The ideal solution for IT managers and printer administrators in small, medium, and large businesses who want to share HP EIO-based peripherals across their Ethernet/Fast Ethernet networks
- Any HP EIO-based peripheral, HP Print Server Appliance
- Advanced security
- High performance
- Compatible and flexible
With advanced security and industry-leading performance, the HP Jetdirect 620n Fast Ethernet internal print server lets businesses easily and affordably share HP printers with EIO slots across the network and the Internet. High security networking equals a more secure network printer. The HP Jetdirect 620n Fast Ethernet print server supports 802.1X authentication to protect access to your network. Provides enhanced security for network configuration and management, including password-protected configuration, Secure Sockets Layer (SSL), Transport Layer Security (TLS), and Simple Network Management Protocol (SNMP) Version 3 to keep your network safe. The HP Jetdirect 620n Fast Ethernet print server lets you boost uptime with throughput speeds of up to 6 MB per second, letting you maintain high performance on your network. Take advantage of 4 MB flash upgradable memory for easy access to future firmware enhancements for your HP Jetdirect 620n Fast Ethernet print server-stay up-to-date without the hassle. The modular internal design of the HP Jetdirect 620n Fast Ethernet print server slides into the EIO slot of any compatible HP peripheral, reducing the number of cables needed for printer connectivity.
Designed and tested for optimal performance with HP EIO peripherals, the HP Jetdirect 620n Fast Ethernet print server lets you quickly and easily share networked peripherals. Protect your investment with highly dependable and affordable network printing backed by a limited one-year HP warranty. With the HP Jetdirect 620n Fast Ethernet print server, connect to a wide variety of network operating systems, including Microsoft, Novell, Apple, UNIX, and Linux. You will also enjoy support for a range of network protocols, including TCP/IP (IP Direct Mode, LPD, FTP, IPP), IPX/SPX, DLC/LLC, and AppleTalk. Quickly and easily install and configure shared peripherals with the HP Install Network Printer Wizard. Use the HP Embedded Web Server to enjoy simple, one-to-one configuration and management from any standard Web browser. Additionally, you can take advantage of scalable support for easy peripheral installation and management using HP Web Jetadmin. Experience flexibility in office layout and peripheral placement without the need for a PC file server.
Product Type : Print Server
Product Family : JetDirect
