREE WARRANTY EXTENSION - SEE PRODUCT FOR MORE DETAILS
Quicklinx: DZWGWS00 Mfr#: J8A11A#B19
This HP Colour LaserJet MFP with JetIntelligence combines exceptional performance and energy efficiency with professional-quality documents right when you need them – all while protecting your network with the industry's deepest security.
  • The world's most secure printing
    With HP Sure Start, each printer regularly checks its operating code and repairs itself from attempted hacks.Run-time intrusion detection continually monitors to detect and stop attacks, then automatically reboots.Centralise control of your printing environment with HP Web Jetadmin – and help build business efficiency.Give workgroups what they need to succeed. Easily choose and deploy over 180 HP and third-party solutions.
  • High speed performance meets energy efficiency
    Scanning is now faster than ever; duplex scan speeds up to 111 ipm. Scan to SharePoint and more.This MFP wakes up fast and prints your first page faster – in as quickly as 9 seconds (M681dh and M681f).This MFP uses exceptionally low amounts of energy thanks to its innovative design and toner technology.Paper handling options include a wheeled stand and 550-sheet input feeder for paper sizes 10.16 x 15.24 cm (4 x 6") to legal.
  • More
    ColorSphere3 toner formulation, combined with an automatic media sensor, help provide leading print quality.Original HP Toner cartridges with JetIntelligence supply 39% more pages per colour cartridge vs predecessor.Help retain the Original HP quality you paid for with anti-fraud and cartridge authentication technology.Spend less time replacing toner, and more on business. Choose high-yield toner cartridges.
HP LaserJet Enterprise MFP M681f - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
100000 pages
Recommended Monthly Volume
2000 - 14000 pages
Max Copying Speed
Up to 47 ppm (mono) / up to 47 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 203 x 392 dpi
Scanning
600 x 600 dpi
Display
8"
Original Size
216 x 863 mm (max)
Original Type
Sheets
Document Feeder Capacity
150 sheets
Media Size
76 x 127 mm (min) - 216 x 863 mm (max)
Media Type
Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, film, heavy-weight paper, card stock, extra heavy-weight paper, light-weight paper, glossy paper, punched paper, preprinted paper
Standard Media Capacity
1200 sheets
Max Media Capacity
1200 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
500 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB 2.0 host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, scan to network, Hardware Integration Pocket, Hard Disk Drive Encryption, save to network folder, automatic paper sensor, HP High-Performance Secure Hard Disk, Instant-on Technology, scan to SharePoint, HP Auto-On/Auto-Off Technology
AC 230 V (50Hz)
65.7 cm x 65.7 cm x 110.8 cm
61.5 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
1-year warranty
Fax Type
Plain paper
Printing Technology
Laser - colour
100000 pages
2000 - 14000 pages
Display Diagonal Size
8"
Display Features
Touch screen
AirPrint Enabled
Max Supported Memory
2.5 GB
Hard Disk Drive
320 GB
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
9999
Automatic Duplexing
Copying Features
ID Card Copy, Manual Color Adjustment, collation copy, Job Build, Edge Erase, blank page skipping, Book Copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF 1.7, URF
Image Enhancement Technology
HP ProRes 1200, HP ImageREt 3600, Pantone Calibrated
Automatic Duplexing
First Print Out Time B/W
9 sec
First Print Out Time Colour
9 sec
Scanning
Scan Element
CCD
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 500 pages
Fax Printing Resolution
400 x 400 dpi
PC Faxing
Fax Machine Features
Speed Dialing
1000 station(s)
Broadcast Transmission
210 stations
Remote Fax Retrieval (Polling)
Fax forwarding, automatic redialing, junk fax barrier, LAN fax, auto reduction, fax polling, fax archiving
Document & Media Handling
Max Original Size
216 x 863 mm
Original Type
Sheets
150 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
45 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 216 x 297 mm, C5 (162 x 229 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), 76 x 127 mm, 216 x 863 mm, 99 x 148 mm, Oficio (216 x 343 mm), 216 x 356 mm, JIS B6 (128 x 182 mm), DL (210 x 99 mm), RA4 (215 x 305 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
1200 sheets
Max Media Capacity
1200 sheets
100 sheets
500 sheets
ADF - 150 sheets size: 68 x 147 mm - 216 x 863 mm weight: 45 g/m² - 199 g/m² , 2 x input tray - 500 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Bypass tray - 100 sheets size: 101.6 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Output tray - 500 sheets
Speed Details
Printing: up to 74 ppm (A5) - B/W , Printing: up to 47 ppm (A4) - B/W normal , Printing: up to 74 ppm (A5) - colour normal , Printing: up to 47 ppm (A4) - colour normal , Printing: up to 47 ppm (A4) - B/W duplex , Printing: up to 47 ppm (A4) - colour duplex , Copying: up to 47 ppm (A4) - B/W normal , Copying: up to 47 ppm (A4) - colour normal , Copying: up to 47 ppm (A4) - B/W duplex , Copying: up to 50 ppm (Letter A) - colour normal , Copying: up to 47 ppm (A4) - colour duplex , Scanning: up to 69 ppm (A4) - B/W normal , Scanning: up to 69 ppm (A4) - colour normal , Scanning: up to 111 ipm (A4) - B/W normal , Scanning: up to 111 ipm (A4) - colour normal
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 2 x USB 2.0 host - 4 pin USB Type A , 1 x modem - RJ-11
Security Protocols & Features
Kerberos, LDAP, SSL, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP
Operating System Support
UNIX, Novell NetWare 6.5, MS Windows Server 2008 R2, Red Hat Enterprise Linux 6, Ubuntu Linux 12.04, MS Windows Server 2012, Novell Open Enterprise Server, Android, MS Windows Server 2008 R2 x64 Edition SP1, MS Windows Server 2012 R2, MS Windows Server 2003 (32/64-bits), MS Windows Server 2003 R2 (32/64-bits), MS Windows Server 2008 SP2 (32/64-bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Boss 5.0, Debian Linux 7.x, Linux Mint 17, Ubuntu Linux 14.04, Red Hat Enterprise Linux 7, Apple Mac OS X 10.11, MS Windows Vista 32-bit Edition, Novell NetWare 6.5 SP8, Novell Open Enterprise Server 11 SP1, Novell Open Enterprise Server 2, Debian Linux 8.0, Novell Open Enterprise Server 11, macOS 10.12, Linux Mint 17.1, Linux Mint 17.2, Linux Mint 18, Linux Mint 17.3, SuSe Linux 13.2, Ubuntu Linux 15.10, Ubuntu Linux 16.04, Ubuntu Linux 16.10, Debian Linux 8.1, Debian Linux 8.2, Debian Linux 8.3, Debian Linux 8.4, Debian Linux 8.5, Debian Linux 8.6, Fedora Linux 22, Fedora Linux 23, Fedora Linux 24
Software Included
Drivers & Utilities, HP Web Jetadmin, HP Device Experience (DXP), HP Connected
AC 230 V (50Hz)
900 Watt
Power Consumption Sleep
0.9 Watt
First Copy Out Time B/W
6.5 sec
First Copy Out Time Colour
7.2 sec
UL, cUL, GS, EMC, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN 62479:2010, EMC 2004/108/EC, LVD 2006/95/EC, 21 CFR 1040.10, 21 CFR 1040.11, ETSI ES203 021, EN 55024:2010, EN 55022:2010 Class A, CISPR 22:2008, EN 60950-1:2006+A1:2010+A2:2013+A11:2009+A12:2011, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62479:2010, CAN/CSA C22.2 No. 60950-1-07 Second Edition 2011-12, EN 60825-1:2007, R&TTE Directive 1999/5/EC, IEC 60825-1:2007 Class 1
ENERGY STAR Certified
Blue Angel Compliant
Limited warranty - 1 year - on-site - response time: next business day
65.7 cm
65.7 cm
110.8 cm
61.5 kg
Shipping Width
85.6 cm
Shipping Depth
76 cm
Shipping Height
151.9 cm
Shipping Weight
81.1 kg
Sound Emission
32 dBA (idle) / 58 dBA (operating)
15 °C
30 °C
10 - 80%
