Product
Brand
HP LaserJet Custom Tray -Media Cassette for P4010/P4510 Prin
Quicklinx: 88KSWS00 Mfr#: CB527A
The 400-sheet Custom Media Tray gives you the flexibility to print small jobs on different media. It has been designed to support some of the smaller media sizes (as small as A6) that currently are not supported on the standard input tray.
HP media tray
Media tray
LaserJet P4014, P4014dn, P4014n, P4515n, P4515tn, P4515x, P4515xm; LaserJet Enterprise 600 M601dn, 600 M601m, 600 M601n, 600 M602dn, 600 M602m, 600 M602n, 600 M602x, 600 M603dn, 600 M603n, 600 M603xh
Media tray
59 cm x 43 cm x 24.5 cm / 3 kg
HP LaserJet P4014, P4014dn, P4014n, P4515n, P4515tn, P4515x, P4515xm , HP LaserJet Enterprise 600 M601dn, 600 M601m, 600 M601n, 600 M602dn, 600 M602m, 600 M602n, 600 M602x, 600 M603dn, 600 M603n, 600 M603xh
