HP Envy 5640 e-All-in-One Printer
Quicklinx: 9NJ6WS00 Mfr#: B9S59A#BHC
Get versatile printing for your family. Easily create lab-quality photos and laser-quality text on the go – right from your smartphones and tablets. This e-all-in-one is designed to help you be creative and stay productive – at a great value.
  • Enjoy printing as connected as you are
    Enjoy the easiest way to print from your smartphone or tablet – with or without a router or local wireless network.Easily connect this e-all-in-one to your local network and the Internet, wirelessly – right from your PC.Start printing quickly with easy setup from your smartphone, tablet or PC.Print from your iPhone , iPad , Android mobile devices, Amazon Kindle Fire – and many more.
  • Save up to 70% on ink with HP Instant Ink
    Print high-quality documents and photos in black-and-white and colour – all for the same low price.Print lab-quality colour photos in seconds for just a few pence, when you sign up for HP Instant Ink.Getting started with HP Instant Ink is quick and easy – learn more at hpinstantink.co.uk.
  • Step up and create
    Print borderless, lab-quality photos that dazzle and sharp documents with laser-quality text.Print 10 x 15 cm photos from your mobile device without switching paper using the separate photo paper tray.Walk up, edit and print right from the 6.75 cm (2.66-inch) touchscreen.
  • Reduce your impact
    Save paper and conserve resources – consume up to 50% less paper with automatic two-sided printing.Save energy with an e-all-in-one that's ENERGY STAR qualified.Reduce your environmental impact – easily recycle your Original HP Ink Cartridges for free.
HP ENVY 5640 e-All-in-One - multifunction printer - colour
Multifunction printer
Western Europe, United Kingdom, Ireland, Nordics, Baltic Region
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
1000 pages
Recommended Monthly Volume
300 - 400 pages
Max Copying Speed
Up to 10 ppm (mono) / up to 5 ppm (colour)
Max Copying Resolution
Up to 300 x 300 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Up to 12 ppm (mono) / up to 8 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Scanning
1200 x 1200 dpi
Display
2.66"
Original Size
216 x 297 mm (max)
Original Type
Sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, iron-on transfers, photo paper
Standard Media Capacity
125 sheets
Output Trays Capacity
25 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
Scan to e-mail, HP Auto Wireless Connect
AC 120/230 V (50/60Hz)
45.4 cm x 41 cm x 16.1 cm
6.82 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Printing Technology
Ink-jet - colour
1000 pages
300 - 400 pages
Display Diagonal Size
2.66"
Display Features
Touch screen
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Standard Memory
128 MB
Supported Flash Memory
SD Memory Card
Copying
Max Copying Speed
Max Document Enlargement
200%
Max Document Reduction
50%
Maximum Copies
20
Printing
Inkjet Technology
HP Thermal Inkjet
Nozzle Configuration
704 nozzles (black), 608 nozzles (colour)
Max Printing Speed
Ink Cartridge Configuration
1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 3 GUI
Automatic Duplexing
First Print Out Time B/W
18 sec
First Print Out Time Colour
22 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Max Original Size
216 x 297 mm
Original Type
Sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
75 g/m²
Max Media Weight
250 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, C6 (114 x 162 mm), 76 x 127 mm, DL (210 x 99 mm)
125 sheets
25 sheets
Input tray - 125 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 75 g/m² - 250 g/m² , Output tray - 25 sheets
Speed Details
Printing: up to 22 ppm (A4) - B/W draft , Printing: up to 21 ppm (A4) - colour draft , Printing: up to 12 ppm (A4) - B/W (ISO) , Printing: up to 8 ppm (A4) - colour (ISO) , Printing: 32 sec (10 x 15 cm (4"x6")) - photo normal , Copying: up to 21 ppm (A4) - B/W draft , Copying: up to 19 ppm (A4) - colour draft , Copying: up to 10 ppm (A4) - B/W (ISO) , Copying: up to 5 ppm (A4) - colour (ISO) , Scanning: up to 4 ppm
1 x USB 2.0 - 4 pin USB Type B
Operating System Support
MS Windows 7, MS Windows Vista, Apple Mac OS X 10.6, Apple Mac OS X 10.7, Apple Mac OS X 10.8, Windows 8, Windows 8.1
Software Included
Drivers & Utilities
13.95 Watt
Power Consumption Standby
3.6 Watt
Power Consumption Sleep
0.93 Watt
CISPR 24, CISPR 22, CEM, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN55022:2010, EN 301 489-1 V1.9.2, EN 301 489-17 V2.2.1, EN 55024:2010
ENERGY STAR Certified
Limited warranty - 1 year
45.4 cm
41 cm
16.1 cm
6.82 kg
Shipping Width
49.7 cm
Shipping Depth
20.5 cm
Shipping Height
49.1 cm
Shipping Weight
8.211 kg
Sound Emission
49 dBA (operating)
5 °C
20 - 80%
9NJ6 HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm In Stock £14.71
9NJ6 HP 62 Black Ink Cartridge In Stock £15.41
9NJ6 HP 62 Tri-color Ink Cartridge In Stock £18.38
9NJ6 HP Iron-on Transfers-12 sheet/A4/210 x 297 mm In Stock £13.72
