Get productive print performance at an affordable price. Produce high-quality results, and print and scan from your phone.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
Uncompromising laser quality
This surprisingly small laser delivers exceptional quality, page after page. -
Sharp, black text
Produce sharp text, bold blacks, and crisp graphics. -
The right price
Rely on a high-performance laser printer at an affordable price. -
The power of your printer in the palm of your hand
Get simple setup, and print and scan from your phone, with the HP Smart app. -
Your device, your choice
Easily print from a variety of smartphones and tablets. -
Extend your printing reach
Easily share resources – access and print with wireless networking.
- HP Laser 107w - printer - B/W - laser
- Printer Type
- Personal printer - laser - B/W
- Number of Users
- 1-5 users
- 4.16 kg
- Localisation
- English, German, French, Italian, Spanish / Europe
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 20 ppm - B/W - A4 (210 x 297 mm) , Up to 21 ppm - B/W - ANSI A (Letter) (216 x 279 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Image Enhancement Technology
- Rendering Engine for Clean Pages (ReCP)
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Processor
- 400 MHz
- RAM Installed (Max)
- 64 MB (64 MB)
- Language Simulation
- SPL (Samsung Printer Language)
- Media Type
- Envelopes, labels, plain paper, bond paper, recycled paper, thick paper, thin paper, card stock, preprinted paper, archive paper, coloured paper
- Total Media Capacity
- 150 sheets
- Media Handling
- 150-sheet input tray
- Monthly Duty Cycle (max)
- 10000 pages
- Recommended Monthly Volume
- 100 - 1500 pages
- Networking
- Print server
- Printer Features
- Wireless Direct Print, Mopria certified, Auto Power Off
- System Requirements
- Microsoft Windows Server 2008 R2, Microsoft Windows 7 / Windows 8 / Windows Server 2008 / Windows Server 2012, Windows 8.1 (32/64 bits), Windows 10 (32/64 bits), Microsoft Windows Server 2016
- 1-year warranty
- 33.1 cm x 21.5 cm x 17.8 cm
- Printer Type
- Personal printer - laser - monochrome
- Number of Users
- 1-5 users
- Localisation
Printer
- Print Speed
- Connectivity Technology
- Wireless
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- 1200 x 1200 dpi
- First Print Out Time B/W
- 8.3 sec
- Printer Features
- Media Handling
- Processor
- 400 MHz
RAM
- 64 MB / 64 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 76 x 127 mm, Oficio (216 x 343 mm), JIS B6 (128 x 182 mm), RA4 (215 x 305 mm)
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- Media Weight
- 60 g/m² - 163 g/m²
- Media Weight (lbs)
- 16 lbs - 43 lbs
- 150 sheets
- Media Feeders
- 1 x automatic - 150 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray: 1 - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
- Output Trays Capacity
- 100 sheets
Duty Cycle
- 10000 pages
- 100 - 1500 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 1, SNMP 2, SNMP 3, HTTP, SLP, DHCP, IPv4, IPv6
- Apple Bonjour, IPsec, MAC address filtering, Wi-Fi Direct, IPv6 support
- Connections
- 1 x USB 2.0 - 4 pin USB Type B
- Cables Included
- 1 x USB cable
- Consumables Included
- 1 x toner cartridge (black)
- LED indicator
- GS, EMC, FCC CFR47 Part 15 B, ANSI C63.4-2009, GB 9254-2008, EN 62479:2010, CNS 13438, LVD 2006/95/EC, GB 17625.1-2012, EN 61000-3-3:2013, EN 55024:2010, CISPR 22:2008, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, ICES-003 issue 5, KN32, KN35, EN 55032:2012, IEC/EN 60825-1:2014 Class 1, CISPR 32:2012, T9254-2008 (Class A), EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 320 Watt
- Power Consumption Stand by
- 33 Watt
- Power Consumption Sleep
- 1.1 Watt
- Software Included
- Drivers & Utilities
- OS Required
- System Requirements Details
- Windows 7/8/8.1/10 - 1 GHz - RAM 1 GB - HD 16 GB
Environmental Standards
- Blue Angel
- Limited warranty - parts - 1 year
- 10 °C
- 30 °C
- 10 - 80% (non-condensing)
- 33.1 cm
- 21.5 cm
- 17.8 cm
- 4.16 kg
- Width (Shipping)
- 38.4 cm
- Depth (Shipping)
- 28 cm
- Height (Shipping)
- 26.1 cm
- Weight (Shipping)
- 5.7 kg
HP 106A Black Original Toner Cartridge | In Stock | £38.41 |
HP Glossy Laser Paper 150GSM 150 SHT/A4 | In Stock | £14.44 |
