Enable large-volume professional-quality colour printing on a wide range of paper sizes up to A3, with paper capacity up to 4,350 sheets. Preview and edit scanning jobs. Centrally manage printing policies. Safeguard sensitive business information.
Expand possibilities with broad capabilities and brilliant colour with this affordable A3 MFP
Increase colour printing capabilities with media sizes up to A3 for impressive marketing materials and more.Impress with bold text and smooth colour, and get the colour output you intended with Pantone matching.Go from start to finish, right at the MFP – print, copy, scan, and fax from the large touchscreen.Print from your smartphone or tablet from virtually anywhere with HP ePrint. -
Boost productivity and easily manage printing
Boost productivity – get up to 4,350-sheet paper capacity for large printing jobs from this workhorse MFP.Automate high-volume print jobs to save time, using the 100-page automatic document feeder.Easily manage your business's colour printing with HP colour access controls.Save and print files directly at the MFP via an easy-access USB port. -
Streamline your workflow with robust scanning
Improve workflow using touchscreen controls to preview, edit, and digitally send documents at the device.Streamline tasks: print, copy, fax and scan projects directly at the MFP's large colour touchscreen.Incorporate paper documents into digital workflows – easily send scans to fax, email, or network folders.Efficiently capture the right content: remove blank pages in scanned documents to avoid wasted paper. -
Invest in robust security that grows with you
Extend the capabilities of workteam print environments, using a rich array of easy-to-integrate solutions.Boost printing and imaging safeguards and protect business data with fleet-level security solutions.Add security solutions such as card and badge readers through the hardware integration pocket.Help control expenses with energy-saving features.
- HP LaserJet Enterprise MFP M775z - multifunction printer - colour
- Multifunction printer
- Copier Type
- Digital
- Fax Type
- Plain paper
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 120000 impressions
- Recommended Monthly Volume
- 2500 - 7500 pages
- Max Copying Speed
- Up to 30 ppm (mono) / up to 30 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 300 x 300 dpi, 204 x 98 dpi, 204 x 196 dpi
- Scanning
- 600 x 600 dpi
- Display
- 8.07"
- Original Size
- 101.6 x 152.4 mm (min) - A3/Ledger (297 x 432 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- 76 x 127 mm (min) - 320 x 470 mm (max)
- Media Type
- Transparencies, envelopes, plain paper, labels, recycled paper, photo paper, bond paper, film, heavy-weight paper, card stock
- Standard Media Capacity
- 1850 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 750 sheets
- Collator
- Included
- Stacker
- Included
- Stapler
- Included
- Automatic Duplexing
- Yes (copying) Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host, 2 x USB host (internal)
- AirPrint Enabled
- Office Machine Features
- Document send function, save to USB flash drive, scan to e-mail, scan to network, Hardware Integration Pocket, automatic paper sensor, Foreign Interface Harness (FIH)
- Power
- AC 230 V (50/60Hz)
- 74.5 cm x 66.8 cm x 119.8 cm
- 107.7 kg
- Environmental Standards
- ENERGY STAR Qualified, EPEAT Silver
- Copier Type
- Digital
- Fax Type
- Plain paper
- Laser - colour
- 2500 - 7500 pages
- Display Diagonal Size
- 8.07"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 1.5 GB
- Max Supported Memory
- 1.5 GB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 9999
- Copying Features
- Auto colour select, collation copy
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, PDF 1.4
- Image Enhancement Technology
- HP ImageREt 3600
- First Print Out Time B/W
- 10.5 sec
- First Print Out Time Colour
- 10.5 sec
Scanning
- Scan Element
- CCD
- Optical Resolution
- 600 x 600 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 100 pages
- Fax Printing Resolution
- 400 x 400 dpi
- PC Faxing
Fax Machine Features
- Speed Dialing
- 100 station(s)
- Broadcast Transmission
- 100 stations
- Fax forwarding, automatic redialing, junk fax barrier, auto reduction, fax polling
Document & Media Handling
- Min Original Size
- 101.6 x 152.4 mm
- Max Original Size
- Original Type
- Sheets
- 100 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A3/Ledger
- Min Media Weight
- 49 g/m²
- Max Media Weight
- 120 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), ANSI B (Ledger) (279 x 432 mm), ARCH B (304.8 x 457.2 mm), Folio (216 x 330 mm), 297 x 432 mm, 148 x 182 mm, JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), SRA3 (320 x 450 mm), SRA4 (225 x 320 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), B6 (125 x 176 mm), 76 x 127 mm, RA3 (305 x 430 mm), 127 x 177.8 mm, 320 x 470 mm, 127 x 203.2 mm, JIS B6 (128 x 182 mm), 210.1 x 133.6 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
- 1850 sheets
- 100 sheets
- 750 sheets
- Stacker / stapler - 500 sheets , Output tray - 250 sheets , Bypass tray - 100 sheets size: 76 x 127 mm - 320 x 470 mm weight: 60 g/m² - 220 g/m² , Input tray - 250 sheets size: 148 x 182 mm - A3/Ledger (297 x 432 mm) weight: 60 g/m² - 220 g/m² , 3 x input tray - 500 sheets size: 210.1 x 133.6 mm - A3/Ledger (297 x 432 mm) weight: 60 g/m² - 220 g/m² , ADF - 100 sheets size: 101.6 x 152.4 mm - A3/Ledger (297 x 432 mm)
- Speed Details
- Printing: up to 30 ppm (A4) - B/W normal , Printing: up to 30 ppm (A4) - colour normal , Copying: up to 30 ppm (A4) - B/W normal , Copying: up to 30 ppm (A4) - colour normal , Scanning: up to 30 ppm (A4) - B/W normal , Scanning: up to 30 ppm (A4) - colour normal
Finishing Equipment
- Collator
- Included
- Stacker
- Included
- Stapler
- Included
- 1 x USB 2.0 , 1 x USB host , 2 x USB host (internal) , 1 x Gigabit LAN
- Operating System Support
- UNIX, Linux, MS Windows Server 2008 x64 Edition, MS Windows XP SP2 or later, MS Windows 7, MS Windows Vista, MS Windows Server 2008, Apple Mac OS X 10.6, Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2003 SP1 or later, Windows 8
- Software Included
- Drivers & Utilities
- Voltage Required
- 703 Watt
- Power Consumption Standby
- 85 Watt
- Power Consumption Sleep
- 14.8 Watt
- Included Accessories
- Phone cable
- Consumables Included
- 1 x Cartridge (black) - up to 13500 pages , 1 x Cartridge (cyan) - up to 16000 pages , 1 x Cartridge (magenta) - up to 16000 pages , 1 x Cartridge (yellow) - up to 16000 pages
- FCC Class A certified, UL, cUL, GS, ICES-003, EN55024, EN55022 Class A, CISPR 22, EMC, Laser Class 1, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, IEC 60825-1, EN 60825-1, LVD, GB 9254-2008, EN 61000-3-2:2006, EN 61000-3-3:2008, GB 17625.1-2003 EMC
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- 74.5 cm
- 66.8 cm
- 119.8 cm
- 107.7 kg
- Shipping Width
- 85.6 cm
- Shipping Depth
- 76 cm
- Shipping Height
- 155.3 cm
- Shipping Weight
- 126.7 kg
- Sound Emission
- 53 dBA (operating)
- 15 °C
- 27 °C
- 10 - 70%
HP 651A Black Original LaserJet Toner Cartridge | In Stock | £130.14 |
HP 651A Cyan Original LaserJet Toner Cartridge | In Stock | £325.59 |
HP 651A Yellow Original LaserJet Toner Cartridge | In Stock | £325.59 |
HP 651A Magenta Original LaserJet Toner Cartridge | In Stock | £325.59 |
