Finish tasks faster with an MFP that starts right away and helps conserve energy. Multi-level device security helps protect from threats. Original HP Toner cartridges with JetIntelligence and this printer produce more high-quality pages.
Accelerate your work and use less energy
Don't wait for documents. Print your first page in as few as 8.7 seconds from energy-efficient sleep mode and 5.7 seconds from ready.Print two-sided documents without sacrificing performance slowdowns for duplexing and let high-volume jobs handle themselves with a 2,300-sheet maximum input capacity.Scan two-sided documents in a single pass with super-fast scan speeds. HP EveryPage allows employees to scan without worry, detect potential errors or missed pages on the spot and save time with the advanced workflow features with the Flow MFP M527c.This MFP leads its class in low energy use – thanks to its innovative design and toner technology. -
Unparalleled fleet security and management
Embedded features detect security threats and heal your MFP, protecting it from boot up to shutdown.Protect sensitive data on the MFP and in transit, using embedded security features and 256-bit encryption.Protect sensitive business data with embedded and optional HP JetAdvantage Security Solutions.Centralise control of your printing environment with HP Web Jetadmin – and help build business efficiency. -
More
Produce sharp text, bold blacks, and crisp graphics with precision black toner.Get more. Original HP Toner with JetIntelligence delivers more pages per cartridge than predecessors.Get the professional results you expect from HP with a choice of JetIntelligence cartridges to fit your budget.Help ensure the Original HP quality you paid for with anti-fraud and cartridge authentication technology. -
Stay connected with secure mobile printing options
Use optional, 128-bit encrypted wireless direct printing from mobile devices – no network needed.Add the option to print with a touch of your NFC-enabled mobile device to this printer – no network needed.Easily access, print, and share resources with Ethernet and optional wireless networking.
- HP LaserJet Enterprise Flow MFP M527c - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 150000 pages
- Recommended Monthly Volume
- 2000 - 7500 pages
- Max Copying Speed
- Up to 43 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 43 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 98 dpi, 300 x 300 dpi
- Scanning
- 600 dpi
- Display
- 8"
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, card stock, punched paper, preprinted paper
- Standard Media Capacity
- 650 sheets
- Max Media Capacity
- 2300 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 250 sheets
- Stapler
- Included
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB 2.0 host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, Internet faxing, scan to e-mail, Hard Disk Drive Encryption, save to network folder, HP EveryPage, HP High-Performance Secure Hard Disk, pull-out keyboard, Instant-on Technology, scan to FTP, scan to SharePoint, scan to OCR, ultrasonic multi-feed detection, security lock slot
- Power
- AC 230 V (50Hz)
- 48.2 cm x 49.6 cm x 49.7 cm
- 22.1 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- Fax Type
- Plain paper
- Laser - monochrome
- 150000 pages
- 2000 - 7500 pages
- Display Diagonal Size
- 8"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Supported Flash Memory
- USB flash drive
Copying
- Max Copying Speed
- Up to 43 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
Printing
- Up to 43 ppm
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PDF 1.7, PCL 5
- Image Enhancement Technology
- HP ProRes 1200
Scanning
- Optical Resolution
- 600 dpi
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
Fax Machine Features
- Speed Dialing
- 1000 station(s)
- Broadcast Transmission
- 210 stations
- Remote Fax Retrieval (Polling)
- Fax forwarding, automatic redialing, auto reduction
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 100 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 199 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 216 x 297 mm, 101.6 x 152.4 mm, 76 x 127 mm, Oficio (216 x 343 mm), 215.9 x 330.2 mm, 127 x 203.2 mm, 102 x 148 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
- 650 sheets
- 2300 sheets
- 100 sheets
- 250 sheets
- Bypass tray - 100 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 199 g/m² , Input tray - 550 sheets size: 102 x 148 mm - 216 x 297 mm weight: 60 g/m² - 120 g/m² , Output tray - 250 sheets , ADF - 100 sheets - Legal (216 x 356 mm) weight: 45 g/m² - 199 g/m²
- Speed Details
- Scanning: up to 45 ppm (A4) - B/W , Scanning: up to 48 ppm (Letter A) - B/W , Scanning: up to 45 ppm (A4) - colour , Scanning: up to 48 ppm (Letter A) - colour , Scanning: up to 68 ipm (Letter A) - B/W duplex , Scanning: up to 60 ipm (Letter A) - colour duplex , Scanning: up to 64 ipm (A4) - B/W duplex , Scanning: up to 58 ipm (A4) - colour duplex , Printing: up to 43 ppm (A4) - B/W (ISO) , Printing: up to 45 ppm (Letter A) - B/W (ISO) , Printing: up to 34 ipm (A4) - B/W duplex (ISO/IEC 24734) , Printing: up to 36 ipm (Letter A) - B/W duplex (ISO/IEC 24734) , Copying: up to 43 ppm (A4) - B/W (ISO) , Copying: up to 34 ipm (A4) - B/W duplex , Printing: up to 65 ppm (A5) - B/W draft , Copying: up to 45 ppm (Letter A) - B/W (ISO)
Finishing Equipment
- Stapler
- Included
- 2 x USB 2.0 host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
- Kerberos, LDAP, SSL, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP
- Operating System Support
- Apple Mac OS X 10.x, Ubuntu Linux 10.04, Apple Mac OS X 10.7, Ubuntu Linux 11.10, Ubuntu Linux 12.04, Apple Mac OS X 10.8, Fedora 17, Android, iOS, Fedora 18, Ubuntu Linux 12.10, Linux Mint 13, Linux Mint 14, Apple Mac OS X 10.9, Fedora 19, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Ubuntu Linux 13.04, Linux Mint 15, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Ubuntu Linux 13.10, Windows 10 (32/64-bits), SuSe Linux 12.2, SuSe Linux 12.3, SuSe Linux 13.1, Boss 3.0, Boss 5.0, Ubuntu Linux 14.10, Debian Linux 7.x, Fedora 20, Linux Mint 16, Linux Mint 17, Ubuntu Linux 14.04, Debian Linux 6.0.x
- Software Included
- Drivers & Utilities
- Voltage Required
- AC 230 V (50Hz)
- 671 Watt
- Power Consumption Standby
- 27.8 Watt
- Power Consumption Sleep
- 3.2 Watt
- Consumables Included
- 1 x toner cartridge (black) - up to 9000 pages - HP 87A
- FCC Class A certified, UL, cUL, GS, CS-03, FCC CFR47 Part 68, R&TTE, Laser Class 1, FCC CFR47 Part 15, EN 60825-1, CECP, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 60825-1:2007, EN 62479:2010, EMC 2004/108/EC, LVD 2006/95/EC, ETSI ES203 021, ICES-003 issue 4, EN 55024:2010, EN 55022:2010 Class A, CISPR 22:2008, IEC60950-1:2005+A1, IEC 62479:2010, EN 60950-1:2006+A11:2009+A1:2010+A12:2011
- Security Slot Type
- Kensington security slot
- ENERGY STAR Certified
- Blue Angel Compliant
- 48.2 cm
- 49.6 cm
- 49.7 cm
- 22.1 kg
- Shipping Width
- 73.4 cm
- Shipping Depth
- 61.3 cm
- Shipping Height
- 59.2 cm
- Shipping Weight
- 27.5 kg
- Sound Emission
- 25 dBA (idle) / 56 dBA (operating)
- 15 °C
- 32.5 °C
- 10 - 80%
Ink (5)
HP 87A Black Original LaserJet Toner Cartridge | In Stock | £190.60 |
HP 87X High Yield Black Original LaserJet Toner Cartridge | In Stock | £256.66 |
HP 87X HY Original LaserJet 2pk Black | In Stock | £463.96 |
HP 87AS Black Original LaserJet Toner Cartridge | In Stock | £120.23 |
HP Glossy Laser Paper 150GSM 150 SHT/A4 | In Stock | £14.48 |
Other bundles (5)
HP LaserJet 550 Sheet Paper Tray | In Stock | £112.78 |
HP LaserJet Printer Cabinet | In Stock | £258.94 |
HP Internal USB Ports for M506/M527 Series | In Stock | £19.86 |
HP Foreign Interface Harness (FIH) | In Stock | £77.37 |
HP 3Y NBD + DMR LJ M527 MFP Hardware Support | In Stock | £493.46 |
