Product
HP Flexible Thin Client t520 GX-212JC 1.2 GHz 4GB 16GB
Quicklinx: 9NN0WS00 Mfr#: G9F08AT#ABU
Get a flexible, reliable desktop experience for your virtual network and knowledge base users with the HP t520 Flexible Thin Client.
  • Work smarter
    Maximize your productivity with the latest thin client technologies packed into a sleek, new, fanless industrial design that brings a modern touch to a range of environments.
  • Powerful performance
    Get AMD GX-212JC SOC, an ultra-fast flash drive interface, integrated dual DisplayPort, and native VGA.
  • Seamless integration
    Choose the operating system and client virtualization solutions best suited to your environment. Help boost management and performance of your thin client deployment with HP Device Manager and HP Velocity software.
  • Rest easy with a smart investment
    Be future-ready with a 36-month long lifecycle that supports extended deployments, get global support from a standard three-year limited warranty, and help save money with an energy-efficient design that carries globally recognized eco-certifications.
HP Flexible t520 - tower - GX-212JC 1.2 GHz - 4 GB - 16 GB
Thin client - tower
1 x AMD GX-212JC 1.2 GHz (Dual-Core)
Cache Memory
1 MB L2 Cache
Cache Per Processor
1 MB
RAM
4 GB (installed) / 8 GB (max) - DDR3L SDRAM - non-ECC - PC3-12800
Storage Controller
SATA
Hard Drive
1 x SSD 16 GB - SATA - M.2
Optical Storage
No optical drive
Audio Output
Integrated
GigE
OS Provided
Microsoft Windows Embedded Standard 7E 32-bit
4.51 cm x 20 cm x 20.01 cm
1.04 kg
Environmental Standards
ENERGY STAR Qualified
Thin client
Product Form Factor
Tower
Processor / Chipset
CPU
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
Cache Memory
Installed Size
L2 Cache - 1 MB
Cache Per Processor
1 MB
RAM
Installed Size
4 GB / 8 GB (max)
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
SO-DIMM 204-pin
Unbuffered, low-voltage
Configuration Features
1 x 4 GB
Hard Drive
SSD - M.2
1 x 16 GB
Interface Type
SATA
Multi-level cell (MLC)
Storage Controller
1 x SATA - integrated
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Video Interfaces
VGA, DisplayPort
Audio Output
Integrated
Input Device
Mouse, keyboard
Keyboard
USB
Mouse
USB
Integrated
Slots
1 (total) / 0 (free) x SO-DIMM 204-pin , 1 (total) / 0 (free) x M.2 Card , 1 (total) / 1 (free) x PCIe Half Mini Card
2 x USB 3.0 , 4 x USB 2.0 , 2 x DisplayPort , 1 x VGA , 1 x LAN (Gigabit Ethernet) , 1 x headphones , 1 x microphone
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Low halogen
Power adapter
Nominal Voltage
Power Provided
65 Watt
Operating System / Software
OS Provided
Software
Citrix ICA, Microsoft RDP, Microsoft Internet Explorer 9.0, VMware Horizon View, Citrix HDX, Microsoft RemoteFX
ENERGY STAR Certified
4.51 cm
20 cm
20.01 cm
1.04 kg
