This HP LaserJet MFP with JetIntelligence combines exceptional performance and energy efficiency with professional-quality documents right when you need them – all while protecting your network from attacks with the industry's deepest security.
Take the guesswork out of fleet management
Centrally monitor and control your printers with HP Web Jetadmin. -
Eliminate the wait from your workday
This printer wakes up fast and prints your first page as quickly as 7.9 seconds.
- HP LaserJet Enterprise MFP M632h - multifunction printer - B/W
- Multifunction printer
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 300000 pages
- Recommended Monthly Volume
- 5000 - 30000 pages
- Max Copying Speed
- Up to 61 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 61 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Scanning
- 600 x 600 dpi
- Display
- 8"
- Original Size
- 68 x 148 mm (min) - Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, heavy-weight paper, card stock, extra heavy-weight paper, light-weight paper, punched paper
- Standard Media Capacity
- 650 sheets
- Max Media Capacity
- 3750 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 500 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB 2.0 host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, Hardware Integration Pocket, Hard Disk Drive Encryption, save to network folder, Foreign Interface Harness (FIH)
- Power
- AC 230 V (50/60Hz)
- 51.2 cm x 55.8 cm x 64 cm
- 33.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Laser - monochrome
- 300000 pages
- Display Diagonal Size
- 8"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 1.5 GB
- Max Supported Memory
- 2 GB
- Hard Disk Drive
- 320 GB
Copying
- Max Copying Speed
- Up to 61 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 9999
Printing
- Up to 61 ppm
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PDF 1.7, PCL 5
- Image Enhancement Technology
- HP FastRes 1200
Scanning
- Scan Element
- CCD
- Optical Resolution
- 600 x 600 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Document & Media Handling
- Min Original Size
- 68 x 148 mm
- Max Original Size
- Original Type
- Sheets
- 100 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 200 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76 x 127 mm, 127 x 177.8 mm, Oficio (216 x 343 mm), 216 x 356 mm, 127 x 203.2 mm, JIS B6 (128 x 182 mm), RA4 (215 x 305 mm)
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
- 650 sheets
- 3750 sheets
- 100 sheets
- 500 sheets
- ADF - 150 sheets size: 68 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , Input tray - 500 sheets size: 148 x 210 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , Bypass tray - 100 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m² , Output tray - 500 sheets
- Speed Details
- Printing: up to 61 ppm (A4) - B/W (ISO) , Printing: up to 65 ppm (Letter A) - B/W (ISO) , Printing: up to 50 ppm (A4) - B/W duplex , Printing: up to 53 ppm (Letter A) - B/W duplex , Copying: up to 61 ppm (A4) - B/W (ISO) , Copying: up to 65 ppm (Letter A) - B/W (ISO) , Copying: up to 50 ppm (A4) - B/W duplex , Copying: up to 53 ppm (Letter A) - B/W duplex
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Kerberos, LDAP, SSL, TLS, IPsec, 802.1x, EAP-TLS, PEAP
- Operating System Support
- Sun Solaris 8, Sun Solaris 9, MS Windows 7, MS Windows XP SP3, Ubuntu Linux 8.10, Ubuntu Linux 9.04, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), SuSe Linux 10.3, HP-UX 11.0, Ubuntu Linux 9.10, Ubuntu Linux 10.04, Fedora 10, Fedora 9, Fedora 11, Fedora 12, Apple Mac OS X 10.7, Debian Linux 5.0, Red Hat Enterprise Linux 5, SuSe Linux 11.0, SuSe Linux 11.1, SuSe Linux 11.2, Debian Linux 5.0.1, Debian Linux 5.0.2, Debian Linux 5.0.3, Ubuntu Linux 8.04, Apple Mac OS X 10.8, Windows 8, Windows 8 64-bit, MS Windows XP 64-bit Edition SP3 or later, Windows 8.1, Apple Mac OS X 10.9, Windows 8.1 64-bit, Linux 9.4, Linux 9.5, Ubuntu Linux 8.04.1, Ubuntu Linux 8.04.2
- Software Included
- Drivers & Utilities, HP Web Jetadmin
- Voltage Required
- FCC Class A certified, UL, CISPR 22 Class A, cUL, GS, ICES-003, EMC, Laser Class 1, FCC CFR47 Part 15, LVD, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN 60825-1:2001, IEC 62479, IEC 60825-1:2007, EN 62479:2010, IEC 60950-1:2005, EN 55024:2010, EN 55022:2010 Class A, EN 60950-1:2006+A11:2009+A1:2010+A12:2011
- ENERGY STAR Certified
- Limited warranty - 1 year - on-site - response time: next business day
- 51.2 cm
- 55.8 cm
- 64 cm
- 33.2 kg
- Shipping Width
- 70 cm
- Shipping Depth
- 63.9 cm
- Shipping Height
- 78.5 cm
- Shipping Weight
- 38 kg
- Sound Emission
- 60 dBA (operating)
- 15 °C
- 27 °C
- 10 - 80%
Ink (3)
HP 37X - High Yield Black Laserjet Toner Cartridge | In Stock | £205.23 |
HP 37A Black Original Laserjet Toner | In Stock | £137.42 |
HP 37Y Extra High Yield Black Original LaserJet Toner Cartridge | In Stock | £297.90 |
Other bundles (1)
HP Foreign Interface Harness (FIH) | In Stock | £77.37 |
