Brand
HP Integrated Work Center Stand - Monitor/desktop stand - 17"-2
Quicklinx: DD2RWS00 Mfr#: G1V61AT
Type: Stand
27 in stock
£138.35 ex VAT
£166.02 inc VAT
Make the most of small work spaces with an HP IWC Desktop Mini/Thin Client that lets you create a compact desktop solution by combining a display with an HP Desktop Mini, HP Thin Client or HP Chromebox and giving you convenient front access to all of its inputs.
  • No more reaching around
    Save time and work smarter with easy front access to your platform's inputs, connectors, and power buttons. Even better, you don't have to move the entire IWC around during the day to get to them.
  • Keep it clean
    Run your display and platform cables through the IWC's guides. Secure the HP Desktop Mini or HP Chromebox power brick out of the way in the brick holder on the back of the stand.
  • Work comfortably throughout the day
    Find your best viewing position with adjustable height, tilt, and swivel adjustment settings.
  • Pair with your choice of display and platform
    Enjoy compatibility with a wide range of monitors, including most of the HP Pro and Elite portfolios and an HP Desktop Mini, HP Thin Client or HP Chromebox.
HP Integrated Work Center Stand - monitor/desktop stand
Package Content
VGA cable, mounting bracket
41.1 cm x 25.9 cm x 27.4 cm
2.6 kg
Display Screen Size Compatibility
17"-24"
Tilt adjustment, swivel adjustment, adjustable height, HP Quick Release, VESA interface support
HP 260 G1, 260 G2, LV2011, LV241, t310, t310 G2, t430, t430 v2, t530, t540, t628, V201, V206, V241, Z24; Chromebox G2; EliteDesk 705 G1, 705 G3, 800 G1, 800 G2; EliteDisplay E190, E221, E231, E23123, E241; Flexible t520; ProDesk 400 G1, 400 G2, 400 G3, 600 G1, 600 G2, 600 G3; ProDisplay P17, P231
Package Content
41.1 cm
25.9 cm
27.4 cm
2.6 kg
17"-24"
Weight Limit
5 kg
VESA FDMI, RoHS
Limited warranty - 1 year , Technical support - phone consulting - 1 year
HP 260 G1 (mini desktop), 260 G2, L2401x, LE1711, LV2011, LV2011q, LV241, t310 (all-in-one), t310 G2, t430, t430 v2, t530, t540, t628, V201, V201a, V206hz, V241, V241a, V241P, Z22i, Z23i, Z24i, ZR2040w, ZR2240W, ZR2330w, ZR2440W , HP Chromebox G2 , HP EliteDesk 705 G1 (micro tower, mini desktop), 705 G3 (mini desktop), 800 G1 (mini desktop), 800 G2 (mini desktop) , HP EliteDisplay E190i, E201, E221, E221c, E221i, E231, E23123, E231e, E231i, E241i , HP Flexible t520 , HP ProDesk 400 G1 (mini desktop), 400 G2 (mini desktop), 400 G3 (mini desktop), 600 G1 (mini desktop), 600 G2 (mini desktop), 600 G3 , HP ProDisplay P17A, P191, P19A, P201, P201m, P221, P231 , HP Compaq L2206tm, L2311c, L2311c Notebook Docking Monitor, LA1956x, LA2405x, LE1711, LE1911, LE1911i
Type: Stand
Brand: HP
Stock Status: In stock
