HP Envy 7640 Colour Printer
Quicklinx: 9NJ8WS00 Mfr#: E4W47A#BHC
Get HP's premium home e-all-in-one for printing low-cost lab-quality photo, creative projects and laser-quality documents. Advanced mobile printing features make it easy to print from your smartphone, tablet and connected PCs at home or on the go.
  • Experience advanced mobile and photo printing in three steps
    Enjoy the easiest way to print from your smartphone or tablet – with or without a router or local wireless network.Print 10 x 15 cm and 13 x 18 cm photos from mobile devices without switching paper, using the separate paper tray.Start printing quickly with easy setup from your smartphone, tablet or PC.Print from your iPhone , iPad , Android mobile devices, Amazon Kindle Fire – and many more.
  • Enjoy versatile performance for all your home projects
    Create borderless, lab-quality photos, fulfilling creative projects and standout documents with ease.Manage multiple pages quickly with the 25-page automatic document feeder and automatic two-sided printing.Walk up, edit, and print photos right from the 8.89 cm (3.5-inch) touchscreen.Easily connect to your local network and the Internet – wirelessly or using the Ethernet port.
  • Reduce your impact
    Save energy with this ENERGY STAR qualified e-all-in-one.Save paper and conserve resources – consume up to 50% less paper with automatic two-sided printing.Count on easy, free cartridge recycling through HP Planet Partners.
HP ENVY 7640 e-All-in-One - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
Western Europe, United Kingdom, Ireland, Nordics, Baltic Region
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
1000 pages
Recommended Monthly Volume
300 - 400 pages
Max Copying Speed
Up to 11 ppm (mono) / up to 5 ppm (colour)
Max Copying Resolution
Up to 300 x 300 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Up to 14 ppm (mono) / up to 9 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 311 dpi, 196 x 208 dpi, 200 x 208 dpi, 98 x 208 dpi
Scanning
1200 x 1200 dpi
Display
3.5"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
25 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, iron-on transfers, photo paper
Standard Media Capacity
125 sheets
Output Trays Capacity
25 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), NFC
AirPrint Enabled
Office Machine Features
Scan to e-mail, HP Auto Wireless Connect, automatic paper sensor
AC 120/230 V (50/60Hz)
45.4 cm x 41 cm x 19.3 cm
7.67 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
1000 pages
300 - 400 pages
Display Diagonal Size
3.5"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
128 MB
Supported Flash Memory
SD Memory Card
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
50
Automatic Duplexing
Printing
Inkjet Technology
HP Thermal Inkjet
Nozzle Configuration
704 nozzles (black), 608 nozzles (colour)
Max Printing Speed
Ink Cartridge Configuration
1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 3 GUI
Automatic Duplexing
First Print Out Time B/W
18 sec
First Print Out Time Colour
22 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Transmission Memory Capacity
Up to 100 pages
Fax Printing Speed
Up to 15 ppm
PC Faxing
Fax Machine Features
Broadcast Transmission
20 stations
Delayed Transmission
Yes (black only)
Fax forwarding, colour faxing, Distinctive Ring Detection (DRD)
Document & Media Handling
Max Original Size
Original Type
Sheets
25 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
75 g/m²
Max Media Weight
250 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, C6 (114 x 162 mm), 76 x 127 mm, DL (210 x 99 mm)
125 sheets
25 sheets
Input tray - 125 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 75 g/m² - 250 g/m² , Output tray - 25 sheets , ADF - 25 sheets
Speed Details
Printing: up to 22 ppm (A4) - B/W draft , Printing: up to 21 ppm (A4) - colour draft , Printing: up to 14 ppm (A4) - B/W (ISO) , Printing: up to 9 ppm (A4) - colour (ISO) , Printing: 32 sec (10 x 15 cm (4"x6")) - photo normal , Copying: up to 21 ppm (A4) - B/W draft , Copying: up to 19 ppm (A4) - colour draft , Copying: up to 11 ppm (A4) - B/W (ISO) , Copying: up to 5 ppm (A4) - colour (ISO) , Scanning: up to 4 ppm
2 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Operating System Support
MS Windows 7, MS Windows Vista, Apple Mac OS X 10.6, Apple Mac OS X 10.7, Apple Mac OS X 10.8, Windows 8, Windows 8.1
Software Included
Drivers & Utilities, HP Photo Creations
Power Consumption Standby
5.04 Watt
Power Consumption Sleep
1.55 Watt
CISPR 24, CISPR 22, CEM, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN55022:2010, EN 301 489-1 V1.9.2, EN 301 489-17 V2.2.1, EN 55024:2010
ENERGY STAR Certified
Limited warranty - 1 year
45.4 cm
41 cm
19.3 cm
7.67 kg
Shipping Width
49.7 cm
Shipping Depth
24.7 cm
Shipping Height
49.1 cm
Shipping Weight
9.156 kg
Sound Emission
49 dBA (operating)
5 °C
20 - 80%
9NJ8 HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm In Stock £14.71
9NJ8 HP Iron-on Transfers-12 sheet/A4/210 x 297 mm In Stock £13.72
