HP ENVY 6430e All-in-One Wireless Colour Printer
Quicklinx: GDV9WS00 Mfr#: 223R2B#687
Handle it all from home. Print, scan, and copy everyday documents and more, and get a 35-page auto document feeder. Set up and connect on any device, and get self-healing Wi-Fi™.
Loaded with everything. Except complications.
Work fast and hands-free – the 35-page auto-feeder helps you complete scan and copy jobs quickly.
Easily print, scan, and copy everyday documents from your smartphone, using HP Smart app.
Save time by sending a mobile fax from your smartphone, tablet, or PC for 24 months, with HP Smart app.
Easily handle tasks and get a lot from one device – print, scan, and copy.
Print then and there. From anywhere.
Get started fast with simple setup that guides you through each step, using HP Smart app. Self-healing Wi-Fi™ automatically detects and resolves connectivity issues to help reduce interruptions.
Tap the Smart Tasks shortcut in HP Smart app for a shortcut on your phone. Scan to cloud, email, and more.
Get connected with Bluetooth® and start printing fast from your smartphone or tablet – easy setup.
  • Seamless setup
    Get started fast with simple setup that guides you through each step, using HP app.
  • Your reliable connection
    Reduce interruptions with self-healing Wi-Fi that keeps you connected.
  • Hands-free. Auto-fed
    Work fast and hands-free – the 35 page auto-feeder helps you complete scan and copy jobs quickly.
  • Print, scan, and copy from your phone
    With HP app, print everyday documents, get high-quality scanning and sharing, and easily make copies – all from your phone.
  • HP+, the cloud-connected, smart printing system
    An HP+ printer is ready when you are, more secure and productive than ever.
  • Tackle the essentials
    Get versatile performance and print, scan, and copy.
HP ENVY Pro 6430e All-in-One - multifunction printer - colour - HP Instant Ink eligible
Multifunction printer
Fax Type
Plain paper
United Kingdom, Ireland
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
1000 pages
Recommended Monthly Volume
50 - 100 pages
Max Copying Speed
Up to 8 ppm (mono) / up to 4 ppm (colour)
Max Copying Resolution
Up to 300 x 300 dpi (mono) / up to 300 x 300 dpi (colour)
Max Printing Speed
Up to 10 ppm (mono) / up to 7 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Fax Transmission Speed
14.4 Kbps
Fax Resolutions
150 x 150 dpi
Scanning
1200 x 1200 dpi
Original Size
216 x 297 mm (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
76.2 x 127 mm (min) - ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, cards, recycled paper, photo paper, light-weight paper, glossy paper, matte paper
Standard Media Capacity
100 sheets
Output Trays Capacity
25 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Wi-Fi(ac)
AirPrint Enabled
Office Machine Features
Scan to e-mail, automatic paper sensor, print from mobile devices, scan to PDF
AC 230 V (50/60Hz)
43.25 cm x 36.11 cm x 13.21 cm
6.16 kg
Environmental Standards
ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
1000 pages
50 - 100 pages
USB 2.0, Wi-Fi(ac)
AirPrint Enabled
Standard Memory
256 MB
Max Supported Memory
256 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
9
Printing
Inkjet Technology
HP Thermal Inkjet
Nozzle Configuration
328 nozzles (black), 588 nozzles (colour)
Max Printing Speed
Ink Cartridge Configuration
1 pigment black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, pigment black
4-ink
Printer Drivers / Emulations
PCL 3 GUI
Automatic Duplexing
First Print Out Time B/W
21 sec
First Print Out Time Colour
18 sec
Colour Management Features
ColorLok Technology
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
14.4 Kbps
Fax Resolutions
150 x 150 dpi
PC Faxing
Fax Machine Features
Fax forwarding, automatic redialing, Distinctive Ring Detection (DRD), fax polling
Document & Media Handling
Max Original Size
216 x 297 mm
Supported Original Sizes
216 x 297 mm
Original Type
Sheets
35 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Letter
Min Media Weight
60 g/m²
Max Media Weight
300 g/m²
Min Media Weight (lb)
16 lbs
Max Media Weight (lb)
80 lbs
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 101.6 x 152.4 mm, 76.2 x 127 mm, 127 x 177.8 mm, 203.2 x 254 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
Borderless Photo Sizes
216 x 297 mm
100 sheets
25 sheets
Input tray - 100 sheets size: 76.2 x 127 mm - Letter A (216 x 279 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 300 g/m²; weight (lbs): 16 lbs - 80 lbs , Output tray - 25 sheets , ADF - 35 sheets
Speed Details
Printing: up to 20 ppm (A4) - B/W draft , Printing: up to 17 ppm (A4) - colour draft , Printing: up to 10 ppm (A4) - B/W (ISO) , Printing: up to 7 ppm (A4) - colour (ISO) , Copying: up to 8 ppm - B/W (ISO) , Copying: up to 4 ppm (A4) - colour (ISO) , Scanning: up to 7 ipm (Letter A) - B/W normal , Scanning: up to 7 ipm (A4) - B/W normal , Scanning: up to 3 ipm (Letter A) - colour normal , Scanning: up to 3 ipm (A4) - colour normal
1 x USB 2.0 - 4 pin USB Type B
Operating System Support
MS Windows 7 (32/64 bits), Windows 10 (32/64-bits), macOS 10.12, macOS 10.13, macOS 10.14, macOS 10.15
Software Included
HP Smart App
AC 230 V (50/60Hz)
Power Consumption Standby
4 Watt
Power Consumption Sleep
1.7 Watt
FCC Class B certified, FCC CFR47 Part 15, EN 62479:2010, EN 61000-3-3:2013, CISPR 24:2010, IEC 61000-3-3:2013, EN 55024:2010, EN 62311:2008, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, EN 55032:2015, ICES-003 issue 6, EN 301 489-17 V3.1.1 (2017), CISPR 35, VCCI-CISPR 32:2016, CISPR 32:2015 Class B, EN 301 489-1 V2.1.1:2017, EN 55035:2017, EN 62368-1:2014+A11:2017, IEC 61000-3-2:2014, IEC 62368-1: 2014, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
ENERGY STAR Certified
43.25 cm
36.11 cm
13.21 cm
6.16 kg
Shipping Width
47.4 cm
Shipping Depth
40.8 cm
Shipping Height
21.8 cm
Shipping Weight
7.55 kg
Sound Emission
55 dBA (operating)
5 °C
Ink (3)
GDV9 HP 305XL High yeild black orginal In Stock £17.62
GDV9 HP 305 Colour (Cyan, Magenta, Yellow) Original Ink Cartridge In Stock £9.37
GDV9 HP 305XL High Yield Tri-Color Origin In Stock £16.16
Other bundles (1)
GDV9 HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Shipment In Stock £17.19
