HP LaserJet 5200tn Mono Laser Printer
HP LaserJet 5200TN
YOU BUY. YOU TRY. YOU DECIDE!
Quicklinx: 7S0NWS00 Mfr#: Q7545A#B19
Designed to deliver efficiency and versatility, this powerful wide-format A3+ monochrome laser printer is flexible and easily manageable to meet your office printing needs.
  • Get perfect results on media up to A3+ from this efficient monochrome HP LaserJet printer
    Get great results on media up to A3+ with this high performance mono HP LaserJet. It delivers fast print and first page out speeds, 460 MHz processor for handling complex print jobs, expandable memory up to 512 MB and industry-leading networking.
  • Supporting a wide range of solutions and media sizes, this printer keeps pace with your business
    Benefit from more options with this versatile printer. A3+ printing capabilities expand the printable area, CompactFlash support enables third-party solutions and the open EIO slot enhances productivity with the HP high-performance EIO hard disk.
  • Make your job easier with this simple and intuitive printer which is both easy to use and manage
    Experience worry-free printing, simple operation, and effortless printer management with tools like HP Web Jetadmin. Easily replace the HP all-in-one print cartridge that assures quality and reliability with its HP Smart printing technology.
HP LaserJet 5200tn - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
30.2 kg
Media Size Class
A3
Max Media Size
A3 (297 x 420 mm)
Max Media Size (Custom)
312 mm x 470 mm
Print Speed
Up to 35 ppm - black best - A4 (210 x 297 mm) , Up to 18.5 ppm - black normal - A3 (297 x 420 mm) , Up to 18.5 ppm - black best - A3 (297 x 420 mm) , Up to 35 ppm - black normal - A4 (210 x 297 mm) , Up to 35 ppm - black draft - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 dpi
Image Enhancement Technology
HP ProRes 1200 / HP FastRes 1200
Parallel, USB, LAN
MIPS 460 MHz
RAM Installed (Max)
64 MB (512 MB) - DDR SDRAM - DIMM 100-PIN
Language Simulation
PCL 5E, PostScript 3, PCL 6
Media Type
Envelopes, transparencies, labels, plain paper, cards, bond paper, recycled paper, vellum paper
Total Media Capacity
850 sheets
Media Handling
100-sheet multipurpose tray, 250-sheet input tray, 500-sheet input tray
Monthly Duty Cycle (max)
65000 pages
Print server - Ethernet, Fast Ethernet - integrated
Printer Features
Optional duplex
Apple MacOS X 10.2, Microsoft Windows 2000 / XP, Microsoft Windows Server 2003, Apple MacOS X 10.3, Apple MacOS X 10.4
Microsoft Certification
Certified for Windows Vista
49 cm x 60 cm x 40.5 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Up to 35 ppm - black best - 1200x1200 dpi - A4 (210 x 297 mm) , Up to 18.5 ppm - black normal - 1200x1200 dpi - A3 (297 x 420 mm) , Up to 18.5 ppm - black best - 1200x1200 dpi - A3 (297 x 420 mm) , Up to 35 ppm - black normal - 1200x1200 dpi - A4 (210 x 297 mm) , Up to 35 ppm - black draft - 600x600 dpi - A4 (210 x 297 mm)
Built-in Devices
Status LCD
Wired
Parallel, USB, LAN
1200 dpi
PostScript Support
Standard
First Print Out Time B/W
10 sec
Language Simulation
Fonts Included
93 x PostScript , 103 x PCL
Printer Features
Optional duplex
Media Handling
MIPS 460 MHz
RAM
RAM Installed (Max)
64 MB / 512 MB (max)
Technology / Form Factor
Slots Qty
1
Empty Slots
1
Media Handling
Media Type
Media Size Class
A3
Max Media Size
A3 (297 x 420 mm)
312 mm x 470 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), Folio (216 x 330 mm), 297 x 432 mm, Tabloid Extra (305 x 457 mm), JIS B5 (182 x 257 mm), 312 x 470 mm, Statement (139.7 x 215.9 mm), B6 (125 x 176 mm), 76.2 x 127 mm
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
Media Weight
60 g/m² - 199 g/m²
850 sheets
Media Feeders
1 x automatic - 100 sheets - 312 x 470 mm weight: 60 g/m² - 199 g/m² , 1 x automatic - 250 sheets - 297 x 432 mm weight: 60 g/m² - 120 g/m² , 1 x automatic - 500 sheets - 297 x 432 mm weight: 60 g/m² - 120 g/m²
Max Media Capacity
850 sheets
Output Trays Capacity
250 sheets
Duty Cycle
65000 pages
Print server - integrated
Network / Transport Protocol
AppleTalk
Expansion Slots
2 x CompactFlash Card , 1 x EIO
1 x parallel , 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B
Consumables Included
1 x toner cartridge (black) - up to 12000 pages
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
TUV, CISPR 22 Class A, EN 60950, EN 61000-3-2, ICES-003, IEC 60950, EN 61000-3-3, EN55024, EN55022 Class A, FCC Part 15 B, EMC
Power supply - internal
600 Watt
Power Consumption Stand by / Sleep
27 Watt
Software Included
Drivers & Utilities
System Requirements Details
Windows 98 - Pentium - 90 MHz - RAM 16 MB - HD 220 MB , Windows ME - Pentium - 150 MHz - RAM 32 MB - HD 220 MB , Windows 2000 - 133 MHz - RAM 64 MB - HD 220 MB , Windows XP - 233 MHz - RAM 64 MB - HD 220 MB , Windows Server 2003 - 550 MHz - RAM 128 MB - HD 220 MB , MacOS X 10.2 or later - HD 160 MB
Environmental Standards
ENERGY STAR
10 °C
32 °C
20 - 80%
Sound Emission (Idle)
31 dBA
Sound Emission (Operating)
54 dBA
49 cm
60 cm
40.5 cm
30.2 kg
Width (Shipping)
79.9 cm
Depth (Shipping)
73.1 cm
Height (Shipping)
60 cm
Weight (Shipping)
42.7 kg
7S0N HP 16A Black Original LaserJet Toner Cartridge In Stock £179.13
