HP LaserJet Enterprise M632h MFP Colour Printer
Quicklinx: DC70WS00 Mfr#: J8J70A#B19
Type: Printer / copier / scanner
Functionality: Copier, Printer, Scanner
Max Paper Size: A4 (210 x 297 mm), Legal (216 x 356 mm)
Hurry, only 2 left in stock!
£1,679.60 ex VAT
£2,015.52 inc VAT
This HP LaserJet MFP with JetIntelligence combines exceptional performance and energy efficiency with professional-quality documents right when you need them – all while protecting your network from attacks with the industry's deepest security.
HP LaserJet Enterprise MFP M632h - multifunction printer - B/W
Multifunction printer
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
300000 pages
Recommended Monthly Volume
5000 - 30000 pages
Max Copying Speed
Up to 61 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 61 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Scanning
600 x 600 dpi
Display
8"
Original Size
68 x 148 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
100 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, heavy-weight paper, card stock, extra heavy-weight paper, light-weight paper, punched paper
Standard Media Capacity
650 sheets
Max Media Capacity
3750 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
500 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB 2.0 host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, Hardware Integration Pocket, Hard Disk Drive Encryption, save to network folder, Foreign Interface Harness (FIH)
AC 230 V (50/60Hz)
51.2 cm x 55.8 cm x 64 cm
33.2 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Printing Technology
Laser - monochrome
300000 pages
5000 - 30000 pages
Display Diagonal Size
8"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
1.5 GB
Max Supported Memory
2 GB
Hard Disk Drive
320 GB
Copying
Max Copying Speed
Up to 61 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
9999
Automatic Duplexing
Printing
Max Printing Speed
Up to 61 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, PDF 1.7, PCL 5
Image Enhancement Technology
HP FastRes 1200
Automatic Duplexing
Scanning
Scan Element
CCD
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Min Original Size
68 x 148 mm
Max Original Size
Original Type
Sheets
100 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
200 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76 x 127 mm, 127 x 177.8 mm, Oficio (216 x 343 mm), 216 x 356 mm, 127 x 203.2 mm, JIS B6 (128 x 182 mm), RA4 (215 x 305 mm)
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
650 sheets
Max Media Capacity
3750 sheets
100 sheets
500 sheets
ADF - 150 sheets size: 68 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , Input tray - 500 sheets size: 148 x 210 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , Bypass tray - 100 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m² , Output tray - 500 sheets
Speed Details
Printing: up to 61 ppm (A4) - B/W normal , Printing: up to 65 ppm (Letter A) - B/W normal , Printing: up to 50 ppm (A4) - B/W duplex , Printing: up to 53 ppm (Letter A) - B/W duplex , Copying: up to 61 ppm (A4) - B/W normal , Copying: up to 65 ppm (Letter A) - B/W normal , Copying: up to 50 ppm (A4) - B/W duplex , Copying: up to 53 ppm (Letter A) - B/W duplex
1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
Kerberos, LDAP, SSL, TLS, IPsec, 802.1x, EAP-TLS, PEAP
Operating System Support
Sun Solaris 8, Sun Solaris 9, MS Windows 7, MS Windows XP SP3, Ubuntu Linux 8.10, Ubuntu Linux 9.04, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), SuSe Linux 10.3, HP-UX 11.0, Ubuntu Linux 9.10, Ubuntu Linux 10.04, Fedora 10, Fedora 9, Fedora 11, Fedora 12, Apple Mac OS X 10.7, Debian Linux 5.0, Red Hat Enterprise Linux 5, SuSe Linux 11.0, SuSe Linux 11.1, SuSe Linux 11.2, Debian Linux 5.0.1, Debian Linux 5.0.2, Debian Linux 5.0.3, Ubuntu Linux 8.04, Apple Mac OS X 10.8, Windows 8, Windows 8 64-bit, MS Windows XP 64-bit Edition SP3 or later, Windows 8.1, Apple Mac OS X 10.9, Windows 8.1 64-bit, Linux 9.4, Linux 9.5, Ubuntu Linux 8.04.1, Ubuntu Linux 8.04.2
Software Included
Drivers & Utilities, HP Web Jetadmin
AC 230 V (50/60Hz)
FCC Class A certified, UL, CISPR 22 Class A, cUL, GS, ICES-003, EMC, Laser Class 1, FCC CFR47 Part 15, LVD, EN 61000-3-3:2008, EN 60825-1:2001, IEC 62479, IEC 60825-1:2007, EN 62479:2010, IEC 60950-1:2005, EN 55024:2010, EN 55022:2010 Class A, EN 60950-1:2006 + A11:2009 + A1:2010 + A12:2011, EN 61000-3-2:2006 + A1:2009 + A2:2009
ENERGY STAR Certified
Limited warranty - 1 year - on-site - response time: next business day
51.2 cm
55.8 cm
64 cm
33.2 kg
Shipping Width
70 cm
Shipping Depth
63.9 cm
Shipping Height
78.5 cm
Shipping Weight
38 kg
Sound Emission
60 dBA (operating)
15 °C
27 °C
10 - 80%
Functionality: Printer
Functionality: Scanner
Brand: HP
Price Range Ex VAT: 1500+
