HP LaserJet Enterprise M507dn Laser Printer Colour 43 ppm Mono
Quicklinx: FHMZWS00 Mfr#: 1PV87A#OPG:42294275
Choose an HP LaserJet Enterprise printer designed to handle business solutions securely and efficiently, and helps conserve energy with HP EcoSmart black toner. Keep up with the demands of growing business with a printer you can rely on.
Dynamic security enabled printer. Only intended to be used with cartridges using an HP original chip. Cartridges using a non-HP chip may not work, and those that work today may not work in the future.
  • The world's most secure printing
    Each printer in your fleet checks its operating code and repairs itself from attacks.Your printer's outgoing network connections are inspected to stop suspicious requests and thwart malware.Memory activity is monitored to continually detect and stop attacks.Firmware is automatically checked during startup to determine if it's authentic code – digitally signed by HP.
  • Low costs, low energy use
    Stay productive with reliable cartridges, and help save energy while printing with HP EcoSmart black toner.Spend less time replacing toner, and more on business. Choose optional high-yield toner cartridges.Enhanced energy savings - up to 29% over prior products plus save with Auto-on/Auto-off technology.This printer fits in tight places to boost performance in almost any workspace.
  • A whole fleet at your control
    Centralise control of your printing environment with HP Web Jetadmin – and help build business efficiency.Gain insights into print costs, behaviors, utilization to drive efficiencies with this cloud-based printer.Set security configuration policies and automatically validate settings for every HP printer in your fleet.
  • Enhanced productivity keeps business moving
    Submit print jobs on the go and securely release them at any HP Roam-enabled office printer, securely.Don't wait for documents. Print your first page in as little as 10 seconds from energy-efficient sleep mode.
HP LaserJet Enterprise M507dn - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
16.34 kg
English, German, French, Italian, Spanish / Europe
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Print Speed
Up to 43 ppm - black normal - A4 (210 x 297 mm) , Up to 34 ipm - B/W duplex - A4 (210 x 297 mm) , Up to 65 ppm - black draft - A5 (148 x 210 mm) , Up to 45 ppm - black normal - ANSI A (Letter) (216 x 279 mm) , Up to 36 ipm - B/W duplex - ANSI A (Letter) (216 x 279 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Image Enhancement Technology
HP ProRes 1200 / HP FastRes 1200
Automatic Duplexing
USB 2.0, Gigabit LAN, USB 2.0 host
Preview Screen Size
2.7"
1.2 GHz
RAM Installed (Max)
512 MB (1.5 GB)
Language Simulation
PCL 5, PostScript 3, PCL 6, PDF 1.7
Media Type
Envelopes, transparencies, labels, plain paper, bond paper, recycled paper, card stock, punched paper, preprinted paper
Total Media Capacity
650 sheets
Media Handling
100-sheet multipurpose tray, 2x 550-sheet input trays
Monthly Duty Cycle (max)
150000 pages
Recommended Monthly Volume
2000 - 7500 pages
Print server
Printer Features
Instant-on Technology
AC 230V
1-year warranty
41.8 cm x 37.6 cm x 48.1 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Built-in Devices
2.7 inch QVGA LCD display
Preview Screen Size
2.7"
Wired
1200 x 1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
5.9 sec
Language Simulation
Printer Features
Media Handling
1.2 GHz
RAM
RAM Installed (Max)
512 MB / 1.5 GB (max)
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm
Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
650 sheets
Media Feeders
1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 199 g/m² , 1 x automatic - 550 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m²
Max Media Capacity
2300 sheets
Output Trays Capacity
250 sheets
Duty Cycle
150000 pages
2000 - 7500 pages
Print server
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, NDPS, NDS, HTTPS, TFTP, IPPS, SLP
Security Protocols & Features
Kerberos, SSL, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 2 x USB 2.0 host - 4 pin USB Type A
Consumables Included
1 x toner cartridge (black) - up to 5000 pages
Power supply - internal
AC 230V
601 Watt
Power Consumption Stand by
7.6 Watt
Software Included
Drivers & Utilities
Environmental Standards
ENERGY STAR
Limited warranty - 1 year - on-site - response time: next business day
10 °C
32.5 °C
10 - 80%
Sound Emission (Idle)
24 dBA
Sound Emission (Operating)
54 dBA
41.8 cm
37.6 cm
48.1 cm
16.34 kg
Width (Shipping)
67.1 cm
Depth (Shipping)
49.7 cm
Height (Shipping)
46.5 cm
Weight (Shipping)
22.6 kg
