Enable large-volume printing on a wide range of paper sizes – up to A3 – with a 4,600-sheet maximum input capacity. Preview and edit scanning jobs; centrally manage printing policies; safeguard sensitive business information.
Empower teams to do more – print, scan, copy and fax on paper sizes up to A3 – from a desktop MFP
Stay focused on work – paper capacity up to 4,600 sheets and high-capacity cartridges limit interruptions.Get impressive document quality with near edge-to-edge printing and a convenient, built-in stapler.Print what you need, even on the go – from your smartphone or tablet – using HP ePrint or Apple Airprint . -
Quicken your business pace
Set a swift pace – use this powerful MFP to keep your work moving. Save time and make your job easier, using HP Quick Sets.Efficiently capture the right content: automatically remove blank pages, preview, edit and control jobs on the large colour touchscreen.Incorporate paper documents into digital workflows – easily send scans to fax, email, network folders or USB. Print right from a memory device via the USB port.
- HP LaserJet Enterprise MFP M725z+ - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 200000 impressions
- Recommended Monthly Volume
- 5000 - 20000 pages
- Max Copying Speed
- Up to 41 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 41 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 300 x 300 dpi, 400 x 400 dpi, 204 x 98 dpi, 204 x 196 dpi
- Scanning
- 600 x 600 dpi
- Display
- 8"
- Original Size
- A3 (297 x 420 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- 76.2 x 127 mm (min) - 312 x 469.9 mm (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, recycled paper, bond paper, film, heavy-weight paper
- Standard Media Capacity
- 4100 sheets
- Max Media Capacity
- 4600 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 750 sheets
- Collator
- Included
- Stacker
- Included
- Stapler
- Included
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host, USB host (internal)
- AirPrint Enabled
- Office Machine Features
- Document send function, save to USB flash drive, scan to e-mail, scan to network, Hardware Integration Pocket, Foreign Interface Harness (FIH)
- Power
- AC 230 V (50Hz)
- 74.5 cm x 68.1 cm x 119.2 cm
- 102.42 kg
- Environmental Standards
- ENERGY STAR Qualified, EPEAT Silver
- 1-year warranty
- Fax Type
- Plain paper
- Laser - monochrome
- Display Diagonal Size
- 8"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 1 GB
- Max Supported Memory
- 1.5 GB
Copying
- Max Copying Speed
- Up to 41 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 9999
- Copying Features
- Auto colour select
Printing
- Up to 41 ppm
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3, PDF
- Image Enhancement Technology
- HP FastRes 1200
- First Print Out Time B/W
- 10 sec
Scanning
- Scan Element
- CCD
- Optical Resolution
- 600 x 600 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- PC Faxing
Fax Machine Features
- Speed Dialing
- 100 station(s)
- Broadcast Transmission
- 100 stations
- Fax forwarding, automatic redialing, junk fax barrier, auto reduction, fax polling
Document & Media Handling
- Max Original Size
- A3 (297 x 420 mm)
- Original Type
- Sheets
- 100 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A3/Ledger
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 199 g/m²
- Supported Media Type
- Supported Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), 76.2 x 127 mm, JIS B6 (128 x 182 mm), 297 x 363 mm, 312 x 469.9 mm, 297 x 431 mm
- 4100 sheets
- 4600 sheets
- 100 sheets
- 750 sheets
- ADF - 100 sheets size: 68 x 148 mm - A3 (297 x 420 mm) , Bypass tray - 100 sheets size: 76.2 x 127 mm - 312 x 469.9 mm weight: 60 g/m² - 199 g/m² , Input tray - 250 sheets size: 148 x 210 mm - 297 x 363 mm weight: 60 g/m² - 120 g/m² , Input tray - 250 sheets size: 148 x 210 mm - 297 x 431 mm weight: 60 g/m² - 120 g/m² , Output tray - 250 sheets , Input tray - 3500 sheets size: 148 x 210 mm - 297 x 431 mm weight: 60 g/m² - 120 g/m² , Stacker / stapler - 500 sheets
- Speed Details
- Printing: up to 41 ppm (A4) - B/W normal , Printing: up to 28 ppm (A4) - B/W duplex , Printing: up to 20 ppm (A3) - B/W normal , Copying: up to 41 ppm (A4) - B/W normal , Scanning: up to 50 ppm (A4) - B/W , Scanning: up to 30 ppm (A4) - colour , Scanning: up to 19 ppm (A4) - B/W duplex , Scanning: up to 14 ppm (A4) - colour duplex
Finishing Equipment
- Collator
- Included
- Stacker
- Included
- Stapler
- Included
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 2 x USB host (internal) , 1 x Gigabit LAN - RJ-45
- Operating System Support
- MS Windows Server 2008 x64 Edition, MS Windows XP SP2 or later, MS Windows 7, MS Windows Vista, MS Windows Server 2008, Apple Mac OS X 10.6, Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2003 SP1 or later, Apple Mac OS X 10.8, Windows 8, MS Windows Server 2012 x64 Edition
- Software Included
- Drivers & Utilities, HP Web Jetadmin
- Voltage Required
- AC 230 V (50Hz)
- 890 Watt
- Power Consumption Standby
- 39 Watt
- Power Consumption Sleep
- 6.5 Watt
- Included Accessories
- Phone cable
- Consumables Included
- 1 x Cartridge (black) - up to 10000 pages
- EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class A, CISPR 22, EMC, IEC 60950-1, EN 60950-1, AES-256, IEC 60825-1, EN 60825-1
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- Limited warranty - 1 year
- 74.5 cm
- 68.1 cm
- 119.2 cm
- 102.42 kg
- Shipping Width
- 155.3 cm
- Shipping Depth
- 85.6 cm
- Shipping Height
- 76 cm
- Shipping Weight
- 122 kg
- Sound Emission
- 54 dBA (operating)
- 10 °C
- 32.5 °C
- 20 - 80%
HP 14A Black Original LaserJet Toner Cartridge | In Stock | £152.40 |
HP 14X High Yield Black Original LaserJet Toner Cartridge | In Stock | £167.99 |
