HP Flexible Thin Client t520 GX-212JC 1.2 GHz 4GB 16GB
Quicklinx: 9NN1WS00 Mfr#: G9F12AT#ABU
Get a flexible, reliable desktop experience for your virtual network and knowledge base users with the HP t520 Flexible Thin Client.
Work smarter.
Maximize your productivity with the latest thin client technologies packed into a sleek, new, fanless industrial design that brings a modern touch to a range of environments.
Seamless integration.
Choose the operating system and client virtualization solutions best suited to your environment. Help boost management and performance of your thin client deployment with HP Device Manager and HP Velocity software.
Powerful performance.
Get AMD GX-212JC SOC, an ultra-fast flash drive interface, integrated dual DisplayPort, and native VGA.
Rest easy with a smart investment.
Be future-ready with a 36-month long lifecycle that supports extended deployments, get global support from a standard three-year limited warranty, and help save money with an energy-efficient design that carries globally recognized eco-certifications.
  • Essential business performance
    Get the best bang for your investment buck with AMD GX-212JC SOC (System on Chip), HD graphics, and expansive memory and storage.
  • Place it where you need it
    Make the most of your available workspace and deploy the sleek, new, fanless chassis horizontally or vertically in a range of compact settings.
  • Keep it simple
    Make it easy to deploy, manage, and maintain your install base with HP Device Manager, a software tool available exclusively for HP Thin Clients.
  • High quality LAN-like data delivery
    Improve network performance and the end-user experience with HP Velocity software.
  • Get the right OS for your environment and budget
    Select a Windows OS for a familiar Windows experience with Enhanced Write Filter security and added multi-touch support, HP ThinPro for full-featured Linux or HP Smart Zero Technology for simple management.
  • No-hassle virtualization
    Connect to your virtualized desktops and applications with support for the latest ISVs and certifications from Citrix, VMware, and Microsoft.
HP Flexible t520 - tower - GX-212JC 1.2 GHz - 4 GB - SSD 16 GB
Thin client - tower
1 x AMD GX-212JC 1.2 GHz (Dual-Core)
Cache Memory
1 MB L2 Cache
Cache Per Processor
1 MB
RAM
4 GB (installed) / 8 GB (max) - DDR3L SDRAM - non-ECC - PC3-12800
Storage Controller
SATA
Hard Drive
SSD 16 GB - SATA - M.2
Optical Storage
No optical drive
Audio Output
Integrated
GigE
OS Provided
Windows Embedded 8 Standard x64 Edition
Software Included
Citrix ICA, Microsoft RDP, VMware Horizon View, Citrix HDX, Microsoft RemoteFX
4.51 cm x 20 cm x 20.01 cm
1.04 kg
Environmental Standards
ENERGY STAR Qualified
Thin client
Product Form Factor
Tower
Processor / Chipset
CPU
AMD GX-212JC
Clock Speed
1.2 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
Cache Memory
Installed Size
L2 Cache - 1 MB
Cache Per Processor
1 MB
RAM
Installed Size
4 GB / 8 GB (max)
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
SO-DIMM 204-pin
Slots
1 (Total) / 0 (empty)
Unbuffered, low-voltage
Configuration Features
1 x 4 GB
Hard Drive
SSD - M.2
1 x 16 GB
Interface Type
SATA
Multi-level cell (MLC)
Storage Controller
1 x SATA - integrated
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Video Interfaces
VGA, DisplayPort
Audio Output
Integrated
Input Device
Mouse, keyboard
Keyboard
USB
Mouse
USB
Integrated
Slots
1 (total) / 0 (free) x SO-DIMM 204-pin , 1 (total) / 0 (free) x M.2 Card , 1 (total) / 1 (free) x PCIe Half Mini Card
2 x USB 3.0 , 4 x USB 2.0 , 2 x DisplayPort , 1 x VGA , 1 x LAN (Gigabit Ethernet) , 1 x headphones , 1 x microphone
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Low halogen
Power adapter
Power Provided
65 Watt
Operating System / Software
OS Provided
Software
Sustainability Information
ENERGY STAR Certified
4.51 cm
20 cm
20.01 cm
1.04 kg
