Your basket is empty
HP LaserJet Enterprise M604n Printer
Quicklinx: B9KJWS00 Mfr#: E6B67A#B19
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
HP LaserJet Enterprise M604n - printer - monochrome - laser
Printer Type
Workgroup printer - laser - monochrome
22.6 kg
English, German, French, Italian, Spanish / Europe
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 50 ppm - B/W - A4 (210 x 297 mm) , Up to 52 ppm - B/W - ANSI A (Letter) (216 x 279 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Image Enhancement Technology
HP ImageRet 3600 / HP ProRes 1200
Automatic Duplexing
Optional
USB 2.0, Gigabit LAN, USB 2.0 host
AirPrint Enabled
1.2 GHz
RAM Installed (Max)
512 MB (1 GB) - SDRAM - DIMM 90-pin
Flash Memory Installed (Max)
4 GB
Language Simulation
PCL 5E, PostScript 3, PCL 6, PDF 1.7
Media Type
Envelopes, transparencies, labels, plain paper, bond paper, recycled paper, card stock, light-weight paper, punched paper, preprinted paper
Total Media Capacity
600 sheets
Media Handling
100-sheet multipurpose tray, 500-sheet input tray
Monthly Duty Cycle (max)
175000 pages
Recommended Monthly Volume
5000 - 13000 pages
Print server
Printer Features
Hardware integration pocket, Instant-on Technology
AC 230V
UNIX, HP-UX 10.20, SunSoft Solaris 2.5 or later, IBM AIX 3.2.5 or later, HP-UX 11.x, HP-UX 11i, Microsoft Windows Server 2003 Standard x64 Edition, Microsoft Windows Server 2003 Enterprise x64 Edition, Citrix Presentation Server 4.5, Microsoft Windows Server 2008 Enterprise x64 Edition, Citrix MetaFrame Presentation Server 3.0, Citrix Presentation Server 4.0, Microsoft Windows XP SP3, Android, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2003 R2 (32/64-bits), Ubuntu 10.04, Microsoft Windows 7 (32/64 bits), Apple MacOS X 10.7 Lion, Microsoft Windows Server 2008 (32/64-bits) SP2, Apple iOS, Citrix XenApp 5, Citrix XenApp 6, Ubuntu 11.10, Ubuntu 12.04, Red Hat Linux 7.x or later, SuSE Linux 8.x or later, Windows 8 (32/64 bits), openSUSE 12.2, Apple MacOS X 10.8, Red Hat Fedora 17, Microsoft Windows Server 2008 R2 (64-bits), Ubuntu 12.10, Citrix XenApp 6.5, Windows 8.1 (32/64 bits), Apple MacOS X 10.9, Microsoft Windows Server 2008 R2 SP1 (64-bits), Red Hat Fedora 18, openSUSE 12.3, Linux Mint 13, Ubuntu 13.04, Ubuntu 13.10, Ubuntu 14.04, Red Hat Fedora 19, Linux Mint 14, Linux Mint 15, Apple MacOS X 10.10, openSUSE 13.1, Microsoft Windows Server 2012 (64-bit), Microsoft Windows Server 2012 R2 (64-bit), Windows 10 (32/64 bits), Red Hat Fedora 20, Linux Mint 16, Linux Mint 17, BOSS GNU/Linux 3.0, BOSS GNU/Linux 5.0, Ubuntu 14.10, Debian Linux 6.0.x, Debian Linux 7.x, Microsoft Windows Server 2003 Standard Edition (32-bit), Microsoft Windows Server 2003 Enterprise Edition (32-bit), Citrix XenDesktop 5.6 (32/64 bits), Novell NetWare 6.5 SP8
42.5 cm x 45.1 cm x 39.9 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
AirPrint Enabled
1200 x 1200 dpi
Automatic Duplexing
Optional
PostScript Support
Standard
First Print Out Time B/W
7.5 sec
Language Simulation
Fonts Included
105 x TrueType , 92 x PostScript 3
Printer Features
Media Handling
1.2 GHz
RAM
RAM Installed (Max)
512 MB / 1 GB (max)
Technology / Form Factor
SDRAM - DIMM 90-pin
Slots Qty
1
Empty Slots
1
Flash Memory
Flash Memory
4 GB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76 x 127 mm, 127 x 177.8 mm, 215.9 x 330.2 mm, JIS B6 (128 x 182 mm)
Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
Media Weight
60 g/m² - 200 g/m²
600 sheets
Media Feeders
1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m² , 1 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m²
Max Media Capacity
3600 sheets
Output Trays Capacity
600 sheets
Duty Cycle
175000 pages
5000 - 13000 pages
Print server
Network Controller Name
HP Jetdirect
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, NDS, HTTPS, TFTP, IPPS, SLP
Security Protocols & Features
Kerberos, LDAP, Apple Bonjour, IPsec, 802.1x, EAP-TLS, PEAP
1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 10500 pages ISO/IEC 19752
FCC Class A certified, UL, cUL, GS, Laser Class 1, FCC CFR47 Part 15, EN 60825-1, CECP, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 60825-1:2007, EN 62479:2010, EN55024:2010, EMC 2004/108/EC, IEC 60950-1:2005, EN60950-1:2006 + A11:2009 + A1:2010 + A12:2011, ICES-003 issue 4, EN 55022:2010 Class A, CISPR 22:2008
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
720 Watt
Power Consumption Sleep
3.9 Watt
Software Included
Drivers & Utilities
Environmental Standards
Blue Angel
15 °C
32 °C
10 - 80%
Sound Emission (Idle)
28 dBA
Sound Emission (Operating)
56 dBA
42.5 cm
45.1 cm
39.9 cm
22.6 kg
Width (Shipping)
58.9 cm
Depth (Shipping)
54.7 cm
Height (Shipping)
49.9 cm
Weight (Shipping)
25.5 kg
B9KJ HP 81A Black Original LaserJet Toner Cartridge In Stock £128.94
