Finish tasks faster with an MFP that starts right away and helps conserve energy. Multi-level device security helps protect from threats. Original HP Toner cartridges with JetIntelligence and this printer produce more high-quality pages.
Fast wake-up and print
Print the first page from sleep mode as fast as 8.7 seconds. -
Fast two-sided printing
Print two-sided documents as fast as 36 ipm (images per minute). -
Get more pages, performance, and protection out of your printer – using Original HP Toner cartridges with JetIntelligence. -
Keep fleet security covered
Protect sensitive business data with embedded and optional HP JetAdvantage security solutions. -
Low energy use
This printer is optimised for low energy consumption. -
Improve uptime with added input capacity
Save time by refilling paper less often with an optional paper input tray.
- HP LaserJet Enterprise MFP M527dn - multifunction printer - B/W
- Multifunction printer
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 150000 pages
- Recommended Monthly Volume
- 2000 - 7500 pages
- Max Copying Speed
- Up to 43 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 43 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Scanning
- 600 dpi
- Display
- 8"
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, card stock, punched paper, preprinted paper
- Standard Media Capacity
- 650 sheets
- Max Media Capacity
- 2300 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 250 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB 2.0 host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, Internet faxing, scan to e-mail, save to network folder, Instant-on Technology, scan to FTP, security lock slot
- Power
- AC 230 V (50Hz)
- 48.2 cm x 49.6 cm x 49.7 cm
- 21.9 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- Laser - monochrome
- 150000 pages
- 2000 - 7500 pages
- Display Diagonal Size
- 8"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Supported Flash Memory
- USB flash drive
Copying
- Max Copying Speed
- Up to 43 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
Printing
- Up to 43 ppm
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PDF 1.7, PCL 5
- Image Enhancement Technology
- HP ProRes 1200
- First Print Out Time B/W
- 5.7 sec
Scanning
- Optical Resolution
- 600 dpi
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 100 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 199 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 216 x 297 mm, 101.6 x 152.4 mm, 76 x 127 mm, Oficio (216 x 343 mm), 215.9 x 330.2 mm, 127 x 203.2 mm, 102 x 148 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
- 650 sheets
- 2300 sheets
- 100 sheets
- 250 sheets
- Bypass tray - 100 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 199 g/m² , Input tray - 550 sheets size: 102 x 148 mm - 216 x 297 mm weight: 60 g/m² - 120 g/m² , Output tray - 250 sheets , ADF - 100 sheets - Legal (216 x 356 mm) weight: 45 g/m² - 199 g/m²
- Speed Details
- Scanning: up to 43 ppm (A4) - B/W , Scanning: up to 45 ppm (Letter A) - B/W , Scanning: up to 38 ppm (A4) - colour , Scanning: up to 40 ppm (Letter A) - colour , Scanning: up to 45 ipm (Letter A) - B/W duplex , Scanning: up to 40 ipm (Letter A) - colour duplex , Scanning: up to 43 ipm (A4) - B/W duplex , Scanning: up to 38 ipm (A4) - colour duplex , Printing: up to 43 ppm (A4) - B/W (ISO) , Printing: up to 45 ppm (Letter A) - B/W (ISO) , Printing: up to 34 ipm (A4) - B/W duplex (ISO/IEC 24734) , Printing: up to 36 ipm (Letter A) - B/W duplex (ISO/IEC 24734) , Copying: up to 45 ppm (Letter A) - B/W (ISO) , Copying: up to 43 ppm (A4) - B/W (ISO)
- 2 x USB 2.0 host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
- Kerberos, LDAP, SSL, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP
- Operating System Support
- Apple Mac OS X 10.x, Ubuntu Linux 10.04, Apple Mac OS X 10.7, Ubuntu Linux 11.10, Ubuntu Linux 12.04, Apple Mac OS X 10.8, Fedora 17, Android, iOS, Fedora 18, Ubuntu Linux 12.10, Linux Mint 13, Linux Mint 14, Apple Mac OS X 10.9, Fedora 19, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Ubuntu Linux 13.04, Linux Mint 15, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Ubuntu Linux 13.10, Windows 10 (32/64-bits), SuSe Linux 12.2, SuSe Linux 12.3, SuSe Linux 13.1, Boss 3.0, Boss 5.0, Ubuntu Linux 14.10, Debian Linux 7.x, Fedora 20, Linux Mint 16, Linux Mint 17, Ubuntu Linux 14.04, Debian Linux 6.0.x
- Software Included
- Drivers & Utilities
- Voltage Required
- AC 230 V (50Hz)
- 671 Watt
- Power Consumption Standby
- 27.8 Watt
- Power Consumption Sleep
- 3.2 Watt
- Consumables Included
- 1 x toner cartridge (black) - up to 9000 pages - HP 87A
- FCC Class A certified, UL, cUL, GS, Laser Class 1, FCC CFR47 Part 15, EN 60825-1, CECP, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 60825-1:2007, EN 62479:2010, EMC 2004/108/EC, LVD 2006/95/EC, ICES-003 issue 4, EN 55024:2010, EN 55022:2010 Class A, CISPR 22:2008, IEC60950-1:2005+A1, IEC 62479:2010, EN 60950-1:2006+A11:2009+A1:2010+A12:2011
- Security Slot Type
- Kensington security slot
- ENERGY STAR Certified
- Blue Angel Compliant
- 48.2 cm
- 49.6 cm
- 49.7 cm
- 21.9 kg
- Shipping Width
- 73.5 cm
- Shipping Depth
- 61.3 cm
- Shipping Height
- 59.2 cm
- Shipping Weight
- 27.5 kg
- Sound Emission
- 25 dBA (idle) / 56 dBA (operating)
- 15 °C
- 32.5 °C
- 10 - 80%
HP 87A Black Original LaserJet Toner Cartridge | In Stock | £195.41 |
HP 87X High Yield Black Original LaserJet Toner Cartridge | In Stock | £256.66 |
