Enable high-volume, black-and-white printing on paper sizes up to A3, with capacity up to 4,600 sheets. Control costs with energy-saving features and two-sided printing. Protect sensitive business data and centrally manage printing policies.
Upsize and accelerate with fast A3 printing
Save time and keep business moving with exceptionally fast printing from this black-and-white A3 workgroup printer.Expand black-and-white printing options on paper sizes up to A3 with two-sided printing nearly to the edge of the page.Boost productivity – reload paper less often with up to 4,600-sheet capacity for high-volume printing.Replace toner cartridges easily. Choose high-capacity Original HP toner cartridges for frequent printing. -
Conserve resources and help control costs
Save energy – HP Auto On/Auto Off and Instant-on Technology help conserve energy,.Reduce paper use by up to 50% with automatic two-sided printing on this ENERGY STAR qualified printer.Original HP toner cartridges are easily recycled for free through HP Planet Partners. -
Simplify IT management and safeguard data
Boost printing and imaging safeguards and help protect business data with fleet-level security solutions.Safeguard confidential data stored on the printer, with the installed HP High-Performance Secure Hard Disk.Centralise printer management with HP Web Jetadmin which helps you monitor equipment and increase uptime.Add security solutions such as card and badge readers through the hardware integration pocket (HIP). -
Invest in a forward-thinking, easy-to-use solution
Extend the value of your investment – easily update and expand device capabilities with HP FutureSmart Firmware.Print from your smartphone or tablet from virtually anywhere with HP ePrint.Manage jobs at the colour control panel. The easy-access USB port lets you print from flash drives.
- HP LaserJet Enterprise 700 Printer M712dn - printer - monochrome - laser
- Printer Type
- Workgroup printer - laser - monochrome
- 38.5 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Media Size Class
- A3/Ledger
- Max Media Size
- 312 x 470 mm
- Min Media Size (Custom)
- 76.2 mm x 127 mm
- Max Media Size (Custom)
- 312 mm x 470 mm
- Print Speed
- Up to 40 ppm - black normal - ANSI A (Letter) (216 x 279 mm) , Up to 41 ppm - black normal - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 dpi
- Image Enhancement Technology
- HP ProRes 1200 / HP FastRes 1200
- Automatic Duplexing
- Interface
- USB, Gigabit LAN, USB host
- AirPrint Enabled
- Processor
- 800 MHz
- RAM Installed (Max)
- 512 MB (1 GB)
- Language Simulation
- PCL 5E, PostScript 3, PCL 6, PDF 1.4
- Media Type
- Envelopes, transparencies, labels, plain paper, bond paper, recycled paper, card stock, vellum paper
- Total Media Capacity
- 600 sheets
- Media Handling
- 100-sheet multipurpose tray, 2x 250-sheet input trays
- Monthly Duty Cycle (max)
- 100000 pages
- Recommended Monthly Volume
- 5000 - 20000 pages
- Networking
- Print server - Ethernet, Fast Ethernet, Gigabit Ethernet - integrated
- Printer Features
- Hardware integration pocket
- Power
- AC 230V
- System Requirements
- Microsoft Windows XP SP2 or later, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6, Microsoft Windows Server 2003 SP1 or later, Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows Server 2008 (32/64-bits), Apple MacOS X 10.7 Lion, Microsoft Windows Vista / 7 / 8
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- EPEAT Silver
- 56.8 cm x 59.6 cm x 39.2 cm
- Printer Type
- Localisation
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 10.5 sec
- Printer Features
- Media Handling
- Processor
- 800 MHz
RAM
- 512 MB / 1 GB (max)
Media Handling
- Media Type
- Media Size Class
- A3/Ledger
- Max Media Size
- 312 x 470 mm
- 76.2 mm x 127 mm
- 312 mm x 470 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), 312 x 470 mm, 76.2 x 127 mm, 279.4 x 431.8 mm, 215.9 x 330.2 mm, 297.2 x 431.8 mm, 297 x 363 mm
- Media Weight
- 60 g/m² - 199 g/m²
- 600 sheets
- Media Feeders
- 1 x automatic - 100 sheets - 312 x 470 mm weight: 60 g/m² - 199 g/m² , 1 x automatic - 250 sheets - 297 x 363 mm weight: 60 g/m² - 120 g/m² , 1 x automatic - 250 sheets - 297.2 x 431.8 mm weight: 60 g/m² - 120 g/m²
- Max Media Capacity
- 4600 sheets
- Output Trays Capacity
- 250 sheets
Duty Cycle
- 100000 pages
- Networking
- Print server - integrated
- Data Link Protocol
- ICMP/IP, LPR/LPD, FTP, BOOTP, DHCP, Bonjour, SLP
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, HTTPS, TFTP
- Kerberos, Apple Bonjour, TLS, IPsec, 802.1x
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 10000 pages
- UL, cUL, GS, ICES-003, EN55024, EN55022 Class A, CISPR 22, EMC, FCC, Laser Class 1, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, IEC 60825-1, EN 60825-1, LVD, EN 61000-3-2:2006, EN 61000-3-3:2008
- Power Device
- Power supply - internal
- Voltage Required
- AC 230V
- Frequency Required
- 50/60 Hz
- 786 Watt
- Power Consumption Stand by / Sleep
- 22.1 Watt
- Software Included
- Drivers & Utilities
- OS Required
- System Requirements Details
- Windows Server 2003/2008 - HD 200 MB , Windows XP/Vista/7/8 - HD 200 MB , MacOS X 10.6/10.7 - HD 200 MB
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR
- 10 °C
- 32.5 °C
- 20 - 80%
- Sound Emission (Operating)
- 54 dBA
- 56.8 cm
- 59.6 cm
- 39.2 cm
- 38.5 kg
- Width (Shipping)
- 81 cm
- Depth (Shipping)
- 78.5 cm
- Height (Shipping)
- 64.4 cm
- Weight (Shipping)
- 45.6 kg
HP 14A Black Original LaserJet Toner Cartridge | In Stock | £149.60 |
HP 14X High Yield Black Original LaserJet Toner Cartridge | In Stock | £170.63 |
