HP Flexible Thin Client t520 GX-212JC 1.2 GHz - 4 GB - 8 GB
Quicklinx: CYH9WS00 Mfr#: X9S41EA#ABU
  • IEEE 802.11n
Get a flexible, reliable desktop experience for your virtual network and knowledge base users with the HP t520 Flexible Thin Client.
  • Essential business performance
    Get the best bang for your investment buck with AMD GX-212JC SOC (System on Chip), HD graphics, and expansive memory and storage.
  • Place it where you need it
    Make the most of your available workspace and deploy the sleek, new, fanless chassis horizontally or vertically in a range of compact settings.
  • Keep it simple
    Make it easy to deploy, manage, and maintain your install base with HP Device Manager, a software tool available exclusively for HP Thin Clients.
  • High quality LAN-like data delivery
    Improve network performance and the end-user experience with HP Velocity software.
  • Get the right OS for your environment and budget
    Select a Windows OS for a familiar Windows experience with Enhanced Write Filter security and added multi-touch support, HP ThinPro for full-featured Linux or HP Smart Zero Technology for simple management.
  • No-hassle virtualization
    Connect to your virtualized desktops and applications with support for the latest ISVs and certifications from Citrix, VMware, and Microsoft.
HP Flexible t520 - tower - GX-212JC 1.2 GHz - 4 GB - SSD 8 GB
Thin client - tower
1 x AMD GX-212JC 1.2 GHz (Dual-Core)
RAM
4 GB (installed) / 8 GB (max) - DDR3L SDRAM - PC3L-12800
Storage Controller
SATA
Hard Drive
SSD 8 GB - SATA - M.2
Optical Storage
No optical drive
1GbE, Bluetooth, 802.11a, 802.11b/g/n, Wi-Fi 5
OS Provided
HP ThinPro 32-bit
Software Included
Citrix ICA, Microsoft RDP, HP ThinState Tools, HP Easy Tools, HP Device Manager, VMware Horizon View, Citrix HDX, Microsoft RemoteFX, Mozilla Firefox 19
4.51 cm x 20 cm x 20.01 cm
1.04 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Thin client
Product Form Factor
Tower
Processor / Chipset
CPU
AMD GX-212JC
Clock Speed
1.2 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
RAM
Installed Size
4 GB / 8 GB (max)
DDR3L SDRAM
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3L-12800
SO-DIMM 204-pin
Slots
1 (Total) / 0 (empty)
Low-voltage
Configuration Features
1 x 4 GB
Hard Drive
SSD - M.2
1 x 8 GB
Interface Type
SATA
Multi-level cell (MLC)
Storage Controller
1 x SATA
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Video Interfaces
VGA, DisplayPort
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, Bluetooth, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Slots
1 (total) / 0 (free) x SO-DIMM 204-pin , 1 (total) / 0 (free) x M.2 Card , 1 (total) / 1 (free) x PCIe Mini Card
2 x USB 3.0 (2 in front) , 4 x USB 2.0 , 2 x DisplayPort , 1 x VGA , 1 x LAN (Gigabit Ethernet) , 1 x headphones (1 in front) , 1 x microphone (1 in front)
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
FCC Class B certified, TUV GS, VCCI, EN 60950, UL 1950, CSA 22.2 No. 950, EN55022 Class B, RoHS, WEEE, low halogen
Power adapter
Power Provided
65 Watt
Operating System / Software
OS Provided
HP ThinPro 32-bit English
Software
Sustainability Information
ENERGY STAR Certified
4.51 cm
20 cm
20.01 cm
1.04 kg
10 °C
10 - 90% (non-condensing)
