Virtual graphical console
Integrated Lights-Out Advanced provides embedded hardware Graphical Remote Console capabilities that can turn a supported browser into a virtual desktop, giving the user full control over the display, keyboard, and mouse of the host server. The operating system-independent console supports graphic modes that display remote host server activities, such as shutdown and startup operations. It works with a standard browser and no additional software is required on the remote server or client system. -
Virtual media (Virtual Floppy and CD)
The USB-based Virtual Media feature allows an IT administrator to boot the remote server using a standard 1.44-MB diskette on the client machine, a CD on the client machine, or an image of the floppy from anywhere on the client's network. After the remote server has booted a USB-capable operating system, the virtual floppy or CD is available as if it were a local USB device. The Virtual Media features save time and increase efficiency by eliminating the need to visit the remote server just to insert and use a diskette or CD. -
Directory integration for user management
The Integrated Lights-Out integrates with enterprise-class directory services to provide secure, scalable, and cost effective user management. Directory services, such as Microsoft Active Directory and Novell eDirectory, can be used to authorize directory users with assigned user roles to Integrated Lights-Out processors. An easy and reliable installation program is available to install a management console snap-in and extend customer's existing directory schema to enable directory support for the HP lights-out management products. A directory migration tool is available to automate the integration of existing HP lights-out management devices to directory services.
- HPE Integrated Lights-Out Advanced - licence + 1 Year 24x7 Support - 1 licence
- Product Type
- Licence
- Category
- Networking applications - system & remote management
- Licence Qty
- 1 licence
- Bundled Support
- 1 Year 24x7 Support
- Distribution Media
- Electronic
- New releases update
- Designed For
- ProLiant DL160 Gen10, DL180 Gen10, DL20 Gen10, DL380 Gen9, DX360 Gen10, MicroServer Gen8, ML30 Gen10, ML310e Gen8, SL250s Gen8, SL270s Gen8, XL170r Gen9, XL190r Gen9, XL290n Gen10, XL2x260w, XL740f Gen9
- Category
- Product Type
- Licence
- Bundled Support
- Electronic
Licencing
- Licence Qty
- 1 licence
- New releases update - 1 year , Technical support - 1 year - availability: 24 hours a day / Monday-Sunday
- Designed For
- HPE ProLiant DL160 Gen10 Base, DL160 Gen10 Entry, DL180 Gen10, DL180 Gen10 Base, DL20 Gen10, DL20 Gen10 Entry, DL20 Gen10 Performance, DL20 Gen10 Plus, DL20 Gen10 Plus Base, DL20 Gen10 Plus Entry, DL20 Gen10 Plus High Performance, DL20 Gen10 Plus Performance, DL20 Gen10 solution, DL380 Gen9 High Performance, DX360 Gen10 Plus, MicroServer Gen8 Base, MicroServer Gen8 Base Starter Kit, MicroServer Gen8 Entry, ML30 Gen10 Plus, ML30 Gen10 Plus Entry, ML30 Gen10 Plus Performance, ML310e Gen8 v2, ML310e Gen8 v2 Base, ML310e Gen8 v2 Enty, ML310e Gen8 v2 Performance, SL250s Gen8 2U Left Half Width Tray, SL250s Gen8 2U PCIe Gen3 Left Tray, SL250s Gen8 2U Right Half Width Tray, SL250s Gen8 Base 2U Left Half Width Tray, SL250s Gen8 Base 2U Right Half Width Tray, SL270s Gen8 1U Left Half Width Tray, SL270s Gen8 1U Right Half Width Tray, XL170r Gen9, XL190r Gen9, XL290n Gen10 Plus, XL2x260w, XL740f Gen9
