Enjoy the thin, light, and cost effective HP EliteBook 755. Be ultra-productive by staying connected with impressive collaboration and connectivity features for your growing business on the HP EliteBook 755.
Slim new design with all the right ports
Connect with all of the essential ports you need without the hassle of dongles - in an ultra-slim design. At just 19.4 mm, the HP EliteBook 755 comes with VGA, Display Port, RJ-45 and enterprise docking capabilities.
Strong security, powerful manageability
Protect, detect, and recover from malicious attacks with HP Sure Start - the industry’s first self-healing BIOS. Keep your team up and running with HP Touchpoint Manager and DASH manageability to help monitor the HP EliteBook 755.
Designed for collaboration
Replace your speaker phone with the HP EliteBook 755 with Audio by Bang & Olufsen that provides a rich collaboration experience for applications like Skype for Business.
Great features and value, from HP!
The ultrathin HP EliteBook 755 delivers tremendous value. HP is the first to offer the new high-performance AMD PRO A12 APU, featuring integrated Radeon™ R7 graphics that help harness the full potential of your applications.
Key Features
Let nothing stand in your way
Power through your day with Windows 10 Pro and the powerful, sleek, thin, and light touch optional HP EliteBook 755.
Self-healing safeguard
HP Sure Start detects attacks, corruption and self-heals the BIOS automatically.
Give your fingers a break
Keep focused without the distraction of a noisy keyboard using the HP Premium Keyboard with numeric keypad engineered for comfort.
Field ready
Stand up to the workload with an EliteBook that passed MIL-STD 810G testing.
In-house serviceability
Easily expand your system’s serviceable components.
Give your speakers a boost
Help make good speakers sound great with HP Clear Sound Amp.
Cut out the chatter
Help suppress ambient noise including keyboard clicks with HP Noise Reduction Software.
AMD Vivid Color Technology
Experience the brilliant color saturation that makes images come to life with AMD Vivid Color Technology.
Power through your day with Windows 10 Pro and the powerful, sleek, thin, and light touch optional HP EliteBook 755. -
HP Sure Start detects attacks, corruption and self-heals the BIOS automatically. -
Keep focused without the distraction of a noisy keyboard using the HP Premium Keyboard with numeric keypad engineered for comfort. -
Field ready
Stand up to the workload with an EliteBook that passed MIL-STD 810G testing. -
Easily expand your system's serviceable components. -
- HP EliteBook 755 G3 Notebook - 15.6" - AMD A12 - PRO-8800B - 8 GB RAM - 256 GB SSD - 4G LTE - UK
- Product Type
- Notebook
- Operating System
- Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
- Processor
- AMD A12 PRO-8800B / 2.1 GHz, up to 3.4 GHz / 2 MB Cache
- Memory
- 8 GB DDR3L (1 x 8 GB)
- Storage
- 256 GB SSD
- Display
- 15.6" LED backlight 1920 x 1080 / Full HD
- Graphics
- AMD Radeon R7
- Input Device
- Pointing stick
- Keyboard
- UK
- Keyboard Backlight
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
- Wireless Broadband (WWAN)
- 4G LTE
- Service Provider
- HP Mobile Connect
- Battery
- 3-cell - up to 8.5 hours
- Dockable
- Security
- Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
- 38.33 cm x 25.77 cm x 1.94 cm
- 1.88 kg
- Localisation
- Environmental Standards
- - ENERGY STAR Qualified
- Limited warranty - 3 years , Limited warranty - battery - 3 years
- Product Type
- Notebook
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.4 GHz
- Number of Cores
- Quad-Core
- Cache
- L2 - 2 MB
- 64-bit Computing
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz / PC3L-12800
- Rated Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD M.2 SATA 6Gb/s
Display
- 15.6" - TN
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Brightness
- 300 cd/m²
- Slim Design, Full HD standard-viewing angle (SVA) eDP anti-glare
Audio & Video
- Graphics Processor
- AMD Radeon R7
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - 1280 x 720
- Sound
- Stereo speakers, two microphones
- Codec
- ALC3228
- DTS Studio Sound
- Audio Features
- Output: Bang & Olufsen Audio, HP Clear Sound Amp
Input
- Keyboard, touchpad, pointing stick
- Keyboard Layout
- UK
- Numeric Keypad
- Spill-resistant, touchpad with gesture support
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 7265 - PCI Express Mini Card (M.2)
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Broadcom BCM5762
- Miracast
- Wi-Fi CERTIFIED
- Generation
- 4G
- Technology
- GPRS, EDGE, LTE, DC-HSPA+, CDMA 2000 1X EV-DO Rev. B
- Controller
- HP lt4120 - M.2 Card
- Max Transfer Rate
- 150 Mbps
- Service Provider
- HP Mobile Connect
Navigation
- Receiver
- A-GPS/GLONASS
- Technology
- 3-cell Lithium Ion
- Capacity
- 46 Wh
- Run Time
- Up to 8.5 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19.5 V
Connections & Expansion
- Slots
- 1 x SIM card (1 free)
- Interfaces Details
- 2 x USB 3.0 , USB-C , DisplayPort , VGA , LAN , Dock , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- Drivers & Utilities, HP Recovery Disc Creator, Skype, LANDesk Management Suite, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, CyberLink YouCam BE, CyberLink PowerDVD BD Edition, HP Systems Software Manager, Foxit PhantomPDF Express, HP Secure Erase, HP Security Manager, HP BIOSphere, HP GPS and Location, HP Client Catalog, HP Pixel Sharp, HP Driver Packs, HP BIOS Config Utility, HP CIK for Microsoft SCCM, HP Noise Reduction Software
- Case Material
- Magnesium-aluminum alloy
- Dockable
- Security
- HP 3D DriveGuard, HP DuraKeys, HP BIOS Protection, HP SureStart, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, 1 USB 3.0 charging port
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- ACPI
- Localization
- 1.88 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
