Rely on a full-featured HP Enterprise MFP that accelerates productivity and streamlines digital workflow, safeguards business data and documents with a robust suite of top-flight security features and offers simple, efficient mobile printing.
Get powerful performance to enhance workflow
Finish faster – without missing a page – using single-pass, dual-head scanning and the automatic document feeder.Preview and edit scans, adjust images, and launch standard processes, all at the 20.3 cm colour touchscreen.Keep productivity high – choose a robust MFP that can print up to 28,000 pages per month at a speed of 57 ppm (A4).Tackle high volume printing with a paper capacity of up to 3,100 sheets, high yield toner cartridge, automatic job sorting and finishing, using the 3-bin stapling mailbox. -
Protect your business – now and in the future
Safeguard and manage centrally your printing fleet with the HP Imaging and Printing Security Center and HP Web Jetadmin.Confidently safeguard the sensitive data sent to your MFP with the encrypted hard drive.Secure your investment – depend on an MFP that can expand with your business, whenever solutions advance.Safeguard security keys, passwords and certificates with the optional HP Trusted Platform Module. -
Enjoy easy and secure mobile printing
Enjoy mobile printing at a touch: enable optional touch-to-print and touch-to-authenticate convenience from mobile devices.Enable secure peer-to-peer direct-access mobile printing without connecting to the corporate network.Easily print from a variety of smartphones and tablets – generally no setup or apps required.Pull print jobs from your pocket – walk up and print or scan from your USB drive.
- HP LaserJet Enterprise MFP M630f - multifunction printer - B/W
- Multifunction printer
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 250000 pages
- Recommended Monthly Volume
- 5000 - 28000 pages
- Max Copying Speed
- Up to 57 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 57 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 300 x 300 dpi, 200 x 100 dpi
- Scanning
- 600 x 600 dpi
- Display
- 8"
- Original Size
- 68 x 148 mm (min) - Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, heavy-weight paper, card stock, extra heavy-weight paper, light-weight paper, punched paper
- Standard Media Capacity
- 1100 sheets
- Max Media Capacity
- 1100 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 500 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, scan to folder
- Power
- AC 230 V (50Hz)
- 73.7 cm x 64.3 cm x 111 cm
- 73.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Laser - monochrome
- 250000 pages
- Display Diagonal Size
- 8"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 1.5 GB
- Max Supported Memory
- 2 GB
- Hard Disk Drive
- 320 GB
Copying
- Max Copying Speed
- Up to 57 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 9999
Printing
- Up to 57 ppm
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PDF 1.7, PCL 5
- Image Enhancement Technology
- HP FastRes 1200, HP ProRes 1200
- First Print Out Time B/W
- 8.5 sec
Scanning
- Scan Element
- CCD
- Optical Resolution
- 600 x 600 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- PC Faxing
Fax Machine Features
- Speed Dialing
- 100 station(s)
- Fax forwarding, automatic redialing, junk fax barrier, auto reduction, poll receive
Document & Media Handling
- Min Original Size
- 68 x 148 mm
- Max Original Size
- Original Type
- Sheets
- 100 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 200 g/m²
- Supported Media Type
- Supported Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 76 x 127 mm, Oficio (216 x 343 mm), 216 x 356 mm, JIS B6 (128 x 182 mm), RA4 (215 x 305 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
- 1100 sheets
- 1100 sheets
- 100 sheets
- 500 sheets
- ADF - 100 sheets size: 68 x 148 mm - Legal (216 x 356 mm) , 2 x input tray - 500 sheets size: 148 x 210 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , Bypass tray - 100 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m²
- Speed Details
- Printing: up to 57 ppm (A4) - B/W , Copying: up to 57 ppm (A4) - B/W , Scanning: up to 60 ppm - B/W , Scanning: up to 45 ppm - colour , Scanning: up to 60 ppm - B/W duplex , Scanning: up to 44 ppm - colour duplex , Printing: up to 39 ppm (A4) - B/W duplex
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A , 1 x modem - RJ-11
- SSL, TLS, IPsec, EAP-TLS, PEAP
- Operating System Support
- Sun Solaris 8, Sun Solaris 9, MS Windows 7, MS Windows XP SP3, Ubuntu Linux 8.10, Ubuntu Linux 9.04, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), SuSe Linux 10.3, HP-UX 11.0, Ubuntu Linux 9.10, Ubuntu Linux 10.04, Fedora 10, Fedora 9, Fedora 11, Fedora 12, Apple Mac OS X 10.7, Debian Linux 5.0, Red Hat Enterprise Linux 5, SuSe Linux 11.0, SuSe Linux 11.1, SuSe Linux 11.2, Debian Linux 5.0.1, Debian Linux 5.0.2, Debian Linux 5.0.3, Ubuntu Linux 8.04, Apple Mac OS X 10.8, Windows 8, Windows 8 64-bit, MS Windows XP 64-bit Edition SP3 or later, Windows 8.1, Apple Mac OS X 10.9, Windows 8.1 64-bit, Linux 9.4, Linux 9.5, Ubuntu Linux 8.04.1, Ubuntu Linux 8.04.2
- Software Included
- Drivers & Utilities, HP Web Jetadmin
- Voltage Required
- AC 230 V (50Hz)
- 970 Watt
- Power Consumption Sleep
- 6.5 Watt
- Included Accessories
- Phone cable
- EN 61000-3-2, EN55022, EN 61000-3-3, EN55024, CISPR 22, EMC
- ENERGY STAR Certified
- Limited warranty - 1 year - on-site
- 73.7 cm
- 64.3 cm
- 111 cm
- 73.5 kg
- Shipping Width
- 85.6 cm
- Shipping Depth
- 76 cm
- Shipping Height
- 147.4 cm
- Shipping Weight
- 93.58 kg
- Sound Emission
- 58 dBA (operating)
- 15 °C
- 32.5 °C
- 10 - 80%
HP 81A Black Original LaserJet Toner Cartridge | In Stock | £150.94 |
HP 81X High Yield Black Original LaserJet Toner Cartridge | In Stock | £249.76 |
