HP LaserJet Enterprise 700 M712xh Mono Laser Printer
Quicklinx: 8H3QWS00 Mfr#: CF238A#B19
Enable high-volume, black-and-white printing on paper sizes up to A3, with capacity up to 4,600 sheets. Control costs with energy-saving features and two-sided printing. Protect sensitive business data and centrally manage printing policies.
  • Upsize and accelerate with fast A3 printing
    Save time and keep business moving with exceptionally fast printing from this black-and-white A3 workgroup printer.Expand black-and-white printing options on paper sizes up to A3 with two-sided printing nearly to the edge of the page.Boost productivity – reload paper less often with up to 4,600-sheet capacity for high-volume printing.Replace toner cartridges easily. Choose high-capacity Original HP toner cartridges for frequent printing.
  • Conserve resources and help control costs
    Save energy – HP Auto On/Auto Off and Instant-on Technology help conserve energy,.Reduce paper use by up to 50% with automatic two-sided printing on this ENERGY STAR qualified printer.Original HP toner cartridges are easily recycled for free through HP Planet Partners.
  • Simplify IT management and safeguard data
    Boost printing and imaging safeguards and help protect business data with fleet-level security solutions.Safeguard confidential data stored on the printer, with the installed HP High-Performance Secure Hard Disk.Centralise printer management with HP Web Jetadmin which helps you monitor equipment and increase uptime.Add security solutions such as card and badge readers through the hardware integration pocket (HIP).
  • Invest in a forward-thinking, easy-to-use solution
    Extend the value of your investment – easily update and expand device capabilities with HP FutureSmart Firmware.Print from your smartphone or tablet from virtually anywhere with HP ePrint.Manage jobs at the colour control panel. The easy-access USB port lets you print from flash drives.
HP LaserJet Enterprise 700 Printer M712xh - printer - monochrome - laser
Printer Type
Workgroup printer - laser - monochrome
49.8 kg
English, German, French, Italian, Spanish / Europe
Media Size Class
A3/Ledger
Max Media Size
312 x 470 mm
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
312 mm x 470 mm
Print Speed
Up to 40 ppm - black normal - ANSI A (Letter) (216 x 279 mm) , Up to 41 ppm - black normal - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 dpi
Image Enhancement Technology
HP ProRes 1200 / HP FastRes 1200
Automatic Duplexing
USB, Gigabit LAN, USB host
AirPrint Enabled
800 MHz
RAM Installed (Max)
512 MB (1 GB)
Language Simulation
PCL 5E, PostScript 3, PCL 6, PDF 1.4
Media Type
Envelopes, transparencies, labels, plain paper, bond paper, recycled paper, card stock, vellum paper
Total Media Capacity
1100 sheets
Media Handling
100-sheet multipurpose tray, 500-sheet input tray, 2x 250-sheet input trays
Monthly Duty Cycle (max)
100000 pages
Recommended Monthly Volume
5000 - 20000 pages
Print server - Ethernet, Fast Ethernet, Gigabit Ethernet - integrated
Printer Features
Hardware integration pocket
AC 230V
Microsoft Windows XP SP2 or later, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6, Microsoft Windows Server 2003 SP1 or later, Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows Server 2008 (32/64-bits), Apple MacOS X 10.7 Lion, Microsoft Windows Vista / 7 / 8
Environmental Standards
EPEAT Silver
56.8 cm x 59.6 cm x 51.7 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
AirPrint Enabled
1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
10.5 sec
Language Simulation
Printer Features
Media Handling
800 MHz
RAM
RAM Installed (Max)
512 MB / 1 GB (max)
Media Handling
Media Type
Media Size Class
A3/Ledger
Max Media Size
312 x 470 mm
76.2 mm x 127 mm
312 mm x 470 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), 312 x 470 mm, 76.2 x 127 mm, 279.4 x 431.8 mm, 215.9 x 330.2 mm, 297.2 x 431.8 mm, 297 x 363 mm
Media Weight
60 g/m² - 199 g/m²
1100 sheets
Media Feeders
1 x automatic - 100 sheets - 312 x 470 mm weight: 60 g/m² - 199 g/m² , 1 x automatic - 250 sheets - 297 x 363 mm weight: 60 g/m² - 120 g/m² , 1 x automatic - 250 sheets - 297.2 x 431.8 mm weight: 60 g/m² - 120 g/m² , 1 x automatic - 500 sheets - 297.2 x 431.8 mm weight: 60 g/m² - 120 g/m²
Max Media Capacity
4600 sheets
Output Trays Capacity
250 sheets
Duty Cycle
100000 pages
5000 - 20000 pages
Print server - integrated
Network / Transport Protocol
ICMP/IP, LPR/LPD, FTP, BOOTP, DHCP, Bonjour, SLP
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, HTTPS, TFTP
Security Protocols & Features
Kerberos, Apple Bonjour, TLS, IPsec, 802.1x
1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 10000 pages
UL, cUL, GS, ICES-003, EN55024, EN55022 Class A, CISPR 22, EMC, FCC, Laser Class 1, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, IEC 60825-1, EN 60825-1, LVD, EN 61000-3-2:2006, EN 61000-3-3:2008
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
786 Watt
Power Consumption Stand by / Sleep
22.1 Watt
Software Included
Drivers & Utilities
System Requirements Details
Windows Server 2003/2008 - HD 200 MB , Windows XP/Vista/7/8 - HD 200 MB , MacOS X 10.6/10.7 - HD 200 MB
EPEAT Compliant
EPEAT Silver
ENERGY STAR
10 °C
32.5 °C
20 - 80%
Sound Emission (Operating)
54 dBA
56.8 cm
59.6 cm
51.7 cm
49.8 kg
Width (Shipping)
82.5 cm
Depth (Shipping)
80 cm
Height (Shipping)
107.4 cm
Weight (Shipping)
83.2 kg
8H3Q HP 14A Black Original LaserJet Toner Cartridge In Stock £147.66
8H3Q HP 14X High Yield Black Original LaserJet Toner Cartridge In Stock £162.76
