HP L6017TM 17" 1280x1024 30ms 1280x1024 VGA DVI-D DisplayPort USB Retail Touchscreen Monitor
Quicklinx: 91GWWS00 Mfr#: A1X77AA
Diagonal Size: 17in
Max Resolution: 1280 x 1024
Response Time: 30ms
Speakers: Speaker(s)
Interfaces: DVI, USB, VGA (HD-15)
£584.39 ex VAT
£701.26 inc VAT
The sleek and stylish flush-bezel HP L6017tm 17-inch Retail Touch Monitor is designed for increased performance, enhanced usability, and outstanding durability in retail and hospitality environments.
  • Retail-ready
    The modernized appearance and sleek design add a wow factor to your retail environment. The chemically strengthened, flush- glass design is both stylish and easy to clean. White LED industrial panels offer improved brightness, extended product life, and energy efficiency. Anti-glare screens help make content and graphics easier to read in ambient light.
  • Flexible design
    Industry-standard, 100-mm VESA patterns enable flexible mounting in a variety of retail settings.
  • Technology that grows with you
    DisplayPort, DVI, and VGA video inputs enable legacy and future video technology compatibility; integrated speakers eliminate the need for separate hardware.
HP L6017tm Retail Touch Monitor - LED monitor - 17"
LED-backlit LCD monitor - 17"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 60 Hz
Pixel Pitch
0.264 mm
Brightness
225 cd/m²
Contrast Ratio
800:1
Speakers
Integrated
Screen Coating
Anti-glare, anti-static
Jack black
38.6 cm x 28.3 cm x 42.3 cm
6.8 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
CSA, UL, VCCI, C-Tick, BSMI, CCC, FCC, ICES, S Mark, CECP, BFR
3-year warranty
Display Type
Diagonal Size
17"
Viewable Size
17"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.264 mm
Brightness
225 cd/m²
Contrast Ratio
800:1
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
24 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
WLED
Colour Temperature
6500K
Controls & Adjustments
Brightness, contrast, colour temperature
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Japanese
Jack black
38.6 cm x 28.3 cm x 42.3 cm - with stand
6.8 kg
Audio
Speakers - stereo - integrated
VGA , DisplayPort (HDCP) , DVI-D (HDCP) , 4 x USB 2.0 , USB upstream , Audio line-in
1 x VGA cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 2 x DVI cable - 1.8 m , 1 x USB cable - 1.8 m , 1 x audio cable - 1.8 m
39 Watt
Power Consumption Stand by / Sleep
1 Watt
Microsoft Windows XP Professional, Microsoft Windows Embedded for Point of Service, Microsoft Windows 7 Professional (32/64 bits), Microsoft Windows Embedded POSReady, Microsoft Windows Vista Business 32-bit Edition
Dimensions & Weight Details
With stand - width: 38.6 cm - depth: 28.3 cm - height: 42.3 cm - weight: 6.8 kg , Without stand - width: 38.6 cm - depth: 5.8 cm - height: 33.9 cm - weight: 4.7 kg
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
5 °C
20 - 80% (non-condensing)
HP L6017TM 17 Bundle deal on HP L6017TM 17" 1280x1024 30ms 1280x1024 VGA DVI-D DisplayPort USB Retail Touchscreen Monitor
£683.56
Diagonal Size: 17in
Response Time: 30ms
Interfaces: DVI
Interfaces: USB
Interfaces: VGA (HD-15)
Brand: HP
Price Range Ex VAT: 500 - 750
