Add an extra layer of security to your notebook with the HP Essential Combination Lock, designed for any notebook with a standard lock slot.
Loop and lock with your own code
Route the 4 ft (1.22 m) vinyl-coated, galvanized steel cable around any secure object, attach to your notebook, and lock with the push-button mechanism and your unique four-digit combination. -
Room to move
The cable head swivels 360 degrees to help you position the cable as needed before you lock. -
Rest easy
Get the reassurance of a one-year limited warranty.
- HP Essential Combination Lock - security cable lock
- Product Type
- Security cable lock
- Product Material
- Galvanised steel
- Length
- 1.22 m
- Combination lock, 360 degree swivel capability, 4 digit code, vinyl-coated
- Designed For
- HP 245 G7; Chromebook x360; Mobile Thin Client mt22, mt45; ProBook 430 G7, 44X G7, 45X G7; ProBook x360; ZBook 14 G2, 14u G4, 14u G5, 14u G6, 15 G2, 15 G3, 15 G4, 15 G5, 15 G6, 15u G2, 15u G3, 15u G4, 15u G5, 15u G6, 17 G3, 17 G4, 17 G5, 17 G6, Studio G3, Studio G4, Studio G5, Studio x360 G5
- Product Type
- Product Material
- Galvanised steel
- Length
- 1.22 m
- Designed For
- HP 240 G6, 245 G1, 245 G6, 245 G7, 250 G4, 250 G5, 250 G6, 250 G7, 255 G4, 255 G5, 255 G6, 255 G7, 340 G2, 350 G2 , HP Chromebook 11 G3 , HP Chromebook x360 11 G1 Education Edition , HP EliteBook 1040 G3, 1050 G1, 725 G3, 725 G4, 735 G5, 745 G3, 745 G4, 745 G5, 755 G3, 755 G4, 755 G5, 820 G3, 820 G4, 830 G5, 830 G6, 840 G3, 840 G4, 840 G5, 840 G6, 840r G4, 850 G2, 850 G3, 850 G4, 850 G5, 850 G6, 8770w , HP EliteBook x360 1030 G2 , HP ElitePad 1000 G2 , HP Mobile Thin Client mt22, mt45 , HP ProBook 11 G1, 430 G3, 430 G4, 430 G5, 430 G6, 430 G7, 440 G3, 440 G4, 440 G5, 440 G6, 440 G7, 445 G6, 445 G7, 445r G6, 450 G3, 450 G4, 450 G5, 450 G6, 450 G7, 455 G3, 455 G4, 455 G5, 455 G6, 455 G7, 455r G6, 470 G3, 470 G4, 470 G5, 640 G2, 640 G3, 640 G4, 640 G5, 645 G2, 645 G3, 645 G4, 650 G2, 650 G3, 650 G4, 650 G5, 655 G2, 655 G3 , HP ProBook x360 11 G2 Education Edition, 440 G1 , HP x360 310 G2 , HP ZBook 14 G2, 14u G4, 14u G5, 14u G6, 15 G2, 15 G3, 15 G4, 15 G5, 15 G6, 15u G2, 15u G3, 15u G4, 15u G5, 15u G6, 17 G3, 17 G4, 17 G5, 17 G6, Studio G3, Studio G4, Studio G5, Studio x360 G5 , HP ZBook x2 G4 Detachable Workstation
