HP Healthcare Edition HC241 24" 1920x1080 14ms VGA HDMI DisplayPort LED Monitor
Quicklinx: F6W0WS00 Mfr#: 3ME68AA#ABU
Diagonal Size: 24in
Max Resolution: 1920 x 1200
Response Time: 14ms
Speakers: None
Interfaces: DisplayPort, HDMI, VGA (HD-15)
£406.38 ex VAT
£487.65 inc VAT
Deploy a display optimized for patient rooms, nurses stations, medical carts, and public areas with the HP Healthcare Edition HC241. It is built for easy, repeatable sanitization after every patient engagement and is DICOM Part 14 compliant for accurate viewing of medical images.
  • Promote patient safety
    Be ready for the next patient or user with a display and optional stand that are sanitizable with germicidal wipes. The display is IEC 60601-1-2: 2014 compliant for use near patients and staff and the front is IP 32 rated against water ingress.
  • Out-of-the box image accuracy
    Help ensure accurate, consistent image viewing between healthcare professionals and for patient consultations and image verification with a DICOM Part 14 compliant display. See more and scroll less on the WUXGA 24-inch diagonal screen.
  • Create an efficient workspace for high-traffic areas
    Attach select HP PCs behind the display for a compact, integrated solution that's perfect for busy and shared spaces like nurses or charting stations. Mount on a medical cart, wall or arm with the VESA pattern.
HP HC241 Clinical Review Monitor - Healthcare - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
33 kWh
Power Consumption (On mode)
31.1 W
USB 3.0 hub
Panel Type
AHVA
Aspect Ratio
16:10
Native Resolution
WUXGA 1920 x 1200 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
270 cd/m²
Contrast Ratio
1000:1
Response Time
14 ms (grey-to-grey)
Input Connectors
HDMI, VGA, DisplayPort
Screen Coating
Anti-glare
White
56.36 cm x 19.7 cm x 55.16 cm
6.87 kg
English / United Kingdom
Plug and Play, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, CECP, EAC, ISC, low halogen, CE/EMC
Display Type
Energy Class
Class A
33 kWh
31.1 W
Diagonal Size
24"
Viewable Size
24"
Built-in Devices
USB 3.0 hub
Panel Type
AHVA
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.27 mm
Brightness
270 cd/m²
Contrast Ratio
1000:1
Response Time
Vertical Refresh Rate
60 Hz
Horizontal Refresh Rate
80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Mercury free, arsenic free
White
56.36 cm x 19.7 cm x 55.16 cm - with stand
6.87 kg
DisplayPort (HDCP) , HDMI (HDCP) , VGA , 2 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, VESA interface support
Security Slot Type
Kensington security slot
25 Watt
Power Consumption Stand by
0.3 Watt
Dimensions & Weight Details
With stand - width: 56.36 cm - depth: 19.7 cm - height: 55.16 cm - weight: 6.87 kg , Without stand - width: 56.36 cm - depth: 5.24 cm - height: 37.88 cm - weight: 4.74 kg
5 °C
35 °C
20 - 80% (non-condensing)
Diagonal Size: 24in
Response Time: 14ms
Speakers: None
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: HP
Price Range Ex VAT: 300 - 500
