Maximize the life of your PC as your business needs change with the flexible display connectivity of the HP VGA Port Flex IO v2. Flex IO.
 - HP Flex IO V2 Card - VGA port
- Product Type
 - VGA port
- Package Content
 - Screws
 - 3.9 cm x 4.18 cm x 1.65 cm
 - 11.5 g
- Designed For
 - HP Z1 G8, Z1 G9; Elite 600 G9, 800 G9; EliteDesk 800 G6, 800 G8, 805 G6, 805 G8; Pro 400 G9; ProDesk 400 G6 (mini desktop), 400 G7, 405 G6, 405 G8, 600 G6; Workstation Z1 G6 Entry
- Product Type
 - VGA port
- Package Content
 - Screws
 - 3.9 cm
 - 4.18 cm
 - 1.65 cm
 - 11.5 g
- Designed For
 - HP Z1 G8, Z1 G9 , HP Elite 600 G9, 800 G9 , HP EliteDesk 800 G6, 800 G8, 805 G6, 805 G8 , HP Pro 400 G9 , HP ProDesk 400 G6 (mini desktop), 400 G7, 405 G6, 405 G8, 600 G6 , HP Workstation Z1 G6 Entry
