This HP LaserJet Printer with JetIntelligence combines exceptional performance and energy efficiency with professional-quality documents right when you need them – all while protecting your network from attacks with the industry's deepest security.
Take the guesswork out of fleet management
Centrally monitor and control your printers with HP Web Jetadmin. -
Eliminate the wait from your workday
This printer wakes up fast and prints your first page as quickly as 7.9 seconds.
- HP LaserJet Enterprise M609x - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 26.3 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), RA4 (215 x 305 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 71 ppm - B/W - A4 (210 x 297 mm) , Up to 75 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 58 ppm - B/W duplex - A4 (210 x 297 mm) , Up to 62 ppm - B/W duplex - ANSI A (Letter) (216 x 279 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Image Enhancement Technology
- HP FastRes 1200
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, Bluetooth, Wi-Fi(n), USB 2.0 host
- AirPrint Enabled
- Preview Screen Size
- 4.3"
- Processor
- 1.2 GHz
- RAM Installed (Max)
- 512 MB (1.5 GB) - DDR3 SDRAM - DIMM 90-pin
- Language Simulation
- PCL 5, PostScript 3, PCL 6, PDF 1.7
- Media Type
- Envelopes, transparencies, labels, plain paper, bond paper, recycled paper, card stock, light-weight paper, punched paper, preprinted paper
- Total Media Capacity
- 1200 sheets
- Media Handling
- 100-sheet multipurpose tray, 2x 550-sheet input trays
- Monthly Duty Cycle (max)
- 300000 pages
- Recommended Monthly Volume
- 5000 - 30000 pages
- Networking
- Print server
- Printer Features
- Hardware integration pocket, Instant-on Technology, JetIntelligence Cartridge Technology
- Power
- AC 230V
- System Requirements
- UNIX, Microsoft Windows Vista (32-bit versions), Android, Red Hat Enterprise Linux 6, Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Microsoft Windows XP (32-bit) SP3, Windows 8.1 (32/64 bits), Ubuntu Linux 12.04, Red Hat Enterprise Linux 7, Apple OS X 10.10 Yosemite, Windows 10 (32/64 bits), Linux Mint 17, BOSS GNU/Linux 5.0, Debian Linux 7.x, Ubuntu Linux 14.04, Apple OS X 10.11 El Capitan, Debian Linux 8.x, Linux Mint 17.1, Linux Fedora, Apple macOS Sierra 10.12 or later, Linux Mint 17.2, Linux Mint 17.3, SUSE Linux 13.2, Linux Mint 18, SUSE Linux 42.1, Ubuntu Linux 15.10, Ubuntu Linux 16.04, Ubuntu Linux 16.10
- 1-year warranty
- 43.1 cm x 46.6 cm x 50.5 cm
- Printer Type
- Workgroup printer - laser - monochrome
- Localisation
Printer
- Print Speed
- Built-in Devices
- 4.3 inch LCD touch screen
- 4.3"
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- HP FastRes 1200
- PostScript Support
- Standard
- Fonts Included
- 105 x TrueType , 92 x PostScript 3
- Printer Features
- Media Handling
- Processor
- 1.2 GHz
RAM
- 512 MB / 1.5 GB (max)
- Technology / Form Factor
- Slots Qty
- 1
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76 x 127 mm, 127 x 177.8 mm, 215.9 x 330.2 mm, JIS B6 (128 x 182 mm), RA4 (215 x 305 mm)
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
- Media Weight
- 60 g/m² - 199 g/m²
- 1200 sheets
- Media Feeders
- 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 199 g/m² , 2 x automatic - 550 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m²
- Max Media Capacity
- 4400 sheets
- Output Trays Capacity
- 500 sheets
Duty Cycle
- 300000 pages
- Networking
- Print server
- Network Controller Name
- HP Jetdirect
- Remote Management Protocol
- SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, IPP 2.0, SLP
- Kerberos, LDAP, SSL, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP
- Connections
- 1 x USB 2.0 , 2 x USB 2.0 host , 1 x Gigabit LAN - RJ-45
- FCC Class A certified, UL, cUL, GS, FCC CFR47 Part 15, Directive 2006/95/EC, EN 62479:2010, 21 CFR 1040.10, 21 CFR 1040.11, IEC 62479:2010, CAN/CSA C22.2 No. 60950-1-07 Second Edition 2011-12, EN 60825-1:2007, IEC 60825-1:2007 Class 1
- Security Slot Type
- Kensington security slot
- Power Device
- Power supply - internal
- Voltage Required
- AC 230V
- Frequency Required
- 50/60 Hz
- OS Required
Environmental Standards
- Blue Angel
- ENERGY STAR
- Limited warranty - 1 year - on-site - response time: next business day
- 15 °C
- 32.5 °C
- 10 - 90%
- Sound Emission (Operating)
- 55 dBA
- 43.1 cm
- 46.6 cm
- 50.5 cm
- 26.3 kg
- Width (Shipping)
- 76.2 cm
- Depth (Shipping)
- 59.3 cm
- Height (Shipping)
- 51.1 cm
- Weight (Shipping)
- 33.8 kg
Ink (5)
HP 37X - High Yield Black Laserjet Toner Cartridge | In Stock | £205.23 |
HP 37A Black Original Laserjet Toner | In Stock | £139.01 |
HP L0H25A Service-Kit, 225K pages | In Stock | £272.66 |
HP 37Y Extra High Yield Black Original LaserJet Toner Cartridge | In Stock | £291.31 |
HP Glossy Laser Paper 150GSM 150 SHT/A4 | In Stock | £12.37 |
Other bundles (1)
HP Media Tray / Feeder 550 sheets For LaserJet | In Stock | £220.69 |
