HP Essential USB Mouse
Quicklinx: F6ZBWS00 Mfr#: 2TX37AA
Wired / Wireless: Wired
Colour: Black
£12.00 ex VAT
£14.40 inc VAT
Pair your device with the HP Essential USB Mouse for precise scrolling and clicking and smooth motion over a variety of surfaces without a mouse pad.
  • Simple USB connectivity
    Connect the mouse to any USB port on your device.
  • Fast navigation
    Scroll quickly without a mouse pad, ball or roller with the optical sensor.
  • Intuitive and familiar
    Enjoy natural, comfortable left or right hand operation, and use the wheel on top as a third mouse button.
  • World-class support
    Get a one-year limited warranty.
HP Essential - mouse - USB - black
Mouse
Wired - USB
Orientation
Right and left-handed
6.29 cm x 11.5 cm x 3.7 cm
90 g
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
800 dpi
Scrolling wheel
Cable Length
1.8 m
Microsoft Windows Vista / 7 / 8 / 10
1-year warranty
HP 24X G7, 24X G8, 25X G8, 340 G7, 470 G8; Elite c1030; EliteBook 830 G8, 840 G8, 850 G8; EliteBook x360; Mobile Thin Client mt46; Pro c645; ProBook 430 G8, 44X G8, 45X G8, 630 G8, 635, 640 G8, 650 G8; ProBook x360; ZBook Create G7, Power G7; ZBook Firefly 14 G8, 15 G8; ZBook Fury 15 G7, 17 G7
Mouse
Orientation
6.29 cm
11.5 cm
3.7 cm
90 g
Input Device
Wired
USB
Optical
Buttons Qty
3
Movement Resolution
800 dpi
Cable Length
1.8 m
Scrolling wheel
1 x USB
TUV GS, VCCI, BSMI, FCC, cULus, KC, EAC
Limited warranty - 1 year
HP 240 G8, 245 G7, 245 G8, 246 G7, 250 G5, 250 G6, 250 G8, 255 G5, 255 G6, 255 G7, 255 G8, 256 G8, 340 G5, 340 G7, 340S G7, 348 G5, 470 G7, 470 G8 , HP Chromebook 11 G5, 11 G7, 11 G8, 11A G6, 11A G8, 13 G1, 14 G6, 14A G5 , HP Chromebook Enterprise 14 G6 , HP Chromebook Enterprise x360 14E G1 , HP Chromebook x360 11 G1 (Education Edition), 11 G2, 11 G3 , HP Elite c1030 Chromebook, c1030 Chromebook Enterprise , HP Elite Dragonfly , HP Elite x2 1012 G2, G4 , HP EliteBook 1030 G1, 1040 G3, 1040 G4, 725 G4, 735 G6, 745 G4, 745 G6, 755 G4, 820 G3, 820 G4, 830 G6, 830 G7, 830 G8, 835 G7, 840 G4, 840 G6, 840 G7, 840 G8, 845 G7, 850 G4, 850 G6, 850 G7, 850 G8, 855 G7 , HP EliteBook x360 1030 G2, 1030 G4, 1030 G7, 1030 G8, 1040 G6, 1040 G7, 1040 G8, 830 G6, 830 G7, 830 G8 , HP Mobile Thin Client mt46 , HP MX12 Retail Solution , HP Pro c640 Chromebook, c645 Chromebook, c645 Chromebook Enterprise , HP Pro x2 612 G2 , HP ProBook 430 G4, 430 G5, 430 G6, 430 G7, 430 G8, 440 G4, 440 G5, 440 G6, 440 G7, 440 G8, 445 G7, 445 G8, 445r G6, 450 G4, 450 G5, 450 G6, 450 G7, 450 G8, 455 G4, 455 G5, 455 G7, 455 G8, 455r G6, 470 G4, 470 G5, 630 G8, 635 Aero G7, 640 G2, 640 G3, 640 G5, 640 G8, 645 G2, 645 G3, 650 G2, 650 G3, 650 G5, 650 G8, 655 G2, 655 G3 , HP ProBook x360 11 G4, 11 G5, 11 G6, 11 G7, 435 G7, 435 G8 , HP Spectre Pro x360 G2 , HP Stream Pro 11 G3, 11 G4 , HP ZBook 14u G4 Mobile Workstation, 14u G6 Mobile Workstation, 15 G3 Mobile Workstation, 15 G4 Mobile Workstation, 15 G6 Mobile Workstation, 15u G4 Mobile Workstation, 15u G6 Mobile Workstation, 17 G3 Mobile Workstation, 17 G4 Mobile Workstation, 17 G6 Mobile Workstation, Create G7, Power G7 Mobile Workstation, Studio G4 Mobile Workstation, Studio G7 Mobile Workstation , HP ZBook Firefly 14 G7 Mobile Workstation, 14 G8 Mobile Workstation, 15 G7 Mobile Workstation, 15 G8 Mobile Workstation , HP ZBook Fury 15 G7 Mobile Workstation, 17 G7 Mobile Workstation
Colour: Black
Brand: HP
