HP Essential Combination Lock - 1.22m
Quicklinx: F6ZJWS00 Mfr#: T0Y16AA
Add an extra layer of security to your notebook with the HP Essential Combination Lock, designed for any notebook with a standard lock slot.
  • Loop and lock with your own code
    Route the 4 ft (1.22 m) vinyl-coated, galvanized steel cable around any secure object, attach to your notebook, and lock with the push-button mechanism and your unique four-digit combination.
  • Room to move
    The cable head swivels 360 degrees to help you position the cable as needed before you lock.
  • Rest easy
    Get the reassurance of a one-year limited warranty.
HP Essential Combination Lock - security cable lock
Security cable lock
Product Material
Galvanised steel
Length
1.22 m
Combination lock, 360 degree swivel capability, 4 digit code, vinyl-coated
Security cable lock
Product Material
Galvanised steel
Length
1.22 m
