Brand
HP Healthcare Edition HC240 24" 1920x1200 8ms DVI HDMI DisplayPort LED Monitor
Quicklinx: F6W2WS00 Mfr#: Z0A71A4#ABU
Diagonal Size: 24in
Max Resolution: 1920 x 1200
Response Time: 8ms
Speakers: None
Interfaces: Mini DisplayPort, HDMI, DisplayPort, DVI
£333.39 ex VAT
£400.06 inc VAT
Be assured that grayscale and color medical images and patient information are consistent and accurate on every display. The HP Pixel Policy also means you get a screen with zero bright dots, or HP replaces it.
View your medical images and records onscreen with a 24" diagonal IPS display with 1920 x 1200 resolution. Seamlessly work across multiple displays and sources with micro-edge bezels, DisplayPort multi-stream support, and Picture-in-Picture.
Attach your HP Desktop Mini or select HP Thin Client behind the display for an integrated, small footprint solution that's perfect for busy and shared spaces like nurse's or charting stations. Mount on a wall or arm with the VESA pattern.
  • Out-of-the-box bi-modal DICOM and color calibration
  • See more and scroll less
  • Create an efficient, compact workspace for high-traffic areas
HP HC240 - Healthcare - LED monitor - 24"
LED-backlit LCD monitor - 24"
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB
Input Connectors
DVI-D, DisplayPort, Mini DisplayPort, HDMI (MHL)
Display Position Adjustments
Pivot (rotation), swivel, tilt
Screen Coating
Anti-glare
Voltage
White
53.38 cm x 21.01 cm x 52.02 cm
5.78 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, CSA, UL, VCCI, C-Tick, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, DICOM Part 14, NFPA 99, MEPS, CECP, EAC, ISC, low halogen, CE/EMC
5-year warranty
Display Type
Diagonal Size
24"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
99% sRGB
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 75 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, DICOM calibrated, Frame Rate Control (FRC), Mercury free, arsenic-free glass, USB 3.0 Fast Charge, 99% sRGB colour gamut
White
53.38 cm x 21.01 cm x 52.02 cm - with stand
5.78 kg
DVI-D , DisplayPort , MHL / HDMI , Mini DisplayPort , Audio line-out , 4 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
Tilt Angle
-2/+20
Swivel Angle
45
Rotation Angle
90
VESA Mounting Interface
Security lock slot (cable lock sold separately), detachable stand, VESA interface support
1 x DisplayPort cable - 1.8 m , 1 x HDMI cable - 1.8 m , 1 x USB 3.0 / USB 2.0 cable - 1.8 m
Backlight Life
30,000 hours
Input Voltage
Power Consumption (Typical)
36 Watt
Power Consumption Stand by
0.5 Watt
Included Software
HP Support Assistant
Dimensions & Weight Details
With stand - width: 53.38 cm - depth: 21.01 cm - height: 52.02 cm - weight: 5.78 kg , Without stand - width: 53.38 cm - depth: 4.93 cm - height: 35.11 cm - weight: 3.87 kg
ENERGY STAR Certified
Limited warranty - 5 years - on-site - response time: next business day
5 °C
35 °C
20 - 80% (non-condensing)
Warranties (1)
F6W2 HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site In Stock £15.53
Other bundles (1)
F6W2 HP PC Mounting Bracket For Monitors In Stock £48.94
Diagonal Size: 24in
Response Time: 8ms
Speakers: None
Interfaces: HDMI
Interfaces: DisplayPort
Interfaces: DVI
Brand: HP
