Product
Brand
HP Keyboard Dual Point Stick UK
Quicklinx: BBL9WS00 Mfr#: 730794-031
This keyboard can be used as a replacement for your original laptop keyboard, if the original is damaged or broken. The keyboards are very easy to fit, with no soldering required.
HP - keyboard - UK
Keyboard
Backlit
Layout
Pointing stick, spill-resistant, DualPoint, DuraKeys
EliteBook 840 G1, 850 G1
Keyboard
Backlit
Input Device
Layout
1 x keyboard cable , 1 x pointing stick cable
HP EliteBook 840 G1, 850 G1
