HP Epson Elite x2 1012 G2 Core i3-7100U Win 10 Pro
Quicklinx: D3VCWS00 Mfr#: 1LV15EA#ABU
Display Size: 12.3in
Processor Model: I3-7100U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 4GB, 4GB
Hard Drive Capacity: 256GB
  • Core i3
  • IEEE 802.11n
£1,458.00 ex VAT
£1,749.60 inc VAT
  • Free to work, the way you want
    A seamless blend of PC power and unbound portability, the HP Elite x2 combines advanced laptop performance and tablet mobility to liberate the way you work.
  • Designed to bring worlds together
    Certified for Skype for Business , the HP Elite x2 keeps you in touch and in sync, wherever you are. Collaboration Keyboard is built into its DNA with premium audio, high-resolution andcameras, and the HP Elite x2 Collaboration Keyboard.
  • Elite-class engineering
    The HP Elite x2 unites powerful security and manageability in an elegant frame with HP Sure Start Gen3 BIOS protection and the HP Manageability Integration Kit.
  • Performance to get the job done
    The HP Elite x2 pushes performance limits with a 7th Gen Intel Core i5/i7 processor and 10 hours of battery life that lets you work, surf, and connect with colleagues.
HP Elite x2 1012 G2 - 12.3" - Core i3 7100U - 4 GB RAM - 256 GB SSD - UK
Tablet - with detachable keyboard
Operating System
Win 10 Pro 64-bit - English
Intel Core i3 (7th Gen) 7100U / 2.4 GHz / 3 MB Cache
4 GB LPDDR3 (provided memory is soldered)
Storage
256 GB SSD HP Z Turbo Drive G2, NVMe, TLC
Display
12.3" LED backlight touchscreen 2736 x 1824
Graphics
Intel HD Graphics 620
Input Device
Keyboard, ClickPad
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
4-cell - up to 10.25 hours
Accelerometer, ambient light sensor, proximity sensor, magnetometer, gyro sensor, hall sensor
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip
Dimensions (WxDxH) - tablet
30 cm x 21.385 cm x 0.805 cm
803 g
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
RAM
4 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
1866 MHz
Storage
Main Storage
256 GB SSD - (M.2 2280) PCIe - HP Z Turbo Drive G2, NVM Express (NVMe), triple-level cell (TLC)
Display
12.3" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Yes (multi-touch)
Resolution
2736 x 1824
Widescreen
Image Brightness
450 cd/m²
BrightView, Ultra Slim Design, ultra wide viewing angle, Corning Gorilla glass 4, 268 ppi
Keyboard Name
HP Pro x2 612 G2 Collaboration Keyboard
Audio & Video
Graphics Processor
Camera
Yes - 1080p
Resolution
8 Megapixel (rear), 5 Megapixel (front)
Video Resolutions
640 x 480, 1920 x 1080
Frame Rate
30 frames per second
Camera Features
IR camera, low light enhancement, Windows Hello
Sound
Stereo speakers, two microphones
Audio Features
Noise-cancellation technology, Bang & Olufsen Audio
Input
Keyboard, ClickPad
Keyboard Backlight
Keyboard Layout
Volume control, ClickPad with gesture support, Wacom Active Pen technology
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 8265
IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
4-cell lithium polymer
47 Wh
Run Time
Up to 10.25 hours
AC Adapter
Input
Output
45 Watt, 5 / 9 / 10 / 12 / 15 / 20 V
Connections & Expansion
USB-C 3.1/Thunderbolt 3 , USB 3.0 , Headphone/microphone combo jack , Dock
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Software
Software Included
Skype, HP SoftPaq Download Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, Windows Defender, HP Client Security, HP Velocity, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP Sure Connect, HP LAN-WLAN Protection, HP MIK for Microsoft SCCM (free download), HP BIOSphere Gen3, HP JetAdvantage, HP System Software Manager (free download), HP Advanced Noise Reduction Software
Integrated Options
Dockable
Security
HP DuraKeys, HP Automatic Drive Lock, HP DriveLock, Power On Authentication, Pre-boot Authentication, HP Sure Start Gen 3, Master Boot Record Security
Theft/Intrusion Protection
Security Slot Type
Kensington nano security slot
Power adapter, keyboard, HP Elite x2 1012 G2 Collaboration Keyboard
Low halogen
Localization
803 g
Dimensions (WxDxH) / Weight Details
30 cm x 21.93 cm x 1.355 cm / 1.156 kg - tablet with keyboard , 30 cm x 21.385 cm x 0.805 cm / 803 g - tablet
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
240 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
1.043 g @ RMS (random)
Vibration Tolerance (non-operating)
3.5 g @ RMS (random)
Software applications
HP Epson Elite x2 1012 G2 Core i3-7100U Win 10 Pro Bundle deal on HP Epson Elite x2 1012 G2 Core i3-7100U Win 10 Pro
£1,640.17
saving £8.33
£1,557.17
Optical Storage: None
Graphics: Intel HD Graphics 620
Hard Drive Type: SSD
Brand: HP
Price Range Ex VAT: 1000 - 1500
