HP Envy 5540 Colour InkJet Multifunction Printer
Quicklinx: BT67WS00 Mfr#: J6U66A#ABU
Let your creativity soar while keeping printing costs low with an HP Instant Ink ready all-in-one. Enjoy the easiest way to print lab-quality photos and laser-quality documents in fewer steps from your smartphone or tablet.
  • You can afford to be creative with HP Instant Ink
    Save up to 70% on ink and never run out ink. Original HP ink. Ordered by your printer, delivered to your door.Print colour, black & white, and photos – your cost is the same.Ink cartridges and delivery costs included in your monthly plan price.No annual fee – change or cancel plans online anytime without penalty.
  • Easily create, without the wait
    Snap. Print. Enjoy. Easily print lab-quality photos from a variety of smartphones and tablets.Start printing and get connected quickly with easy setup from your smartphone, tablet, or PC.Manage printing tasks and scan from your mobile device with a free HP All-in-One Printer Remote mobile app.Connect your smartphone or tablet directly to your printer – and easily print without accessing a network.
  • Make quick work of creative tasks
    Be sure your projects always look good. Print borderless, lab-quality photos and laser-quality documents.The built-in photo tray lets you print 10 x 15 cm photos in brilliant colour without changing paper.Print remotely without worries – the auto-deploying output tray keeps your pages from landing on the floor.
  • Make it easy
    Print photo projects, or scan and copy documents, using the 5.5 cm (2.2-inch) graphics touchscreen display.Easily print at up to 12 pages per minute (ppm) for black-and-white and 8 ppm for colour.Print in any room you choose – without causing disruptions – using the optional quiet mode.
HP ENVY 5540 e-All-in-One - multifunction printer - colour - HP Instant Ink eligible
Multifunction printer
English / United Kingdom
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
1000 pages
Recommended Monthly Volume
300 - 400 pages
Max Copying Speed
Up to 10 ppm (mono) / up to 5 ppm (colour)
Max Copying Resolution
Up to 300 x 300 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Up to 12 ppm (mono) / up to 8 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Scanning
1200 x 1200 dpi
Display
2.2"
Original Size
216 x 297 mm (max)
Original Type
Sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, iron-on transfers, photo paper
Standard Media Capacity
125 sheets
Output Trays Capacity
25 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to folder, HP Auto Wireless Connect
AC 120/230 V (50/60Hz)
45.4 cm x 41 cm x 15.6 cm
6.82 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Printing Technology
Ink-jet - colour
1000 pages
300 - 400 pages
Display Diagonal Size
2.2"
Display Features
Touch screen
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Standard Memory
128 MB
Max Supported Memory
128 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
50
Printing
Inkjet Technology
HP Thermal Inkjet
Max Printing Speed
Ink Cartridge Configuration
1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, pigment black
4-ink
Printer Drivers / Emulations
PCL 3 GUI
Automatic Duplexing
First Print Out Time B/W
19 sec
First Print Out Time Colour
22 sec
Colour Management Features
ColorLok Technology
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Interpolated Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Max Original Size
216 x 297 mm
Original Type
Sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
75 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 76 x 127 mm
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm)
Borderless Photo Sizes
100 x 150 mm, 216 x 297 mm
125 sheets
25 sheets
Input tray - 125 sheets size: 76 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 75 g/m² - 300 g/m² , Output tray - 25 sheets , Photo tray - 15 sheets - 100 x 150 mm
Speed Details
Printing: up to 22 ppm (A4) - B/W draft , Printing: up to 21 ppm (A4) - colour draft , Printing: up to 12 ppm - B/W (ISO) , Printing: up to 8 ppm - colour (ISO) , Printing: up to 12 ppm (A4) - B/W normal , Printing: up to 8 ppm (A4) - colour normal , Printing: 34 sec (10 x 15 cm (4"x6")) - photo normal , Copying: up to 10 ppm - B/W (ISO) , Copying: up to 5 ppm - colour (ISO) , Scanning: 15 sec (A4) - B/W normal , Scanning: 15 sec (A4) - colour normal
1 x USB 2.0 - 4 pin USB Type B
Security Protocols & Features
Wi-Fi Direct
Operating System Support
MS Windows 7, MS Windows Vista, Apple Mac OS X 10.7, Apple Mac OS X 10.8, Windows 8, Windows RT, Android, Windows 8.1, Apple Mac OS X 10.9, Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 10, Blackberry, Windows 10 Mobile
Software Included
Drivers & Utilities, HP Photo Creations, HP Update
13.95 Watt
Power Consumption Standby
3.6 Watt
Power Consumption Sleep
0.93 Watt
Consumables Included
1 x ink cartridge (yellow/cyan/magenta) - up to 165 pages - HP 62 , 1 x ink cartridge (pigmented black) - up to 220 pages - HP 62
ENERGY STAR Certified
Limited warranty - 1 year , Technical support - web support - 1 year
45.4 cm
41 cm
15.6 cm
6.82 kg
Shipping Width
49.7 cm
Shipping Depth
20.5 cm
Shipping Height
49.1 cm
Shipping Weight
8.211 kg
Sound Emission
49 dBA (operating)
5 °C
15 - 80% (non-condensing)
BT67 HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm In Stock £14.71
BT67 HP Iron-on Transfers-12 sheet/A4/210 x 297 mm In Stock £13.72
