HP LaserJet Enterprise 700 M725z+ Mono Laser Multifunction Printer
Quicklinx: 8MBTWS00 Mfr#: CF069A#B19
Functionality: Copier, Fax, Scanner, Printer
Output Type: Monochrome
Wireless Capability: Wired
Technology: Laser
£3,648.82 ex VAT
£4,378.58 inc VAT
Enable large-volume printing on a wide range of paper sizes – up to A3 – with a 4,600-sheet maximum input capacity. Preview and edit scanning jobs; centrally manage printing policies; safeguard sensitive business information.
  • Empower teams to do more – print, scan, copy and fax on paper sizes up to A3 – from a desktop MFP
    Stay focused on work – paper capacity up to 4,600 sheets and high-capacity cartridges limit interruptions.Get impressive document quality with near edge-to-edge printing and a convenient, built-in stapler.Print what you need, even on the go – from your smartphone or tablet – using HP ePrint or Apple Airprint .
  • Quicken your business pace
    Set a swift pace – use this powerful MFP to keep your work moving. Save time and make your job easier, using HP Quick Sets.Efficiently capture the right content: automatically remove blank pages, preview, edit and control jobs on the large colour touchscreen.Incorporate paper documents into digital workflows – easily send scans to fax, email, network folders or USB. Print right from a memory device via the USB port.
HP LaserJet Enterprise MFP M725z+ - multifunction printer - B/W
Multifunction printer
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
200000 impressions
Recommended Monthly Volume
5000 - 20000 pages
Max Copying Speed
Up to 41 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 41 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 400 x 400 dpi, 204 x 98 dpi, 204 x 196 dpi
Scanning
600 x 600 dpi
Display
8"
Original Size
A3 (297 x 420 mm) (max)
Original Type
Sheets
Document Feeder Capacity
100 sheets
Media Size
76.2 x 127 mm (min) - 312 x 469.9 mm (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, recycled paper, bond paper, film, heavy-weight paper
Standard Media Capacity
4100 sheets
Max Media Capacity
4600 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
750 sheets
Collator
Included
Stacker
Included
Stapler
Included
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB host, USB host (internal)
AirPrint Enabled
Office Machine Features
Document send function, save to USB flash drive, scan to e-mail, scan to network, Hardware Integration Pocket, Foreign Interface Harness (FIH)
AC 230 V (50Hz)
74.5 cm x 68.1 cm x 119.2 cm
102.42 kg
Environmental Standards
ENERGY STAR Qualified, EPEAT Silver
1-year warranty
Fax Type
Plain paper
Printing Technology
Laser - monochrome
200000 impressions
5000 - 20000 pages
Display Diagonal Size
8"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
1 GB
Max Supported Memory
1.5 GB
Copying
Max Copying Speed
Up to 41 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
9999
Automatic Duplexing
Copying Features
Auto colour select
Printing
Max Printing Speed
Up to 41 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, PDF
Image Enhancement Technology
HP FastRes 1200
Automatic Duplexing
First Print Out Time B/W
10 sec
Scanning
Scan Element
CCD
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
PC Faxing
Fax Machine Features
Speed Dialing
100 station(s)
Broadcast Transmission
100 stations
Fax forwarding, automatic redialing, junk fax barrier, auto reduction, fax polling
Document & Media Handling
Max Original Size
A3 (297 x 420 mm)
Original Type
Sheets
100 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A3/Ledger
Min Media Weight
60 g/m²
Max Media Weight
199 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), 76.2 x 127 mm, JIS B6 (128 x 182 mm), 297 x 363 mm, 312 x 469.9 mm, 297 x 431 mm
4100 sheets
Max Media Capacity
4600 sheets
100 sheets
750 sheets
ADF - 100 sheets size: 68 x 148 mm - A3 (297 x 420 mm) , Bypass tray - 100 sheets size: 76.2 x 127 mm - 312 x 469.9 mm weight: 60 g/m² - 199 g/m² , Input tray - 250 sheets size: 148 x 210 mm - 297 x 363 mm weight: 60 g/m² - 120 g/m² , Input tray - 250 sheets size: 148 x 210 mm - 297 x 431 mm weight: 60 g/m² - 120 g/m² , Output tray - 250 sheets , Input tray - 3500 sheets size: 148 x 210 mm - 297 x 431 mm weight: 60 g/m² - 120 g/m² , Stacker / stapler - 500 sheets
Speed Details
Printing: up to 41 ppm (A4) - B/W normal , Printing: up to 28 ppm (A4) - B/W duplex , Printing: up to 20 ppm (A3) - B/W normal , Copying: up to 41 ppm (A4) - B/W normal , Scanning: up to 50 ppm (A4) - B/W , Scanning: up to 30 ppm (A4) - colour , Scanning: up to 19 ppm (A4) - B/W duplex , Scanning: up to 14 ppm (A4) - colour duplex
Finishing Equipment
Collator
Included
Stacker
Included
Stapler
Included
1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 2 x USB host (internal) , 1 x Gigabit LAN - RJ-45
Operating System Support
MS Windows Server 2008 x64 Edition, MS Windows XP SP2 or later, MS Windows 7, MS Windows Vista, MS Windows Server 2008, Apple Mac OS X 10.6, Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2003 SP1 or later, Apple Mac OS X 10.8, Windows 8, MS Windows Server 2012 x64 Edition
Software Included
Drivers & Utilities, HP Web Jetadmin
AC 230 V (50Hz)
890 Watt
Power Consumption Standby
39 Watt
Power Consumption Sleep
6.5 Watt
Phone cable
Consumables Included
1 x Cartridge (black) - up to 10000 pages
EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class A, CISPR 22, EMC, IEC 60950-1, EN 60950-1, AES-256, IEC 60825-1, EN 60825-1
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Limited warranty - 1 year
74.5 cm
68.1 cm
119.2 cm
102.42 kg
Shipping Width
155.3 cm
Shipping Depth
85.6 cm
Shipping Height
76 cm
Shipping Weight
122 kg
Sound Emission
54 dBA (operating)
10 °C
32.5 °C
20 - 80%
Functionality: Fax
Functionality: Scanner
Functionality: Printer
Technology: Laser
Max Print Speed: [N/A]
Max Paper Size: 312 x 469.9 mm
Brand: HP
Price Range Ex VAT: £1500+
