Increase productivity with this MFP's fast print and copy speeds, an HP Easy Select control panel and outstanding paper-handling features. Use market-leading management tools to integrate the MFP into existing printing environments.
Enjoy productive, dependable performance with this versatile MFP
Stay productive with high performance speeds: print and copy at up to 52 ppm A4.Boost productivity – get up to 2,100-sheet paper capacity for large printing jobs from this workhorse MFP. Save time with a 3-bin, 900-sheet stapling mailbox that sorts, staples and stacks.Preview jobs using the pivoting colour control panel and use image preview to make adjustments to scan jobs.Save time with easy installation, and get exceptional value from optional high-capacity black print cartridges. -
Invest in an MFP that integrates easily into IT-managed print environments
Save time and money by proactively managing printing environments, and get easy setup and configuration with HP management tools like industry-leading HP Web Jetadmin.Extend the capabilities of workgroup print environments via the hardware integration pocket with a rich portfolio of easy-to-integrate solutions.Easily update, manage and expand the capabilities of networked printers with HP FutureSmart Firmware.Make printing as mobile as you are with HP ePrint. -
Stay in control of sensitive information with advanced security features
Protect sensitive data stored on the HP MFP with the standard encrypted HP High-Performance Secure Hard Disk.Process jobs securely: require a PIN to retrieve print jobs, expand IP addresses on your network with IPv6 and implement network access control with IPSec.Create, print, scan and share sensitive business information securely via encrypted email and PDFs.Add optional authentication security solutions through the hardware integration pocket. -
Conserve resources and meet environmental goals with this ENERGY STAR qualified MFP
Reduce energy use with Instant-on Technology and Instant-on Copy.Conserve resources and save paper –automatic two-sided printing reduces paper consumption and PIN printing ensures only authorised use of the MFP.Original HP LaserJet print cartridges with energy-efficient toner enable an energy saving of over 18% on every page you print.Get free, easy cartridge recycling with HP Planet Partners, plus reduce shipping materials with HP ClearView packaging.
- HP LaserJet Enterprise M4555h MFP - multifunction printer - B/W
- Multifunction printer
- Copier Type
- Digital
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 250000 impressions
- Recommended Monthly Volume
- 5000 - 20000 pages
- Max Copying Speed
- Up to 52 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 52 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Scanning
- 600 dpi
- Display
- 8.07"
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, recycled paper, bond paper
- Standard Media Capacity
- 600 sheets
- Max Media Capacity
- 2100 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- Office Machine Features
- Save to USB flash drive, scan to e-mail, scan to network
- Power
- AC 230 V (50Hz)
- 79 cm x 51 cm x 57 cm
- 52.5 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Copier Type
- Digital
- Laser - monochrome
- Display Diagonal Size
- 8.07"
- Display Features
- Touch screen
- Interface
- Localisation
- Standard Memory
- 1280 MB 1.25 GB
- Max Supported Memory
- 1280 MB 1.25 GB
Copying
- Max Copying Speed
- Up to 52 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 9999
Printing
- Up to 52 ppm
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, PDF 1.4
- Image Enhancement Technology
- HP FastRes 1200
- First Print Out Time B/W
- 9.5 sec
Scanning
- Optical Resolution
- 600 dpi
- Colour Depth
- 30-bit
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Max Media Size
- A4
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 200 g/m²
- Supported Media Type
- Supported Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), C5 (162 x 229 mm), JIS B5 (182 x 257 mm), C6 (114 x 162 mm)
- 600 sheets
- 2100 sheets
- ADF - 50 sheets - A4 (210 x 297 mm) , Input tray - 500 sheets - A4 (210 x 297 mm) , Input tray - 100 sheets - A4 (210 x 297 mm)
- Speed Details
- Printing: up to 52 ppm (A4) - B/W , Copying: up to 52 ppm (A4) - B/W
- 1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
- Network Protocols
- IPP
- Kerberos, SSL, TLS, IPsec
- Operating System Support
- MS Windows Server 2003, MS Windows XP SP2 or later, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.5 or later
- Software Included
- Drivers & Utilities
- Voltage Required
- AC 230 V (50Hz)
- 1024 Watt
- Power Consumption Standby
- 54 Watt
- Power Consumption Sleep
- 21.6 Watt
- Included Accessories
- Phone cable
- Consumables Included
- 1 x toner cartridge (black)
- EN 61000-3-2, GS, ICES-003, EN 61000-3-3, EN55024, EN55022 Class A, CISPR 22, EMC, IEC 60950-1, EN 60950-1, FCC CFR47, IEC 60825-1, EN 60825-1
- ENERGY STAR Certified
- 79 cm
- 51 cm
- 57 cm
- 52.5 kg
- Shipping Width
- 73.8 cm
- Shipping Depth
- 66.3 cm
- Shipping Height
- 73.5 cm
- Shipping Weight
- 61.4 kg
- Sound Emission
- 57 dBA (operating)
- 10 °C
- 30 °C
- 10 - 80%
HP 90X High Yield Black Original LaserJet Toner Cartridge | In Stock | £253.96 |
HP 90A Black Original LaserJet Toner Cartridge | In Stock | £151.96 |
HP 90X 2-pack High Yield Black Original LaserJet Toner Cartridges | In Stock | £457.11 |
