Rely on a full-featured HP Enterprise Flow MFP that streamlines digital workflow with advanced HP Flow solutions, safeguards business data and documents with a robust suite of top-flight security features and offers simple, efficient mobile printing.
Get powerful performance to enhance workflow
Scan two-sided documents in a single pass with super-fast scan speeds. HP EveryPage allows employees to scan without worry and detect potential errors or missed pages on the spot – even when the weight, size or condition of pages varies.Increase efficiency and streamline workflow with a suite of HP Flow MFP features and scanning solutions.Easily tackle large jobs with a standard paper capacity of up to 3,100 sheets and paper-finishing options.Quickly troubleshoot problems with cloud-based help services that are relevant and up to date. -
Protect your business – now and in the future
Safeguard and manage centrally your printing fleet with the HP Imaging and Printing Security Center and HP Web Jetadmin.Confidently safeguard the sensitive data sent to your MFP with the encrypted hard drive.Secure your investment – depend on an MFP that can expand with your business, whenever solutions advance.Safeguard security keys, passwords and certificates with the optional HP Trusted Platform Module. -
Enjoy easy and secure mobile printing
Enable optional touch-to-print and touch-to-authenticate convenience from mobile devices.Enable secure peer-to-peer direct-access mobile printing without connecting to the corporate network.Easily print from a variety of smartphones and tablets – generally no setup or apps required.Pull print jobs from your pocket – walk up and print or scan from your USB drive.
- HP LaserJet Enterprise Flow MFP M630h - multifunction printer - B/W
- Multifunction printer
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 250000 pages
- Recommended Monthly Volume
- 5000 - 28000 pages
- Max Copying Speed
- Up to 57 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 57 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Scanning
- 600 x 600 dpi
- Display
- 8"
- Original Size
- 68 x 148 mm (min) - Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, heavy-weight paper, card stock, extra heavy-weight paper, light-weight paper, punched paper
- Standard Media Capacity
- 600 sheets
- Max Media Capacity
- 3100 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 500 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB 2.0 host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, Hardware Integration Pocket, Hard Disk Drive Encryption, save to network folder, Foreign Interface Harness (FIH), pull-out keyboard
- Power
- AC 230 V (50Hz)
- 73.7 cm x 64.3 cm x 57 cm
- 51.6 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- 1-year warranty
- Laser - monochrome
- 250000 pages
- Display Diagonal Size
- 8"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 1.5 GB
- Max Supported Memory
- 2 GB
- Hard Disk Drive
- 320 GB
- Supported Flash Memory
- USB flash drive
Copying
- Max Copying Speed
- Up to 57 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 9999
Printing
- Up to 57 ppm
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PDF 1.7, PCL 5
- Image Enhancement Technology
- HP FastRes 1200, HP ProRes 1200
- First Print Out Time B/W
- 8.5 sec
Scanning
- Scan Element
- CCD
- Optical Resolution
- 600 x 600 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Document & Media Handling
- Min Original Size
- 68 x 148 mm
- Max Original Size
- Original Type
- Sheets
- 100 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 200 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76 x 127 mm, 127 x 177.8 mm, Oficio (216 x 343 mm), 216 x 356 mm, 127 x 203.2 mm, JIS B6 (128 x 182 mm), RA4 (215 x 305 mm)
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
- 600 sheets
- 3100 sheets
- 100 sheets
- 500 sheets
- ADF - 100 sheets size: 68 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , Input tray - 500 sheets size: 148 x 210 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , Bypass tray - 100 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m² , Output tray - 500 sheets
- Speed Details
- Printing: up to 57 ppm (A4) - B/W normal , Copying: up to 57 ppm (A4) - B/W normal , Scanning: up to 60 ppm (A4) - B/W normal , Scanning: up to 45 ppm (A4) - colour normal , Scanning: up to 60 ipm (A4) - B/W duplex , Scanning: up to 44 ipm (A4) - colour duplex , Printing: up to 39 ppm (A4) - B/W duplex , Printing: up to 60 ppm (Letter A) - B/W normal , Copying: up to 60 ppm (Letter A) - B/W normal , Copying: up to 41 ppm (Letter A) - B/W duplex , Copying: up to 39 ppm (A4) - B/W duplex , Printing: up to 41 ipm (Letter A) - B/W duplex , Printing: up to 39 ipm (A4) - B/W duplex , Scanning: up to 60 ppm (Letter A) - B/W duplex , Scanning: up to 45 ppm (Letter A) - colour duplex , Scanning: up to 60 ipm (Letter A) - B/W duplex , Scanning: up to 45 ipm (Letter A) - colour duplex
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 2 x USB 2.0 host - 4 pin USB Type A
- Kerberos, LDAP, SSL, TLS, IPsec, 802.1x, EAP-TLS, PEAP
- Operating System Support
- Sun Solaris 8, Sun Solaris 9, MS Windows 7, MS Windows XP SP3, Ubuntu Linux 8.10, Ubuntu Linux 9.04, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), SuSe Linux 10.3, HP-UX 11.0, Ubuntu Linux 9.10, Ubuntu Linux 10.04, Fedora 10, Fedora 9, Fedora 11, Fedora 12, Apple Mac OS X 10.7, Debian Linux 5.0, Red Hat Enterprise Linux 5, SuSe Linux 11.0, SuSe Linux 11.1, SuSe Linux 11.2, Debian Linux 5.0.1, Debian Linux 5.0.2, Debian Linux 5.0.3, Ubuntu Linux 8.04, Apple Mac OS X 10.8, Windows 8, Windows 8 64-bit, MS Windows XP 64-bit Edition SP3 or later, Windows 8.1, Apple Mac OS X 10.9, Windows 8.1 64-bit, Linux 9.4, Linux 9.5, Ubuntu Linux 8.04.1, Ubuntu Linux 8.04.2
- Software Included
- Drivers & Utilities, HP Web Jetadmin
- Voltage Required
- AC 230 V (50Hz)
- 970 Watt
- Power Consumption Sleep
- 6.5 Watt
- First Copy Out Time B/W
- 7.5 sec
- FCC Class A certified, UL, CISPR 22 Class A, cUL, GS, ICES-003, EMC, Laser Class 1, FCC CFR47 Part 15, LVD, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN 60825-1:2001, IEC 62479, IEC 60825-1:2007, EN 62479:2010, IEC 60950-1:2005, EN 55024:2010, EN 55022:2010 Class A, EN 60950-1:2006+A11:2009+A1:2010+A12:2011
- ENERGY STAR Certified
- Blue Angel Compliant
- Limited warranty - 1 year - on-site
- 73.7 cm
- 64.3 cm
- 57 cm
- 51.6 kg
- Shipping Width
- 78.3 cm
- Shipping Depth
- 75.5 cm
- Shipping Height
- 73.6 cm
- Shipping Weight
- 62.36 kg
- Sound Emission
- 26 dBA (idle) / 61 dBA (operating)
- 15 °C
- 32.5 °C
- 10 - 80%
