Let your creativity soar while keeping printing costs low with an HP Instant Ink ready all-in-one. Enjoy the easiest way to print lab-quality photos and laser-quality documents in fewer steps from your smartphone or tablet.
You can afford to be creative with HP Instant Ink
Save up to 70% on ink and never run out ink. Original HP ink. Ordered by your printer, delivered to your door.Print colour, black & white, and photos – your cost is the same.Ink cartridges and delivery costs included in your monthly plan price.No annual fee – change or cancel plans online anytime without penalty. -
Easily create, without the wait
Snap. Print. Enjoy. Easily print lab-quality photos from a variety of smartphones and tablets.Start printing and get connected quickly with easy setup from your smartphone, tablet, or PC.Manage printing tasks and scan from your mobile device with a free HP All-in-One Printer Remote mobile app.Connect your smartphone or tablet directly to your printer – and easily print without accessing a network. -
Make quick work of creative tasks
Be sure your projects always look good. Print borderless, lab-quality photos and laser-quality documents.The built-in photo tray lets you print 10 x 15 cm photos in brilliant colour without changing paper.Print remotely without worries – the auto-deploying output tray keeps your pages from landing on the floor. -
Make it easy
Print photo projects, or scan and copy documents, using the 5.5 cm (2.2-inch) graphics touchscreen display.Easily print at up to 12 pages per minute (ppm) for black-and-white and 8 ppm for colour.Print in any room you choose – without causing disruptions – using the optional quiet mode.
- HP ENVY 5540 e-All-in-One - multifunction printer - colour - HP Instant Ink eligible
- Multifunction printer
- Localisation
- English / United Kingdom
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 4-ink
- Monthly Duty Cycle (max)
- 1000 pages
- Recommended Monthly Volume
- 300 - 400 pages
- Max Copying Speed
- Up to 10 ppm (mono) / up to 5 ppm (colour)
- Max Copying Resolution
- Up to 300 x 300 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Up to 12 ppm (mono) / up to 8 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Scanning
- 1200 x 1200 dpi
- Display
- 2.2"
- Original Size
- 216 x 297 mm (max)
- Original Type
- Sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, iron-on transfers, photo paper
- Standard Media Capacity
- 125 sheets
- Output Trays Capacity
- 25 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, scan to folder, HP Auto Wireless Connect
- Power
- AC 120/230 V (50/60Hz)
- 45.4 cm x 41 cm x 15.6 cm
- 6.82 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Ink-jet - colour
- 1000 pages
- 300 - 400 pages
- Display Diagonal Size
- 2.2"
- Display Features
- Touch screen
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Localisation
- Standard Memory
- 128 MB
- Max Supported Memory
- 128 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 50
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Ink Cartridge Configuration
- 1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, pigment black
- 4-ink
- Printer Drivers / Emulations
- PCL 3 GUI
- First Print Out Time B/W
- 19 sec
- First Print Out Time Colour
- 22 sec
- Colour Management Features
- ColorLok Technology
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Interpolated Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Document & Media Handling
- Max Original Size
- 216 x 297 mm
- Original Type
- Sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 75 g/m²
- Max Media Weight
- 300 g/m²
- Supported Media Type
- Supported Media Sizes
- Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 76 x 127 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm)
- Borderless Photo Sizes
- 100 x 150 mm, 216 x 297 mm
- 125 sheets
- 25 sheets
- Input tray - 125 sheets size: 76 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 75 g/m² - 300 g/m² , Output tray - 25 sheets , Photo tray - 15 sheets - 100 x 150 mm
- Speed Details
- Printing: up to 22 ppm (A4) - B/W draft , Printing: up to 21 ppm (A4) - colour draft , Printing: up to 12 ppm - B/W (ISO) , Printing: up to 8 ppm - colour (ISO) , Printing: up to 12 ppm (A4) - B/W normal , Printing: up to 8 ppm (A4) - colour normal , Printing: 34 sec (10 x 15 cm (4"x6")) - photo normal , Copying: up to 10 ppm - B/W (ISO) , Copying: up to 5 ppm - colour (ISO) , Scanning: 15 sec (A4) - B/W normal , Scanning: 15 sec (A4) - colour normal
- 1 x USB 2.0 - 4 pin USB Type B
- Wi-Fi Direct
- Operating System Support
- MS Windows 7, MS Windows Vista, Apple Mac OS X 10.7, Apple Mac OS X 10.8, Windows 8, Windows RT, Android, Windows 8.1, Apple Mac OS X 10.9, Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 10, Blackberry, Windows 10 Mobile
- Software Included
- Drivers & Utilities, HP Photo Creations, HP Update
- Voltage Required
- 13.95 Watt
- Power Consumption Standby
- 3.6 Watt
- Power Consumption Sleep
- 0.93 Watt
- Consumables Included
- 1 x ink cartridge (yellow/cyan/magenta) - up to 165 pages - HP 62 , 1 x ink cartridge (pigmented black) - up to 220 pages - HP 62
- ENERGY STAR Certified
- Limited warranty - 1 year , Technical support - web support - 1 year
- 45.4 cm
- 41 cm
- 15.6 cm
- 6.82 kg
- Shipping Width
- 49.7 cm
- Shipping Depth
- 20.5 cm
- Shipping Height
- 49.1 cm
- Shipping Weight
- 8.211 kg
- Sound Emission
- 49 dBA (operating)
- 5 °C
- 40 °C
- 15 - 80% (non-condensing)
HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm | In Stock | £14.68 |
HP Iron-on Transfers-12 sheet/A4/210 x 297 mm | In Stock | £13.69 |
