HP Healthcare Edition HC271 27" 2560x1440 12ms VGA HDMI DisplayPort LED Monitor
Quicklinx: F6W6WS00 Mfr#: 3ME70AA#ABU
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 12ms
Speakers: None
Interfaces: HDMI, VGA (HD-15), DisplayPort
£686.00 ex VAT
£823.20 inc VAT
Deploy a display optimized for patient rooms, nurses stations, medical carts, and public areas with the HP Healthcare Edition HC271. It's built for easy, repeatable sanitization after every patient engagement and is DICOM Part 14 compliant for accurate viewing of medical images.
  • Promote patient safety
    Be ready for the next patient or user with a display and optional stand that are sanitizable with germicidal wipes. The display is IEC 60601-1-2: 2014 compliant for use near patients and staff and the front is IP 32 rated against water ingress.
  • Out-of-the box image accuracy
    Help ensure accurate, consistent image viewing between healthcare professionals and for patient consultations and image verification with a DICOM Part 14 compliant display. View up to 60% more content at one time on the Quad HD 27" diagonal screen.
  • Create an efficient workspace for high-traffic areas
    Attach select HP PCs behind the display for a compact, integrated solution that's perfect for busy and shared spaces like nurses or charting stations. Mount on a medical cart, wall or arm with the VESA pattern.
HP HC271 Clinical Review Monitor - Healthcare - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
45 kWh
Power Consumption (On mode)
31 W
USB 3.0 hub
Panel Type
AHVA
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
12 ms (grey-to-grey)
Input Connectors
HDMI, VGA, DisplayPort
Screen Coating
Anti-glare
Voltage
White
64.4 cm x 19.7 cm x 39.3 cm
7.16 kg
English / United Kingdom
Plug and Play, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, CECP, EAC, ISC, low halogen, CE/EMC
Display Type
Energy Class
Class B
45 kWh
Diagonal Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
AHVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2331 mm
Pixel Per Inch
108.79
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Mercury free, arsenic free, Zero Bright Dot Warranty
White
64.4 cm x 19.7 cm x 39.3 cm - with stand
7.16 kg
DisplayPort (HDCP) , HDMI (HDCP) , VGA , 2 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, VESA interface support
Security Slot Type
Kensington security slot
Input Voltage
31 W
Power Consumption (Typical)
45 Watt
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
With stand - width: 64.4 cm - depth: 19.7 cm - height: 39.3 cm - weight: 7.31 kg , Without stand - width: 64.4 cm - depth: 5.1 cm - height: 39.3 cm - weight: 5 kg
Shipping Width
75.1 cm
Shipping Depth
19 cm
Shipping Height
50.6 cm
5 °C
35 °C
20 - 80% (non-condensing)
F6W6 HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site In Stock £22.87
F6W6 HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £33.70
F6W6 HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site In Stock £6.01
F6W6 HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor In Stock £10.83
Diagonal Size: 27in
Response Time: 12ms
Speakers: None
Interfaces: HDMI
Interfaces: VGA (HD-15)
Interfaces: DisplayPort
Brand: HP
Price Range Ex VAT: £500 - £750
