Make the most of small work spaces with an HP IWC Desktop Mini/Thin Client that lets you create a compact desktop solution by combining a display with an HP Desktop Mini, HP Thin Client or HP Chromebox and giving you convenient front access to all of its inputs.
No more reaching around
Save time and work smarter with easy front access to your platform's inputs, connectors, and power buttons. Even better, you don't have to move the entire IWC around during the day to get to them. -
Keep it clean
Run your display and platform cables through the IWC's guides. Secure the HP Desktop Mini or HP Chromebox power brick out of the way in the brick holder on the back of the stand. -
Work comfortably throughout the day
Find your best viewing position with adjustable height, tilt, and swivel adjustment settings. -
Pair with your choice of display and platform
Enjoy compatibility with a wide range of monitors, including most of the HP Pro and Elite portfolios and an HP Desktop Mini, HP Thin Client or HP Chromebox.
- HP Integrated Work Center Stand Desktop Mini / Thin Clients - monitor/desktop stand
- Product Type
- Monitor/desktop stand
- Package Content
- VGA cable, mounting bracket
- 41.1 cm x 25.9 cm x 27.4 cm
- 2.6 kg
- Display Screen Size Compatibility
- 17"-24"
- Tilt adjustment, swivel adjustment, adjustable height, HP Quick Release, VESA interface support
- Limited lifetime warranty
- Designed For
- HP 260 G1, 260 G2, t310, t310 G2, t430, t430 v2, t530, t540, t628, V201, V206, V241, Z24; Chromebox G2; Elite 600 G9, 800 G9, t655; EliteDesk 705 G1, 705 G3, 800 G1, 800 G2; EliteDisplay E221, E231, E23123, E241; Flexible t520; Pro t550; ProDesk 400 G1, 400 G2, 400 G3, 600 G1, 600 G2, 600 G3
- Product Type
- Package Content
- 41.1 cm
- 25.9 cm
- 27.4 cm
- 2.6 kg
- Shipping Dimensions (WxDxH) / Weight
- 48 cm x 33.2 cm x 32.5 cm
- 17"-24"
- VESA FDMI
- Limited warranty: - 1 year , Technical support: phone consulting
- Designed For
- HP 260 G1 (mini desktop), 260 G2, L2401x, LE1711, LV2011, LV2011q, LV241, t310 (all-in-one), t310 G2, t430, t430 v2, t530, t540, t628, V201, V201a, V206hz, V241, V241a, V241P, Z22i, Z23i, Z24i, ZR2040w, ZR2240W, ZR2330w, ZR2440W , HP Chromebox G2 , HP Elite 600 G9, 800 G9, t655 , HP EliteDesk 705 G1 (micro tower, mini desktop), 705 G3 (mini desktop), 800 G1 (mini desktop), 800 G2 (mini desktop) , HP EliteDisplay E190i, E201, E221, E221c, E221i, E231, E23123, E231e, E231i, E241i , HP Flexible t520 , HP Pro t550 , HP ProDesk 400 G1 (mini desktop), 400 G2 (mini desktop), 400 G3 (mini desktop), 600 G1 (mini desktop), 600 G2 (mini desktop), 600 G3 , HP ProDisplay P17A, P191, P19A, P201, P201m, P221, P231 , HP Compaq L2206tm, L2311c, L2311c Notebook Docking Monitor, LA1956x, LA2405x, LE1711, LE1911, LE1911i
