HP LaserJet Enterprise 700 M775dn Colour Multifunction Printer
Quicklinx: 9HF5WS00 Mfr#: CC522A#B19
Enable large-volume professional-quality colour printing on a wide range of paper sizes up to A3, with paper capacity up to 4,350 sheets. Preview and edit scanning jobs. Centrally manage printing policies. Safeguard sensitive business information.
  • 2-sided printing
    Allows you to print on both sides of the page, cutting your paper use by up to 50%.
  • 20.3 cm colour touchscreen (printer)
    Manage jobs directly at the MFP, using the HP colour touchscreen.
HP Color LaserJet Enterprise MFP M775dn - multifunction printer - colour
Multifunction printer
Copier Type
Digital
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
120000 impressions
Recommended Monthly Volume
2500 - 7500 pages
Max Copying Speed
Up to 30 ppm (mono) / up to 30 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Scanning
600 x 600 dpi
Display
8.07"
Original Size
101.6 x 152.4 mm (min) - A3/Ledger (297 x 432 mm) (max)
Original Type
Sheets
Document Feeder Capacity
100 sheets
Media Size
76 x 127 mm (min) - 320 x 470 mm (max)
Media Type
Transparencies, envelopes, plain paper, labels, recycled paper, photo paper, bond paper, film, heavy-weight paper, card stock
Standard Media Capacity
350 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
250 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
Connection Availability
USB 2.0, Gigabit LAN, USB host, 2 x USB host (internal)
AirPrint Enabled
Office Machine Features
Document send function, save to USB flash drive, scan to e-mail, scan to network, Hardware Integration Pocket, automatic paper sensor, Foreign Interface Harness (FIH)
AC 230 V (50/60Hz)
59.2 cm x 63.9 cm x 59.5 cm
63.7 kg
Environmental Standards
EPEAT Silver, ENERGY STAR Qualified
Copier Type
Digital
Printing Technology
Laser - colour
120000 impressions
2500 - 7500 pages
Display Diagonal Size
8.07"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
1536 MB 1.5 GB
Max Supported Memory
1536 MB 1.5 GB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
9999
Automatic Duplexing
Copying Features
Auto colour select
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF 1.4
Image Enhancement Technology
HP ImageREt 3600
Automatic Duplexing
First Print Out Time B/W
10.5 sec
First Print Out Time Colour
10.5 sec
Scanning
Scan Element
CCD
Optical Resolution
600 x 600 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Min Original Size
101.6 x 152.4 mm
Max Original Size
Original Type
Sheets
100 sheets
Min Media Size
76 x 127 mm
Max Media Size
A3/Ledger
Min Media Weight
49 g/m²
Max Media Weight
120 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), ANSI B (Ledger) (279 x 432 mm), ARCH B (304.8 x 457.2 mm), Folio (216 x 330 mm), 297 x 432 mm, 148 x 182 mm, JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), SRA3 (320 x 450 mm), SRA4 (225 x 320 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), B6 (125 x 176 mm), 76 x 127 mm, RA3 (305 x 430 mm), 127 x 177.8 mm, 320 x 470 mm, 127 x 203.2 mm, JIS B6 (128 x 182 mm)
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
350 sheets
100 sheets
250 sheets
Output tray - 250 sheets , Bypass tray - 100 sheets size: 76 x 127 mm - 320 x 470 mm weight: 60 g/m² - 220 g/m² , Input tray - 250 sheets size: 148 x 182 mm - A3/Ledger (297 x 432 mm) weight: 60 g/m² - 220 g/m² , ADF - 100 sheets size: 101.6 x 152.4 mm - A3/Ledger (297 x 432 mm)
Speed Details
Printing: up to 30 ppm (A4) - B/W normal , Printing: up to 30 ppm (A4) - colour normal , Copying: up to 30 ppm (A4) - B/W normal , Copying: up to 30 ppm (A4) - colour normal , Scanning: up to 30 ppm (A4) - B/W normal , Scanning: up to 30 ppm (A4) - colour normal
1 x USB 2.0 , 1 x USB host , 2 x USB host (internal) , 1 x Gigabit LAN
Operating System Support
UNIX, Linux, MS Windows Server 2008 x64 Edition, MS Windows XP SP2 or later, MS Windows 7, MS Windows Vista, MS Windows Server 2008, Apple Mac OS X 10.6, Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2003 SP1 or later, Windows 8
Software Included
Drivers & Utilities
AC 230 V (50/60Hz)
703 Watt
Power Consumption Standby
85 Watt
Power Consumption Sleep
14.8 Watt
Phone cable
Consumables Included
1 x toner cartridge (black) - up to 13500 pages , 1 x toner cartridge (cyan) - up to 16000 pages , 1 x toner cartridge (magenta) - up to 16000 pages , 1 x toner cartridge (yellow) - up to 16000 pages
FCC Class A certified, UL, cUL, GS, ICES-003, EN55024, EN55022 Class A, CISPR 22, EMC, Laser Class 1, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, IEC 60825-1, EN 60825-1, LVD, GB 9254-2008, EN 61000-3-2:2006, EN 61000-3-3:2008, GB 17625.1-2003 EMC
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
59.2 cm
63.9 cm
59.5 cm
63.7 kg
Shipping Width
76 cm
Shipping Depth
74.5 cm
Shipping Height
83.2 cm
Shipping Weight
76.5 kg
Sound Emission
53 dBA (operating)
15 °C
27 °C
10 - 70%
