HP Height Adjustable Stand for All-In-One
Quicklinx: CF5PWS00 Mfr#: T0E53AA
Customize a unique workspace with the HP ProOne 400 G2 AIO Height Adjustable Stand, which allows you to position your HP All-in-One for maximum comfort in a range of settings.
• Always within reach
• Plan ahead with expansive compatibility
• Create your comfort zone
• Easy assembly
    Find your best viewing height with up to four inches of vertical travel.
    Find your best screen viewing height with up to four inches of vertical travel, and use the stand to rotate your AiO for portrait views of your content.
  • Easy assembly
    Simply attach your AiO to the VESA bracket on the stand. The sturdy design is built to withstand up to 10,000 lift mechanisms.
  • Rest easy
    Get the reassurance of a one-year limited warranty.
HP Height Adjustable Stand - stand kit
Stand kit
41.9 cm x 23.1 cm x 24 cm
Tilt
-5° to 20°
Pan
180°
Lift
12.7cm
Rotation
90°
Adjustments
Height, pan, tilt
2.8 kg
Recommended Use
All-In-One
Flat Panel Mount Interface
100 x 100 mm
Asteroid
ProOne 400 G2, 400 G3
41.9 cm
23.1 cm
24 cm
2.8 kg
Asteroid
AV Furniture
Stand kit
Recommended Use
All-In-One
100 x 100 mm
Tilt
-5° to 20°
Pan
180°
Lift
12.7cm
Rotation
90°
Adjustments
Height, pan, tilt
HP ProOne 400 G2, 400 G3
