HP LaserJet Enterprise 700 M775dn Colour Multifunction Printer
Quicklinx: 9HF5WS00 Mfr#: CC522A#B19
Type: Printer / copier / scanner
Functionality: Copier, Printer, Scanner
Output Type: Colour
Wireless Capability: Wired
Technology: Laser
£2,684.27 ex VAT
£3,221.12 inc VAT
Enable large-volume professional-quality colour printing on a wide range of paper sizes up to A3, with paper capacity up to 4,350 sheets. Preview and edit scanning jobs. Centrally manage printing policies. Safeguard sensitive business information.
  • Expand possibilities with broad capabilities and brilliant colour with this affordable A3 MFP
    Increase colour printing capabilities with media sizes up to A3 for impressive marketing materials and more.Impress with bold text and smooth colour, and get the colour output you intended with Pantone matching.Go from start to finish, right at the MFP – print, copy, scan, and fax from the large touchscreen.Print from your smartphone or tablet from virtually anywhere with HP ePrint.
  • Boost productivity and easily manage printing
    Boost productivity – get up to 4,350-sheet paper capacity for large printing jobs from this workhorse MFP.Automate high-volume print jobs to save time, using the 100-page automatic document feeder.Easily manage your business's colour printing with HP colour access controls.Save and print files directly at the MFP via an easy-access USB port.
  • Streamline your workflow with robust scanning
    Improve workflow using touchscreen controls to preview, edit, and digitally send documents at the device.Streamline tasks: print, copy, fax and scan projects directly at the MFP's large colour touchscreen.Incorporate paper documents into digital workflows – easily send scans to fax, email, or network folders.Efficiently capture the right content: remove blank pages in scanned documents to avoid wasted paper.
  • Invest in robust security that grows with you
    Extend the capabilities of workteam print environments, using a rich array of easy-to-integrate solutions.Boost printing and imaging safeguards and protect business data with fleet-level security solutions.Add security solutions such as card and badge readers through the hardware integration pocket.Help control expenses with energy-saving features.
HP LaserJet Enterprise MFP M775dn - multifunction printer - colour
Multifunction printer
Copier Type
Digital
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
120000 impressions
Recommended Monthly Volume
2500 - 7500 pages
Max Copying Speed
Up to 30 ppm (mono) / up to 30 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Scanning
600 x 600 dpi
Display
8.07"
Original Size
101.6 x 152.4 mm (min) - A3/Ledger (297 x 432 mm) (max)
Original Type
Sheets
Document Feeder Capacity
100 sheets
Media Size
76 x 127 mm (min) - 320 x 470 mm (max)
Media Type
Transparencies, envelopes, plain paper, labels, recycled paper, photo paper, bond paper, film, heavy-weight paper, card stock
Standard Media Capacity
350 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
250 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
Connection Availability
USB 2.0, Gigabit LAN, USB host, 2 x USB host (internal)
AirPrint Enabled
Office Machine Features
Document send function, save to USB flash drive, scan to e-mail, scan to network, Hardware Integration Pocket, automatic paper sensor, Foreign Interface Harness (FIH)
AC 230 V (50/60Hz)
59.2 cm x 63.9 cm x 59.5 cm
63.7 kg
Environmental Standards
ENERGY STAR Qualified, EPEAT Silver
Copier Type
Digital
Printing Technology
Laser - colour
120000 impressions
2500 - 7500 pages
Display Diagonal Size
8.07"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
1.5 GB
Max Supported Memory
1.5 GB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
9999
Automatic Duplexing
Copying Features
Auto colour select
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF 1.4
Image Enhancement Technology
HP ImageREt 3600
Automatic Duplexing
First Print Out Time B/W
10.5 sec
First Print Out Time Colour
10.5 sec
Scanning
Scan Element
CCD
Optical Resolution
600 x 600 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Min Original Size
101.6 x 152.4 mm
Max Original Size
Original Type
Sheets
100 sheets
Min Media Size
76 x 127 mm
Max Media Size
A3/Ledger
Min Media Weight
49 g/m²
Max Media Weight
120 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), ANSI B (Ledger) (279 x 432 mm), ARCH B (304.8 x 457.2 mm), Folio (216 x 330 mm), 297 x 432 mm, 148 x 182 mm, JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), SRA3 (320 x 450 mm), SRA4 (225 x 320 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), B6 (125 x 176 mm), 76 x 127 mm, RA3 (305 x 430 mm), 127 x 177.8 mm, 320 x 470 mm, 127 x 203.2 mm, JIS B6 (128 x 182 mm)
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
350 sheets
100 sheets
250 sheets
Output tray - 250 sheets , Bypass tray - 100 sheets size: 76 x 127 mm - 320 x 470 mm weight: 60 g/m² - 220 g/m² , Input tray - 250 sheets size: 148 x 182 mm - A3/Ledger (297 x 432 mm) weight: 60 g/m² - 220 g/m² , ADF - 100 sheets size: 101.6 x 152.4 mm - A3/Ledger (297 x 432 mm)
Speed Details
Printing: up to 30 ppm (A4) - B/W normal , Printing: up to 30 ppm (A4) - colour normal , Copying: up to 30 ppm (A4) - B/W normal , Copying: up to 30 ppm (A4) - colour normal , Scanning: up to 30 ppm (A4) - B/W normal , Scanning: up to 30 ppm (A4) - colour normal
1 x USB 2.0 , 1 x USB host , 2 x USB host (internal) , 1 x Gigabit LAN
Operating System Support
UNIX, Linux, MS Windows Server 2008 x64 Edition, MS Windows XP SP2 or later, MS Windows 7, MS Windows Vista, MS Windows Server 2008, Apple Mac OS X 10.6, Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2003 SP1 or later, Windows 8
Software Included
Drivers & Utilities
AC 230 V (50/60Hz)
703 Watt
Power Consumption Standby
85 Watt
Power Consumption Sleep
14.8 Watt
Phone cable
Consumables Included
1 x Cartridge (black) - up to 13500 pages , 1 x Cartridge (cyan) - up to 16000 pages , 1 x Cartridge (magenta) - up to 16000 pages , 1 x Cartridge (yellow) - up to 16000 pages
FCC Class A certified, UL, cUL, GS, ICES-003, EN55024, EN55022 Class A, CISPR 22, EMC, Laser Class 1, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, IEC 60825-1, EN 60825-1, LVD, GB 9254-2008, EN 61000-3-2:2006, EN 61000-3-3:2008, GB 17625.1-2003 EMC
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
59.2 cm
63.9 cm
59.5 cm
63.7 kg
Shipping Width
76 cm
Shipping Depth
74.5 cm
Shipping Height
83.2 cm
Shipping Weight
76.5 kg
Sound Emission
53 dBA (operating)
15 °C
27 °C
10 - 70%
9HF5 HP 651A Black Original LaserJet Toner Cartridge In Stock £135.36
9HF5 HP 651A Cyan Original LaserJet Toner Cartridge In Stock £323.09
9HF5 HP 651A Yellow Original LaserJet Toner Cartridge In Stock £329.13
9HF5 HP 651A Magenta Original LaserJet Toner Cartridge In Stock £338.54
Functionality: Printer
Functionality: Scanner
Output Type: Colour
Technology: Laser
Max Print Speed: [N/A]
Max Paper Size: 320 x 470 mm
Brand: HP
Price Range Ex VAT: 1500+
