Count on the fast print speeds up to 20 ppm, automatic two-sided printing, and reliable Wi-Fi connectivity. Choose HP+ and get 6 months of Instant Ink and 1 extra year of HP warranty with exclusive use of Original HP Ink.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
Customisable shortcuts on your phone
Eliminate steps in repetitive tasks with Shortcuts in HP Smart app. -
Hands-free. Auto-fed
Work fast and hands-free with the 35 page auto-feeder. -
Ready when you are
Connect to cloud-based printing with Wi-Fi or your cellular network. -
Printing just got more productive
Quickly access and print documents and images on your smartphone, from Dropbox and Google Drive. -
Your reliable connection
Reduce interruptions with self-healing Wi-Fi that keeps you connected.
- HP Officejet Pro 8025e All-in-One - multifunction printer - colour - HP Instant Ink eligible
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- United Kingdom, Ireland
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 4-ink
- Monthly Duty Cycle (max)
- 20000 pages
- Recommended Monthly Volume
- 800 pages
- Max Copying Speed
- Up to 13 ppm (mono) / up to 7 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Up to 20 ppm (mono) / up to 10 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
- Scanning
- 1200 x 1200 dpi
- Display
- 2.7"
- Original Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper, photo paper, thick paper, card stock, glossy paper, matte paper
- Standard Media Capacity
- 225 sheets
- Max Media Capacity
- 225 sheets
- Output Trays Capacity
- 60 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n)
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, scan to e-mail, embedded web browser, Mopria certified, scan to SharePoint, HP Auto-On/Auto-Off Technology, HP Instant Ink, IPP printing, scan to network folder
- Power
- AC 120/230 V (50/60Hz)
- 46 cm x 34.12 cm x 23.4 cm
- 8.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Fax Type
- Plain paper
- Ink-jet - colour
- 20000 pages
- 800 pages
- Display Diagonal Size
- 2.7"
- Display Colour Support
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 256 MB
- Max Supported Memory
- 256 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- ID Card Copy, collation copy, margin shift, 2-sided copy orientation change, resize
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Nozzle Configuration
- 1760 nozzles
- Ink Cartridge Configuration
- 4 cartridges (1 each: pigment cyan, pigment magenta, pigment yellow, pigment black)
- Ink Palette Supported (Colours)
- Pigment cyan, pigment magenta, pigment yellow, pigment black
- 4-ink
- Printer Drivers / Emulations
- PCL 3 GUI
- First Print Out Time B/W
- 13 sec
- First Print Out Time Colour
- 16 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 100 pages
- Fax Printing Speed
- Up to 15 ppm
- Fax Printing Resolution
- 203 x 196 dpi
- PC Faxing
Fax Machine Features
- Speed Dialing
- 99 station(s)
- Delayed Transmission
- Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), delayed sending
Document & Media Handling
- Min Original Size
- 76.2 x 127 mm
- Max Original Size
- Original Type
- Sheets
- 35 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 280 g/m²
- Min Media Weight (lb)
- 16 lbs
- Max Media Weight (lb)
- 110 lbs
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76.2 x 127 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- Borderless Photo Sizes
- 225 sheets
- 225 sheets
- 60 sheets
- ADF - 35 sheets - Legal (216 x 356 mm) , Input tray - 225 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m² , Output tray - 60 sheets
- Speed Details
- Printing: up to 20 ppm (A4) - B/W (ISO) , Printing: up to 10 ppm (A4) - colour (ISO) , Printing: up to 29 ppm (A4) - B/W draft , Printing: up to 25 ppm (A4) - colour draft , Copying: up to 29 ppm (A4) - B/W draft , Copying: up to 23 ppm (A4) - colour draft , Scanning: up to 8 ppm (A4) - B/W , Scanning: up to 3.5 ppm (A4) - colour , Copying: up to 3 ppm (A4) - B/W best , Copying: up to 2 ppm (A4) - colour best
- 1 x modem - RJ-11 , 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B
- SSL, TLS, WPA2, 802.1x, EAP-TLS, PEAP, WPA2-Enterprise
- Operating System Support
- Linux, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2012 x64 Edition, MS Windows Server 2008 R2 x64 Edition SP1, MS Windows Server 2012 R2 x64 Edition, MS Windows 7 (32/64 bits), Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Chrome OS, Apple Mac OS X 10.11, MS Windows Server 2016, macOS 10.13, macOS 10.12.x
- Software Included
- Software HP Printer
- Voltage Required
- 21 Watt
- Power Consumption Standby
- 5.8 Watt
- Power Consumption Sleep
- 1 Watt
- First Copy Out Time B/W
- 18 sec
- First Copy Out Time Colour
- 12 sec
- Consumables Included
- 1 x ink cartridge (black) - HP 912 , 1 x ink cartridge (cyan) - HP 912 , 1 x ink cartridge (magenta) - HP 912 , 1 x ink cartridge (yellow) - HP 912
- FCC CFR47 Part 15 B, EN 61000-3-3:2013, CISPR 24:2010, EN 55024:2010, EN 301 489-1, EN 61000-3-2:2014, IEC60950-1:2005, Second edition + Am1:2009 + Am2:2013, UL 62368-1 Second Edition, ICES-003 issue 6 Class B, CISPR 32:2012, EN 301 489-17, EN 55032:2012 Class B, IEC 62368-1: 2014 Second Edition, RED 2014/53/EU, EN 62368-1:2014+A11:2017, ES 203 021-2, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
- ENERGY STAR Certified
- Limited warranty - parts - 1 year , Technical support - web support - 1 year
- 46 cm
- 34.12 cm
- 23.4 cm
- 8.2 kg
- Shipping Width
- 50.6 cm
- Shipping Depth
- 29.8 cm
- Shipping Height
- 40.8 cm
- Shipping Weight
- 10.4 kg
- Sound Emission
- 62 dBA (operating)
- 5 °C
- 40 °C
- 20 - 80%
Ink (6)
HP 912 Black Original Ink Cartridge | In Stock | £12.04 |
HP 912 Magenta Original Ink Cartridge | In Stock | £7.22 |
HP 912 Yellow Original Ink Cartridge | In Stock | £7.22 |
HP 912XL High Yield Black Original Ink Cartridge | In Stock | £26.87 |
HP 912XL High Yield Cyan Original Ink Cartridge | In Stock | £14.12 |
HP 912XL High Yield Magenta Original Ink Cartridge | In Stock | £14.12 |
